Mounting HID Ballasts?
Hey guys, been toying with the idea to install some HID's but wanted opinions or hopefully testimonials on where and how you have seen the ballasts mounted. All the videos I watch are pretty sketchy installs. Any help would be appreciated
#2 |
Just drive it
Drives: 13' FR-S
On passenger side, you can mount it on top of the frame bar.
On driver side, you can just mount it where wheel liner meets the body. It's around the abs sensor area. Anywhere flat is fine. |
#3 |
Custom User Title
Drives: Asphalt FR-S MT
There is a small frame section under but slightly behind each headlight. I used strong double sided tape and mounted them there.
#4 |
Drives: 2020 BRZ tS #54
Installed mine under the lights on the frame..
Yeah my other ballast blew now I have 2 different ones also zip tied it down and put a foam under the ballast to absorb vibrations..On driver side take the windshield funnel out and unclip a harness to have room to work when installing on that side..other side is easy no need to take out stuff just drops in ![]()
#5 |
Drives: 2024 MT Toyota GR86
^ What I did, works great, just some advice, use heavy duty 3M double adhesive.
2024 Toyota GR86
2013 Scion FR-S |
#6 | |
Yeah maybe I need the heavy duty tape.. Not sure how just alone the tape would do when summer hits.. Tape might unstick due to heat idk.. But mine not going come off for sure
#7 | |
But of course you don't need to worry about that now.
2024 Toyota GR86
2013 Scion FR-S |
#8 |
shoved my ballast between the plastic fender liner and the metal fender so its pinched and doesnt move ha
FR-S Journal: http://www.ft86club.com/forums/showt...77#post1030877
#9 | |
Drives: 2013 86 white
#10 |
Drives: 13 Firestorm FRS
I stuck mine on the inner side of the fender. Just partially drop the fender liner, and feed the ballast through.
Super clean install. |
#11 | |
get 2 zip ties connect them together then bend one side like a "U" shape or hook and just loop it under the frame.. The driver side is a bit tricky to get due to the windshield washer container on the bottom.. Just pop out the tube funnel first and the harnesses wire next to it.. Other side is easy
#12 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#13 | |
Will alcohol hurt the clear coat ? Not sure if I will use alcohol when I mount my TRD wing..might use drinking water to clean it..
#14 | |
Drives: 2013 Whiteout Scion FR-S 6MT
| Mounting a Fire Extinguisher | Xauterus | AUSTRALIA | 37 | 05-21-2017 05:15 PM |
| Mounting a radar detector | Bg8780 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 02-06-2014 12:39 PM |
| Radiator Mounting and Cap | SupremeGunman | Engine, Exhaust, Transmission | 7 | 04-30-2012 05:16 PM |
| where are you mounting your plates??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-31-2012 04:41 AM |
