Old 03-27-2013, 05:30 PM   #169
Marrk
Drives: Honda Fit
Originally Posted by Foobar View Post
Just performed this fix today using Permatech's The Right Stuff. After thoroughly cleaning off any residue, I ended up applying the goop on the plate side (following the imprint left by the old seal) - trying to use the applicator gun in that tight space to put it directly on the head side was too much of a pain in the ass, so I just spooged it on the plate, about a quarter of an inch ring, then plopped it back on and torqued it at 12 ft lbs. We'll see how well it holds.
Hmm. 12 lbs isn't very much. But if that what the book says . . . .
Marrk is offline   Reply With Quote
Old 03-27-2013, 05:51 PM   #170
Foobar
SLO NO MO
Foobar's Avatar
Well technically it says 11.8, but my cheap little 3/8ths torque wrench doesn't have that kind of precision
Old 03-28-2013, 08:43 AM   #171
roflcopter
Gold Member
roflcopter's Avatar
Drives: 2013 Whiteout FR-S
Originally Posted by EL_to_TBD View Post
Do you know what your vehicle build date is?
Thanks.
Nov. 2012
roflcopter is offline   Reply With Quote
Old 03-28-2013, 04:28 PM   #172
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That is all that is needed most times, I work in aerospace, we shoot stuff into orbit torqued to less than 10 in-lbs. Anything more and you're just stressing the screw or the threads. It's only a little plate that plugs a hole.
ineedyourdiddly
Marrk (03-28-2013)
Old 03-28-2013, 08:22 PM   #173
Marrk
Drives: Honda Fit
I'm sure you're right.
It's just that it's leaking and all, and this is an area of the car that is subject to a considerable amount of vibration. And, um, I over-torque everything like a maniac. It's the only fun I get to have in life.
Old 03-29-2013, 12:00 AM   #174
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by gzpermadi View Post
Mine is Feb '13 made. Last week I touched that area seems clean
Try to drive it for 30 minutes and then feel it again. I thought mines was dry until after a 30 minute drive with 15 minute to cool I touched the plate and I had fresh oil on my hands. argh!
LeeMaster is offline   Reply With Quote
Old 03-29-2013, 08:48 AM   #175
Foobar
SLO NO MO
Foobar's Avatar
Drove my car all around yesterday and so far so good, the Permatex "The Right Stuff" is keeping the oil in place.
According to Permatex, the gasket is ready within minutes of application, but I let it sit for an hour before I started the car up to back it down the ramps (had the back ramped up so the oil would stay in place) and let the engine warm up for a few minutes just to check for any issues. The car then sat overnight and then I drove it around all day, no issues. I'll continue to monitor it and report back if the gasket fails over the next week.
The Following User Says Thank You to Foobar For This Useful Post:
mact (03-30-2013)
Old 03-29-2013, 09:08 PM   #176
SVThis
SVThis's Avatar
Drives: Scion FRS
I just did mine with the Black Permatex Right Stuff also. Hopefully it seals. Going to left mine sit over night before I start it up. Mine was barely leaking before but I'm anal. Hope it doesn't end up being worse. Getting the old sealant off the backing plate is kind of a pain.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-29-2013, 10:02 PM   #177
SloS13
Drives: 2013 FR-S whiteout
I've done mine 3x and it's slowly coming back. I use a gasket scraper, also - you said anal so lol.
SloS13 is offline   Reply With Quote
Old 03-31-2013, 02:35 PM   #178
Snoopy_TXR
Snoopy_TXR's Avatar
Drives: 2013 Raven FR-S & 2005 BSP X-Runner
I took my car out from storage and started the car up. While it idle, I noticed a burning smell. I couldn't figure out where it was coming from so I open the hood but i could not locate the source. I decide to take the car for a spin after warming up and after driving few minutes I notice the smell was coming through the vents. I parked to open up the hood and saw fumes coming from the the bottom of the motor from the passenger side. I look for leaks and found oil the bottom splash shield and oil on the plate everyone had been describing. I am taking her in to the dealer tomorrow. I'm frustrated but am glad that I am not the only one to have this problem.
Snoopy_TXR is offline   Reply With Quote
Old 03-31-2013, 03:47 PM   #179
cf6mech
Drives: FRS Silver LS1 swapped.
You can buy a sheet of gasket material of your preferance, use the plate as a template, and make a custom gasket for this,..... problem solved,...permanently.
http://www.summitracing.com/parts/fel-3060/overview/
Shocked nobody has suggested this yet, flimsy stamped plate like that with low torque needs some material for give and to fill the gaps,....thats why you guys are having repeated issues with just sealant......no bueno.
cf6mech is offline   Reply With Quote
Old 03-31-2013, 03:52 PM   #180
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My OEM plate had no leaks. I installed the AVO oil pump in that place, created a Ultra Permaflex gasket, and not leaks either.
Old 03-31-2013, 09:27 PM   #181
Snoopy_TXR
Snoopy_TXR's Avatar
I'm going to take the car in, file a claim, and get it fixed by the dealer. I mean come on, this is a new car and it's already leaking oil! Stealerships need to know about this serious problem and fix it because many FRS/BRZ owners have this problem. If it leaks again after the stealership repairs it, I'll repair it myself by making a custom gasket like what you suggested because it makes more sense to a perminant solution of fixing this problem. Thanks for the suggestion.
Old 03-31-2013, 11:19 PM   #182
Lonewolf
Lonewolf's Avatar
Drives: Moped
The dealers/Toyota does need to know about it. All the people performing their self-made fixes is a great and industrious thing, just let the dealer document it first.
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 04:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 05:43 PM
