#155 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I've seen two in Australia alone, one turbo & one NA. The turbo setup snapped the rod on decel while slowing down to pull into the owners street, the NA one snapped through normal acceleration at around 6000rpm. Both ended up with the typical block windows
| The Following User Says Thank You to JP For This Useful Post: | Sportsguy83 (04-01-2013) |
#156 |
Kurenai Samurai
Drives: Red and manual
yeah thats why im staying n/a less headache and im under warr
#157 | |
Drives: 2013 Asphalt FR-S
http://www.turbomaster.info/eng/appl...ial.php?wg=F41
~Namaste~ |
#158 | |
Drives: 2013 White Out FR-S
#159 |
Drives: Pile of junk
Thank you fa20club!!!!!
cant wait to get the car back |
#160 |
Drives: Raven M/T FR-S
#161 |
im sending it to them
| The Following 2 Users Say Thank You to Frs300 For This Useful Post: | akuhei (04-01-2013), Sportsguy83 (04-02-2013) |
#162 |
I could have missed it but did anyone mention if the correct fuel injectors were installed? I had this happen once... Took me a number of pulls to figure out why i was maxing my injector cycle so quickly. It took me about a week before i finally yanked the injectors and realized the 550cc i thought i had were 275's. ( i was messing with the pump, lines, filter, fuel fail...). I felt pretty stupid that i didn't verify before installing. Luckily though the engine didnt go out from it, throttle was cut the moment it started leaning out.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#163 |
Drives: Single Turbo Supra
The main problem here is that no safeguards were in place. No data logging, no wideband, no boost gauge(which is never ok on forced induction applications), running on a basemap, and pushing the car too hard before its ready.
Not only will you have no idea what the car is doing but you will also have no idea of how to prove what went wrong. On a High CR motor you have to be extra cautious,like baby steps. Losing traction in first and shifting into second doesn't exact sound like you were taking it easy before you knew it was safe to push it. I hate it for you ,but if you start mixing boost and high compression then you damn sure better make sure everything is perfect before blasting on it. |
#164 | |
Drives: 2013 BRZ Turbo, 2013 FRS
#165 |
nobody mentioned it but they were correct ones
i had drove it around for almost 100 miles before i got on it good. but yes you are correct in a way it is my fault for not having my failsafe installed |
#166 |
86 Noob
Drives: Firestorm FR-S
So are we saying running a basemap is not okay? I plan on going with an fa20 club setup and their basemap. I planned on running just the basemap because I dont know of any tuners in my area. I live in a crappy town
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
#167 |
Add lightness!
Drives: 17' WRX
I think if you are going to pay $5000 (+$ for install) for a turbo kit on your $27000 car you should be able to pony up another $200 for a custom tune... I think the point of the base map is so you can drive the car safely after install to get tuned. I'm sure there is a decent tuner near you. I've driven to San Fransisco from LA to get tuned before.
| The Following User Says Thank You to industrial For This Useful Post: | coyote (04-01-2013) |
#168 |
basemap is fine just dont do what i did and hold off on installing a boost gauge of some sort. install it from the get go..hell i had my wideband/failsafe and shit in the back seat in the box so its not like i didnt have one.
me being lazy turned into almost 10K $$$$$$ |
| The Following User Says Thank You to Frs300 For This Useful Post: | EAGLE5 (04-02-2013) |
| Swapping the motor. Either 3uz or 2gr | diss7 | Engine Swaps | 34 | 11-16-2015 04:31 PM |
| Motor swaps.. | Brian S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-19-2012 04:18 PM |
| BMTV (Best Motor TV) HKS vs TRD vs 86 | KyShro | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-09-2012 10:48 AM |
| Will Lotus use the FR-S motor? | muffinman | Other Vehicles & General Automotive Discussions | 26 | 01-20-2012 09:24 PM |
