Old 03-31-2013, 07:24 PM   #85
86pro
Drives: frs
yea or get cp rod and pistons. Same as that and lot less. About a lil over 2 grand. then a e85 kit lol All depends on where you want to go with your car. I wont change the internals yet on my car because engine block is good. waiting on heads like valves and springs with cams and so on and so fourth and as well as a crankshaft, then...........along with the bottom end we are going to see the true potential of this engine. high horsepower and reliability. Gotta love Toyota.(n a lil subaru)
86pro is offline   Reply With Quote
Old 03-31-2013, 07:27 PM   #86
Frs300
Frs300's Avatar
Drives: Pile of junk
cant believe this post has 2000 views just today
Frs300 is offline   Reply With Quote
Old 03-31-2013, 07:36 PM   #87
crook
crook's Avatar
Drives: storm black GT
Minus the block which he needs
crook is offline   Reply With Quote
Old 03-31-2013, 07:37 PM   #88
mad_sb
Drives: 2013 Asphalt FR-S
make sure any parts that are re used get inspected and fully cleaned, especially anything that has an oil or coolant passage. Last thing you want is debree from this one causing oil starvation or lack of coolant flow on the next one
The Following User Says Thank You to mad_sb For This Useful Post:
crook (03-31-2013)
Old 03-31-2013, 07:38 PM   #89
crook
crook's Avatar
Haha yep cause alot of people are going/have gone the FI route and its always good to know the reasoning for failure
The Following User Says Thank You to crook For This Useful Post:
86pro (03-31-2013)
Old 03-31-2013, 07:44 PM   #90
2forme
If you blew a hole in your motor, that probably wasn't overboost, but a problem with the fuel/air/ignition mix. If you shot ridiculous amounts of boost, it would lift the head or blow the head gasket before tearing a chunk out of the motor itself.
No, this is a faulty install. Sounds like they screwed up the vacuum lines if the BOV is opening at idle (under vacuum). If that's the case, they most likely screwed up the vacuum line for the wastegate. Perhaps they used the same vacuum source for both?
Gem is right, this is a risk with TC's. They are little more sensitive to misinstallation. The reward is that you can get oodles more power out of them with less boost, when they are installed correctly.
Sucks man, I hope the dealer acknowledges its screw up and accommodates you.
The Following 5 Users Say Thank You to 2forme For This Useful Post:
Huehuecoyotl (04-01-2013), Spaceywilly (03-31-2013), Sportsguy83 (03-31-2013), TRD_07 (04-01-2013), tripjammer (04-15-2013)
Old 03-31-2013, 07:46 PM   #91
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
i was taking the car home to install a aem failsafe/wideband but didnt make it that far obviously
That is why you stay out of boost until you get them installed.
Sent from my SCH-I605 using Tapatalk 2
MattF is offline   Reply With Quote
The Following User Says Thank You to MattF For This Useful Post:
2forme (03-31-2013)
Old 03-31-2013, 07:57 PM   #92
2forme
x 1000000. At least have a bluetooth OBD and Torque on your smart phone. That's a better Boost/AFR gauge than nothing. That would have been the first thing installed if I couldn't have a true wideband in before getting it home.
Old 03-31-2013, 08:23 PM   #93
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
My bov is open at idle which is perfectly normal since the engine is in vacuum while idling, as soon as it starts to boost it will keep it shut with the pressure and yhen let off ghe thtottle back in vacuum amd open again
Silverdub is offline   Reply With Quote
Old 03-31-2013, 08:29 PM   #94
mad_sb
yeah, it is very common for softly sprung BOV's to open under manifold vacuum. that is not the part they screwed up.
Old 03-31-2013, 09:03 PM   #95
2forme
I've never had a softly sprung BOV then. LOL
Old 03-31-2013, 09:06 PM   #96
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
2forme, that sounds personal*
Huehuecoyotl is offline   Reply With Quote
The Following 4 Users Say Thank You to Huehuecoyotl For This Useful Post:
2forme (04-01-2013), ftc~brz (04-04-2013), Sportsguy83 (04-01-2013), Stav (03-31-2013)
Old 03-31-2013, 10:03 PM   #97
jshadeck
jshadeck's Avatar
Maybe u can answer the question i had in the back of my head... Will the obd apps be able to read boost from an ecu that was not programmed for a factory turbo car?
jshadeck is offline   Reply With Quote
Old 03-31-2013, 10:20 PM   #98
Noob4Life
86 Noob
Drives: Firestorm FR-S
Technically all a boost gauge is, is a vacuum gauge so i would think if the ecu can read vacuum it can read boost
Noob4Life is offline   Reply With Quote
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
