Old 03-31-2013, 10:26 PM   #99
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I would love for you to run outside and take a look/pictures of the wastegate lines and see what color spring is inside the wastegate. If you do this now and document it, than the installer can't claim everything was right.
I have never seen a fuel pump fail and put a hole in a motor, although anything is possible.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
JoeBoxer (04-01-2013)
Old 03-31-2013, 11:23 PM   #100
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
This sucks. Sorry to hear it. I look forward to your built block and low compression pistons so you can turn up the boost!
Old 03-31-2013, 11:45 PM   #101
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Random question: did your FX400 make a lot of vibration/rattling noise at low RPMs and decel?
This question is unrelated to the engine failure, I'm just curious. Sorry to hear about the issues you are having
Pure Automotive is offline   Reply With Quote
Old 04-01-2013, 12:06 AM   #102
jshadeck
jshadeck's Avatar
Originally Posted by Noob4Life View Post
Technically all a boost gauge is, is a vacuum gauge so i would think if the ecu can read vacuum it can read boost
Right... But the ecu was not made to read boost from a turbo, so i dont see why there would be a PID for boost.. Again though i know very little about the ecu/obd/app coordination
jshadeck is offline   Reply With Quote
Old 04-01-2013, 12:25 AM   #103
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Good luck with rebuild! I'm sorry to hear about your loss. Time to make some lemonade...
TyperRspec789 is offline   Reply With Quote
Old 04-01-2013, 02:37 AM   #104
Visconti
Drives: 05 STi
Originally Posted by 2forme View Post
If you blew a hole in your motor, that probably wasn't overboost, but a problem with the fuel/air/ignition mix. If you shot ridiculous amounts of boost, it would lift the head or blow the head gasket before tearing a chunk out of the motor itself.
No, this is a faulty install. Sounds like they screwed up the vacuum lines if the BOV is opening at idle (under vacuum). If that's the case, they most likely screwed up the vacuum line for the wastegate. Perhaps they used the same vacuum source for both?
Gem is right, this is a risk with TC's. They are little more sensitive to misinstallation. The reward is that you can get oodles more power out of them with less boost, when they are installed correctly.
Sucks man, I hope the dealer acknowledges its screw up and accommodates you.
Dont be mistaken..30 psi on the basemap would put a hole in the block.
8psi boost limiter would have saved this motor.
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Sportsguy83 (04-01-2013)
Old 04-01-2013, 03:20 AM   #105
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Sorry to hear, i've been working at dealerships for almost 10 years and have only had a couple tech's i would consider putting a turbo kit on my car. We probably would install a kit if somebody asked but i guarantee there wouldn't be a warranty unless it was a factory part. Dealership labor rates are incredibly high compared to independent shops too so i'm surprised it was even cost feasible to have them install it.
Old 04-01-2013, 03:22 AM   #106
Sonolin
OP, I'm very sorry for your loss.
Keep up the spirit and try again with a new engine, GL.
Sonolin is offline   Reply With Quote
Old 04-01-2013, 04:57 AM   #107
cf6mech
Drives: FRS Silver LS1 swapped.
Running lower cr 9 to 1 and 18 psi boost, looks like a head gasket blew out....waiting for verdict,....white smoke out tail pipe coolant low.
cf6mech is offline   Reply With Quote
Old 04-01-2013, 05:03 AM   #108
GTerran
GTerran's Avatar
Originally Posted by jshadeck View Post
Maybe u can answer the question i had in the back of my head... Will the obd apps be able to read boost from an ecu that was not programmed for a factory turbo car?
The stock BRZ/FRS computer is the same out of the GT-R with all the same data points that are associated with a twin turbo car...
wouldn't mind a tuner confirming this.
GTerran is offline   Reply With Quote
Old 04-01-2013, 06:40 AM   #109
2forme
As long as the MAP sensor being used is calibrated correctly, then yes. It will function just fine.
The Following 3 Users Say Thank You to 2forme For This Useful Post:
Huehuecoyotl (04-01-2013), jamesm (04-01-2013), Sportsguy83 (04-01-2013)
Old 04-01-2013, 07:19 AM   #110
Godzilla35
Drives: Nissan GT-R
sorry didn't read the whole thread and don't know much about aftermarket forced induction systems... but my question is, are zipties safe to use to hold any hosing in an engine bay? That would've been sketchy install tip off #1 to me personally.
Godzilla35 is offline   Reply With Quote
Old 04-01-2013, 07:34 AM   #111
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Absolutely, subaru and I agree, you can see the oe stuff in background
if it was a dealership install surely they had these lying around
these photos could be helpful if you call 800-LAWYER, dealerships have insurance policies, I couldnt PAY for work at a shop where they really could have sourced a hose clamp at under $1 each...just saying, best practices...
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Godzilla35 (04-01-2013)
Old 04-01-2013, 07:41 AM   #112
2forme
Lol, to his credit, Crawford provides zip ties for their AOS. Kinda cheap if you as me.
The Following User Says Thank You to 2forme For This Useful Post:
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
