| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: Ultramarine 86 - 6MT
#16 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I can only recommend to use a slight drop (1inch) when changing out the wheels to something more agressive
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#17 | |
FRS Adept
Drives: Firestorm FRS
http://www.frsproject.com/tire_size.php 245 45 17 is a decent size. depends also if you are concerned about weight. then you need to search for a tire brand that meets your target. weight for the same size tire varies by manufacturer. |
#18 |
Drives: 2013 Scion FRS Raven
lets try this again
Here are the pictures of the car
| The Following User Says Thank You to Pbrown For This Useful Post: | forzajuve (03-30-2013) |
#19 |
Proud of BOXER
Drives: Subaru Boxer
| The Following User Says Thank You to Clipdat For This Useful Post: | Beyer Subaru (04-01-2013) |
#20 |
#21 |
#22 |
Oh it's still here
#23 |
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Here's mine, still stock height. Thought the wheel gap would bug me more than it does, that being said, I'm pretty sure it will get lowered eventually.
![]() 2013 FRS 6AT in Raven! |
| The Following User Says Thank You to FRSGT86 For This Useful Post: | forzajuve (03-30-2013) |
#24 |
Thanks
Thank you. Yes 20% on the back 35% on the sides. Keeping everything legal in Ontario. Unless you are going to track the car or for personal preference, stock height is great. The tire size is 225 40 18 offset is +35 in case I didn't post that. A little stretched and the ride is smoother than the winters I had on it. Good luck with your decision. It is by the far the toughest I had to make regarding the car.
#25 |
Still looks good though. The more I am seeing everyone's stock height + 18's it actually looks pretty good since the car naturally sits pretty low as is. You can still get away with it and it still does not look unproportioned
#26 | |
#27 | |
Now that that's gone, the gap is allot easier to live with until I can figure how how to lower it, springs or coilovers, and how much drop. Looks awesome with 1.5 inch or more drop, but I just don't want to mess up the already almost perfect handling characteristics it already has. I'd like to see and ride in a couple with both to compare the difference between the two.
| Anybody got 16 inch wheels on their FR-S /BRZ? | Bmore_Raven86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 734 | 04-27-2022 06:11 PM |
| XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop | AGM6789 | AUSTRALIA | 17 | 11-10-2012 05:10 AM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 06:15 AM |
| Can i drop my car an inch or more and then raise it back to stock height? | ScionFR-S | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 11-01-2012 09:02 PM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 08:33 AM |
