kidgogeta
Old 03-31-2013, 01:54 AM   #421
DC-FRS
Drives: Whiteout FR-S
Originally Posted by white_knight View Post
Looks great!
More info on suspension/tyres please.
Suspension: Lowered on Eibach Pro-Kit springs
Tires: BFGoodrich BF Sport-COMP2 225/40/ZR18
DC-FRS is offline   Reply With Quote
Old 03-31-2013, 03:26 AM   #422
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Size, offset?
white_knight is offline   Reply With Quote
Old 03-31-2013, 07:08 AM   #423
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Originally Posted by jedichimp View Post
Width typically determines concavity but offset also plays a factor. But yes, the 9.75" +20 will be more concave than the 8.75" +35
8.75:
Staggered so you can see the different concavity:
So would 18x9.75J +20et w/ 235/40 All around be rubbing? Just installed my BC BR Type Coilovers yesterday. Didn't mess with the height, just installed them the way they came out of the box (which is low already w/ about 1-1.5" more maxout). I want the "slammed" look, with the most concavity on the wheels I can get, but if I can avoid rubbing that would be GREAT!
VADER is offline   Reply With Quote
Old 03-31-2013, 08:38 AM   #424
white_knight
9.75 +20mm up front is really pushing it (perhaps quite literally)!!!
I think even if you max out on camber, you will poke like a mofo.
Old 03-31-2013, 09:08 AM   #425
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Ok so in this case, would an 8.75 be more ideal for the front and 9.75 for the rear? Also would an 8.75 +20 be more concave than an 8.75 +35?
Old 03-31-2013, 09:17 AM   #426
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I would do
18x8.75 35 front
18x9.75 20 rear
Old 03-31-2013, 09:20 AM   #427
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Originally Posted by whitefrs View Post
I would do
18x8.75 35 front
18x9.75 20 rear
Now remember.. I want the most concavity I can get. Is this the best set up for what I'm looking for?
Old 03-31-2013, 09:28 AM   #428
Vten
Drives: Too heavy
Has anyone tried this yet:
18x8.75 et35
18x9.75 et35
A friend offer me 225/40/18 F and 255/35/18 R Michelin pilot sports tires that I can't pass.
Would it rub a lot with Umpadupa height setting ?
Vten is offline   Reply With Quote
Old 03-31-2013, 10:17 AM   #429
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
18x8.75 et35
18x9.75 et35
They don't offer the 9.75 in +35, only +20
Old 03-31-2013, 11:02 AM   #430
Vten
Drives: Too heavy
Oops pardon my newbieness
How about :
18x8.75 et20
18x9.75 et20
How much poke would they be ?
Old 03-31-2013, 11:33 AM   #431
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
How about :
18x8.75 et20
18x9.75 et20
on stock suspension without any camber set:
18x8.75 et 20 will poke out about 20mm in the front
18x9.75 et 20 will poke out about 30mm in the rear
If you're not planning any overfender/widebody kit you should go for 18x8.75 et35 square (when lowering the car/put some camber to it) or even a 18x8.25 et 35 if you stay on stock suspension and do not like the wheels to poke out a bit
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
CircuitJerk (03-31-2013)
Old 03-31-2013, 11:43 AM   #432
Killerbee
Killerbee's Avatar
Also to state one point regarding the ET of wheels
Less ET does NOT necessary mean more concavity. There are some wheel design that this is true, but in case of the XXR527 this is not.
Some wheels simply keep their concavity but the center of the wheel gets more "space"
compare those two pictures below.
White seems to be a 8.75 with ET 20 (just the front wheel, the rear one is a 9.75)
Black is a 8.75 ET 35
Now look at the center of the wheel, where the lugnuts go. You can see that the white one is far "deeper" than the black one.
As far as I'm aware, the XXR concavity does only change by the wide of the wheel itself, not by its ET.
SkAsphalt (04-01-2013)
Old 03-31-2013, 12:44 PM   #433
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
No look at the center of the wheel, where the lugnuts go. You can see that the white one is far "deeper" than the black one.
So would
18x8.75 35 front
18x9.75 20 rear
be a good set up? or would a better set up be a front of 18x8.75 20?
Old 03-31-2013, 12:56 PM   #434
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I'm pretty set on these as my daily wheels, powdercoated white or the gold from xxr.
17x8.25 +35 front
18x8.75 +33 rear
Anyone have weights of these?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
