Old 08-28-2012, 10:27 AM   #1
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
Tires keep leaking
My tpms keeps going off and ALL my wheels are loosing pressure. It was almost everyday so I went to nitrogen and now every 4 days it goes off and all tires are low. I tightened the outside of the tpms's which were all a little loose but it is still leaking.
Anyone else having this problem? Should I take it in for warranty, I have an intake and no snorkel and don't feel like getting busted cause I don't want to replace everything. Or should I pop the tires off at school and just make sure the inside is set and tight?
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 08-28-2012, 10:32 AM   #2
EvoXDD
I was thinking of just poppin off the hood release wire so if someone wanted to take a peak there would be extra effort envolved.
Old 08-28-2012, 06:12 PM   #3
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Why not take it to a tire shop and ask for their advice first?
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 08-28-2012, 06:16 PM   #4
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Why would the dealership need to pop your hood to check your tires?
Tanuki is offline   Reply With Quote
Old 08-28-2012, 06:25 PM   #5
GregV
Drives: Kia Stinger GT2
Aftermarket intake should not void your warranty, and certainly should have no bearing in the warranty coverage of a faulty or improperly installed TPMS/sensors.
GregV is offline   Reply With Quote
Old 08-28-2012, 06:38 PM   #6
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
+1 this is a new car that's leaking air at all four tires... Screw worrying about your intake..
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-28-2012, 08:39 PM   #7
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
The TPMS sensor seal is probably leaking.
Not a big issue, but dealership should be able to replace the seal no problem.
Have you had a shop check for leaks on the tire itself?
Touge Factory is offline   Reply With Quote
Old 08-28-2012, 11:58 PM   #8
EvoXDD
To answer why worry about under the hood, because it does NOT sound stock anymore and don't want to have to bring laws and acts and all the other stuff to get something fixed down the road.
Also don't need to take it to a shop, I have my own, but if I pop the tires off they could very well blame me for tampering with the sensors.
But the original question. Anyone else have this issue?
Old 08-29-2012, 12:42 AM   #9
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Run some soapy water or just water over the valve stem area and see if its bubbling. That way you don't need to pop off your tires.
Xanatos is offline   Reply With Quote
Old 08-29-2012, 12:45 AM   #10
ahausheer
Re-member
Drives: Toyota camry
Exact thing happened on my companies Honda Element, put in a small amount of fix a flat and problem solved. A year later TPMS still works fine.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 08-29-2012, 12:50 AM   #11
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Just got to make sure first...These are STOCK tires right?
Could be a few possibilities here:
-Punctured tire
-Corroded seating of the beads (Tire not sitting flush to the rim because of dirt or some kind of debris stuck inbetween the tire and the rim)
-Leaking TPMS
I would dip the whole wheel into a shallow bucket of soapy water and turn it around to cover every inch of the tire; take it out and look for bubbles.
If it does turn out to be corroded sitting of the beads...dismount the tire off the rim, thoroughly clean and scrub around the rim where the tire bead would sit, remount, and fill it up and check again.
This is very unusual though; it may very well be the FIRST time I've heard a brand new car having all 4 flats at the same time... Hope it's a quick fix!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 08-29-2012, 03:03 AM   #12
Willsonk
Drives: Scion FR-S Asphalt AT & XB
I would check the torque on your TPMS. I should be 35 "inch" lbs. Do not over torque ..... gasket can be damaged which causes it to leak. Check the torque on the valve core too. Use windex and spray the TPMS area and the tire bead to check for leaks. Best of luck.
Willsonk is offline   Reply With Quote
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
So what non-OEM tires have been tried so far on BRZ/FRS? suzuka Scion FR-S / Toyota 86 GT86 General Forum 20 05-07-2012 10:33 AM
What tires? firebug451 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-24-2012 03:05 PM
What tires do you want? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 123 12-12-2011 02:15 PM
