Old 03-30-2013, 11:33 AM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
turbo kit supporting mods
so im compiling a list of things needed with a turbo kit so that when i go shop nothing gets left out, but not sure exactly what supporting mods are needed at ~290 WHP
right now i no:
1. fuel pump
2. 550cc injectors
3.clutch
the 1st two of which come with the kit. am i missing anything else (brakes will come in time anyway). just don't want to run into any surprises from sheer ignorance
lbroskee is offline   Reply With Quote
Old 03-30-2013, 11:53 AM   #2
jamesm
i'd do 900cc+ injectors and a 4 bar map if you plan on using E85. other than that those seem to be all we really need. i'm not even entirely convinced you'd need a clutch at 290whp (would depend on the torque). i suspect they'll do a bit better on the street around that power level than they have been showing on the dyno. i'm going to test it once my kit is installed and see how long my oem clutch actually lasts in real world driving at ~230wtq.
Old 03-30-2013, 12:19 PM   #3
lbroskee
lbroskee's Avatar
im going 93 octane since i've never seen an E85 station in my area, but ya the clutch would b after a dyno, and if im at ~225WTQ im swapping it out b/c being right on the edge like that is just asking for trouble.
what is the difference between the 4 bar map and OEM? tried google and got nothing but shopping links
Old 03-30-2013, 12:19 PM   #4
SilentAngel
Guest
Posts: n/a
I really don't know to much about FI, but i always heard getting a better/bigger Intercooler and a free'er flowing exhaust were good mod's when going FI. Maybe even Cold Air Intakes?
Old 03-30-2013, 12:22 PM   #5
lbroskee
lbroskee's Avatar
well the kit comes with an intercooler (car doesnt have 1 OEM so already better lol).
exhaust is complete (forgot to mention that) minus the manifold of course since the kits come with those
and the way these turbo kits are setup most CAI out now arent compatible (so my current CAI will b a waste)
The Following User Says Thank You to lbroskee For This Useful Post:
Old 03-30-2013, 12:24 PM   #6
jamesm
the 4 bar map sensor is (i believe) necessary to run the higher boost associated with e85. the stock one maxes out at some psi level.
The Following User Says Thank You to jamesm For This Useful Post:
lbroskee (03-30-2013)
Old 03-30-2013, 01:39 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Depending on the kit, I think you have everything covered.
Oh yeah, something to wipe the goofy grin off your face the first time you drive it, lol!
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
Old 03-30-2013, 01:43 PM   #8
lbroskee
lbroskee's Avatar
ok cool
screw that! if Jeremy Clarkson can rock it then no need to hide it lol
Old 03-30-2013, 01:54 PM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Gauges
Old 03-30-2013, 02:05 PM   #10
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Originally Posted by whitefrs View Post
Gauges
+1 on this!
Old 03-30-2013, 02:24 PM   #11
Dipstik-sportech
Dipstik-sportech's Avatar
Tires, cause you'll burn through the stockers quite quickly lol
Old 03-30-2013, 02:50 PM   #12
lbroskee
lbroskee's Avatar
gauges of course once all the requirements to drive smoothly
tires and wheels already upgrades pzero nero 235,40,18r on 18x8.75 XXR 530
also was lookin at this stoptech upgrade since i dont plan to go insane enough to need a big brake kit
http://ft86speedfactory.com/stoptech...grade-216.html
Old 03-30-2013, 03:46 PM   #13
Xdragonxb0i
Drives: ex500r
Perhaps oil cooler and radiator?
Xdragonxb0i is offline   Reply With Quote
Old 03-30-2013, 08:56 PM   #14
86pro
Drives: frs
First off you need an oil catch can. Then and oil cooler. Turbo timer if your new to how turbo works, definitely a boost gauge and you should be good after your mods you listed. Radiator not really but it all depends im runnin stock one and i heard other are too.
86pro is offline   Reply With Quote
Safely Jacking and Supporting Your BRZ/FR-S GrimmSpeed DIY (Do-It-Yourself) Guides 152 06-11-2021 07:44 AM
Supporting Mods For F/I Applications Tansey86 Forced Induction 59 02-26-2013 01:42 AM
NA engine mods for turbo money? subatoy Engine, Exhaust, Transmission 62 11-28-2012 04:32 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
