Old 04-01-2013, 09:33 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
e85 question.
So have a question.. This is my first go at using e85 in a flashed car. Maybe 3 or 4 times or so I have accidentally started the car with my pump gas map instead of the correct one. One of the times it was driven out of the parking lot then I had realized what I had done and shut it off.
I have noticed when I kill the car and go to switch maps its pegged for a e85 map instead of the default 1. Not sure how it knows to switch.
Do I need to worry about anything other then the car just running like garbage when I forget, maybe possible long term damage? Since I'm never use the analog speedo I'm going to put a little sticky there for now.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-01-2013, 09:38 PM   #2
Yruyur
Yruyur's Avatar
Should not be any issues. I had to drive on pump gas for 80+ miles with the e85 tune...not recommended but laptop was dead.
I don't know what you mean by kill it then it remembers the map. Are you stalling it and just turning the key to start? It should not remember the map you are on if you completely shut off the car.
Old 04-01-2013, 09:46 PM   #3
feldy
feldy's Avatar
Killing it by turning the key off. So what happens is if this is all with in 30 seconds or so... 1. kill the car after accidentally starting it on wrong map. 2.Go to turn the car back on but before you do go to change the map. Notice its on the map it was on, before you turned the car off prior to accidentally starting it on the wrong map.
Kinda weird old school bogus Nintendo controller cheat code style stuff. like the pedal dance trick.
Maybe its just a bug in the software that its doing that who knows.
Wondering more about the affects on the motor with the wrong map.
Old 04-01-2013, 10:19 PM   #4
jamesm
Can't wait for actual flex fuel. This type of thing makes me want to avoid e85 entirely until there is a flex fuel solution available.
Old 04-01-2013, 10:32 PM   #5
Vonsamhain
Vonsamhain's Avatar
Drives: Scion FR-S (Raven)
Their are flex fuel kits available from Visconti and FA20club
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
Vonsamhain is offline   Reply With Quote
Old 04-01-2013, 11:11 PM   #6
feldy
feldy's Avatar
There is and the only reason I have not picked them up is due to the class I race in does not allow it.
Old 04-01-2013, 11:25 PM   #7
reeves
I start my car with the wrong map all the time
You should be fine if you just drove it for a little bit.. don't WOT and you got nothing to worry about.. I drove several miles with a full tank of E85 (on my 93 tune), from the E85 station to the dyno when I got my E85 tune.
reeves is offline   Reply With Quote
Old 04-02-2013, 12:18 AM   #8
lexusb3
Drives: FRS
@reeves i completely agree....i done the same thing plenty of times
lexusb3 is offline   Reply With Quote
Old 04-02-2013, 12:22 AM   #9
feldy
feldy's Avatar
Cool thanks everyone.
Old 04-02-2013, 02:36 AM   #10
Xdragonxb0i
Drives: ex500r
the maps reset everytime?
I thought if you turn your car off on a certain map (e85) map, when you come back it would still be on it? or does automatically go to the default 1 map?
Xdragonxb0i is offline   Reply With Quote
Old 04-02-2013, 02:58 AM   #11
Yruyur
Yruyur's Avatar
None of the tuners have been able to find out how to make the map number stay after the car is shut off. I know John was working on a switch that would accomplish similar results. At least the last I read.
Old 04-02-2013, 11:10 AM   #12
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Some cars will remember the last map you were on and some don't. To my knowledge they don't know why it happens on some cars and doesn't on others.
My car switches back to map 1 everytime I turn it off.
Ranatsu is offline   Reply With Quote
Old 04-02-2013, 11:31 AM   #13
Foobar
SLO NO MO
Foobar's Avatar
Some cars meaning different makes/models or all FRS/BRZ? If all FRS/BRZ, I don't think that's true so long as we're talking about ECUTek.
ECUTek always defaults back to Map 1 upon startup, but if you quickly shutdown/startup, it apparently doesn't get a chance to clear it (not sure what the threshold is though).
Old 04-02-2013, 11:46 AM   #14
Ranatsu
Cone basher
Some BRZ/FR-S owners have said the car remembers what map they were on the last time they drove the car. Mine does not, but its obvious that the things I have read could be completely incorrect.
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Oil question.. tintumz22 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-13-2013 12:41 PM
mpg question jarviz Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 01:40 PM
TCS/VSC question. Cheddar Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 08:29 PM
Question for BRZ and GT-87 hps? west2k95 Scion FR-S / Toyota 86 GT86 General Forum 276 03-13-2012 10:45 PM
