Old 03-30-2013, 02:20 PM   #15
forzajuve
Drives: Ultramarine 86 - 6MT
That link didn't work man
forzajuve is offline   Reply With Quote
Old 03-30-2013, 02:50 PM   #16
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by forzajuve View Post
Thank you for sharing! This is really helping me figure out my next purchase. One more thing, your 18s on stock height vs 18s on the 1 inch eibach drop... do you notice any wheel rubbing with the drop? If I were to do the same (18's + 1inch drop) and went to go drive on a back road somewhat aggressively would there be any drawback?
Glad I can help. No wheel rubbing at all, also the ride quality has not much changed with the drop. The biggest change was when I changed wheels/tires, but the drop itself did not make the car noticably harder or less comfortable to drive.
I can only recommend to use a slight drop (1inch) when changing out the wheels to something more agressive
Killerbee is offline   Reply With Quote
Old 03-30-2013, 05:30 PM   #17
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
Miodculae, what would you recommend if someone were to go that route?
you can use the tire calculator that's linked at the top of this page:
http://www.frsproject.com/tire_size.php
245 45 17 is a decent size. depends also if you are concerned about weight.
then you need to search for a tire brand that meets your target. weight
for the same size tire varies by manufacturer.
miodculae is offline   Reply With Quote
Old 03-30-2013, 08:53 PM   #18
Pbrown
Drives: 2013 Scion FRS Raven
lets try this again
Curious to see if anyone has upgraded to 18 inch wheels but has not lowered their car, kept it stock. PLEASE provide pictures thanks!
Here are the pictures of the car
Pbrown is offline   Reply With Quote
The Following User Says Thank You to Pbrown For This Useful Post:
forzajuve (03-30-2013)
Old 03-30-2013, 09:24 PM   #19
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What wheels are these? Thanks in advance!
Originally Posted by Beyer Subaru View Post
Here's one of mine pre-coilovers:
Beyer Subaru (04-01-2013)
Old 03-30-2013, 10:08 PM   #20
Trog
Where all the snow go?
Trog is offline   Reply With Quote
Old 03-30-2013, 10:15 PM   #21
forzajuve
Pbrown, that is hawwwwt. I am liking the wheels a lot, great contrast. Looks like you got 20% or 30% tint all around too? I dig it man.
Old 03-30-2013, 10:32 PM   #22
Pbrown
Oh it's still here
S
Just on the other side of the car is about 4 feet still. Be another couple of weeks before the first sloshy round of golf
Old 03-30-2013, 10:38 PM   #23
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Here's mine, still stock height. Thought the wheel gap would bug me more than it does, that being said, I'm pretty sure it will get lowered eventually.
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
The Following User Says Thank You to FRSGT86 For This Useful Post:
Old 03-30-2013, 10:38 PM   #24
Pbrown
Thanks
Thank you. Yes 20% on the back 35% on the sides. Keeping everything legal in Ontario. Unless you are going to track the car or for personal preference, stock height is great. The tire size is 225 40 18 offset is +35 in case I didn't post that. A little stretched and the ride is smoother than the winters I had on it. Good luck with your decision. It is by the far the toughest I had to make regarding the car.
Old 03-30-2013, 10:41 PM   #25
forzajuve
Still looks good though. The more I am seeing everyone's stock height + 18's it actually looks pretty good since the car naturally sits pretty low as is. You can still get away with it and it still does not look unproportioned
Old 03-30-2013, 10:44 PM   #26
forzajuve
Thank you sir! I agree with it being a difficult decision. I am more than likely going to sit on it, keep looking at literally every picture I can, and then hopefully make a confident decision in the next month or two. In the mean time I might be upgrading my intake filter + tube as well as lower it using the eibach pro kit.
Old 03-30-2013, 10:51 PM   #27
FRSGT86
FRSGT86's Avatar
Thanks! I think what bugged me more with the stock wheels than the wheel gap was the sucked in look they had, especially the rears.
Now that that's gone, the gap is allot easier to live with until I can figure how how to lower it, springs or coilovers, and how much drop. Looks awesome with 1.5 inch or more drop, but I just don't want to mess up the already almost perfect handling characteristics it already has. I'd like to see and ride in a couple with both to compare the difference between the two.
Old 03-30-2013, 11:48 PM   #28
Pbrown
Sounds like
A good starting point for sure. Good luck.
Anybody got 16 inch wheels on their FR-S /BRZ? Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 734 04-27-2022 06:11 PM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Can i drop my car an inch or more and then raise it back to stock height? ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-01-2012 09:02 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
