kidgogeta
Old 03-31-2013, 04:07 PM   #435
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
research before you buy that setup to get the "stanced" look when you really don't know what you're getting into. Tire size, camber and height play big roles when it comes to fitment or how much room you'll have. Seems the FR-S has a lot of room all around but haven't spent any time with on in that wheel fitment sense.
Post photos of your setup with the new coils:
Originally Posted by VADER View Post
So would 18x9.75J +20et w/ 235/40 All around be rubbing? Just installed my BC BR Type Coilovers yesterday. Didn't mess with the height, just installed them the way they came out of the box (which is low already w/ about 1-1.5" more maxout). I want the "slammed" look, with the most concavity on the wheels I can get, but if I can avoid rubbing that would be GREAT!
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 03-31-2013, 04:31 PM   #436
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Originally Posted by Noob4Life View Post
anybody have a weight? Was debating on these but figured theyd be heavy
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Also interested in the weight please?
Scaldy is offline   Reply With Quote
Old 03-31-2013, 04:37 PM   #437
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
So would
18x8.75 35 front
18x9.75 20 rear
be a good set up? or would a better set up be a front of 18x8.75 20?
In my opinion, go for 18x8.75 all around, with et35. 9.75 and ET20 will poke out way to much and will look shitty unless you like the hellaflush look. Check the previous pages of this thread, plenty of pictures of different setups with different wheel sizes, and choose whatever you like the most
Originally Posted by Wonderbar View Post
I'm pretty set on these as my daily wheels, powdercoated white or the gold from xxr.
17x8.25 +35 front
18x8.75 +33 rear
Anyone have weights of these?
X2 anybody have a weight? Was debating on these but figured theyd be heavy
18x8.75 is 9.5kg, not sure about the other wheel sizes
Killerbee is offline   Reply With Quote
Old 04-01-2013, 12:47 PM   #438
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
would an 8.75 +20 be more concave looking than an 8.75 +35 ?
VADER is offline   Reply With Quote
Old 04-01-2013, 01:32 PM   #439
Killerbee
Killerbee's Avatar
See post 433 here in this thread
http://www.ft86club.com/forums/showp...&postcount=433
Old 04-01-2013, 08:22 PM   #440
ChrisNcoronel
ChrisNcoronel's Avatar
Drives: Fr-S
Test fitted them today on the rear.
XXR 527 18x8.75 +35
waiting to order my eibach springs.
Tires coming in on May.
ChrisNcoronel is offline   Reply With Quote
Old 04-01-2013, 08:24 PM   #441
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
XXR 527 18x8.75 +35
ouch what a tease for yourself
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
ChrisNcoronel (04-01-2013)
Old 04-01-2013, 08:26 PM   #442
ChrisNcoronel
Drives: Fr-S
haha its okay. Patience is key
Old 04-01-2013, 11:11 PM   #443
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Originally Posted by Killerbee View Post
So to be clear. The chromium black +20's look more concave than the white +35's.. agree?
Old 04-01-2013, 11:28 PM   #444
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
No from what I got is the width of the actual wheel is what makes the concavity not the offset. 20 offset will poke ALOT! Stick with 35 offset, there's enough concavity cause I'm in the same boat as you and it's perfect for me
SMOKETREES is offline   Reply With Quote
Old 04-01-2013, 11:36 PM   #445
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Originally Posted by DC-FRS View Post
Put my 530s on this week. Turned out great!
Thoughts?
Attachment 32366
Looks like sex to me bro,tuxedo look does you good
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 04-01-2013, 11:44 PM   #446
Killerbee
Killerbee's Avatar
No. ET 20 and ET 35 will have the same concave face. The only difference is the "space" in the area where the lugnuts go. Compare the black and the white wheels I've posted and you'll see the difference
Agreed on this. ET20 makes only sence if you go for a widebody kit or hellaflush look
The Following User Says Thank You to Killerbee For This Useful Post:
DemonRawr (10-02-2015)
Old 04-02-2013, 02:05 AM   #447
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Agreed and that's if you run at least full camber that you can possibly get if you have no wide body. But if so you might also need some spacers also to get a flushed look with the widebody fenders.
Old 04-02-2013, 10:58 AM   #448
camelflage
Drives: pinto power
based on what i have seen in person, the 18x8.75 have the same face for +20 and +35, so either way same concavity. they cast the 18x8.75 +20 and then shave 15mm off the mounting surface, now you have +35..
the 18x9.75 +20 has more concavity, but is only offered in the one offset.
there are people running an 18x9.75 +20 setup all around, and it looks pretty sick, but you will need to stretch and camber and probably do a little fender pulling to keep it from rubbing.
i ordered 18x8.75 +20, with 225/40/18 front and rear, and will mount those up and take some pics for you asap. i am expecting poke, but the stretch and a little camber should clear me fine.
most people seem to be getting the 18x8.75 +35 all around because it looks flush and doesn't require much stretch or camber. since these are just as concave as the +20, then either one you have the same look concave-wise.
for reference:
18X9.75 +20 all around
Originally Posted by SLICVIC View Post
new wheels
18x8.75 +35 front and +20 rear (same face front and back)
Originally Posted by umpadupa View Post
Might as well add to this
camelflage is offline   Reply With Quote
The Following User Says Thank You to camelflage For This Useful Post:
StRacngtC06 (04-02-2013)
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
