Old 03-26-2013, 11:53 AM   #1
mmieszanek
mmieszanek's Avatar
Mounting HID Ballasts?
Hey guys, been toying with the idea to install some HID's but wanted opinions or hopefully testimonials on where and how you have seen the ballasts mounted. All the videos I watch are pretty sketchy installs. Any help would be appreciated
mmieszanek is offline   Reply With Quote
Old 03-26-2013, 12:07 PM   #2
frslee
Just drive it
Drives: 13' FR-S
On passenger side, you can mount it on top of the frame bar.
On driver side, you can just mount it where wheel liner meets the body. It's around the abs sensor area. Anywhere flat is fine.
frslee is offline   Reply With Quote
Old 03-26-2013, 12:26 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
There is a small frame section under but slightly behind each headlight. I used strong double sided tape and mounted them there.
Old 03-26-2013, 01:55 PM   #4
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Installed mine under the lights on the frame..
Yeah my other ballast blew now I have 2 different ones also zip tied it down and put a foam under the ballast to absorb vibrations..
On driver side take the windshield funnel out and unclip a harness to have room to work when installing on that side..other side is easy no need to take out stuff just drops in
The Following 2 Users Say Thank You to marky For This Useful Post:
FRS_Ken (03-27-2013), illicitstylz (07-07-2014)
Old 03-26-2013, 01:59 PM   #5
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
^ What I did, works great, just some advice, use heavy duty 3M double adhesive.
2024 Toyota GR86
2013 Scion FR-S
briang0901 is offline   Reply With Quote
Old 03-26-2013, 02:07 PM   #6
marky
marky's Avatar
Yeah I tried it only with tape but came off after a while due to dust/dirt build up after driving it.. So I mounted it with the brackets and zip tied it down because the bracket would just have it like hanging/flopping around..
Yeah maybe I need the heavy duty tape.. Not sure how just alone the tape would do when summer hits.. Tape might unstick due to heat idk.. But mine not going come off for sure
Old 03-26-2013, 03:12 PM   #7
briang0901
briang0901's Avatar
I bought mine in Oct, put the 3M adhesive on and havent had an issue yet. I do check regularly but haven't seen any issues yet. 3M tape is strong!
But of course you don't need to worry about that now.
2024 Toyota GR86
2013 Scion FR-S
Old 03-26-2013, 03:21 PM   #8
Timtamtt
Timtamtt's Avatar
shoved my ballast between the plastic fender liner and the metal fender so its pinched and doesnt move ha
Timtamtt is offline   Reply With Quote
Old 03-27-2013, 03:23 AM   #9
TRD_86
Drives: 2013 86 white
This look great. How did you find room to work with your hands in there? I couldn't find room to get my hands to do the zip tied !
TRD_86 is offline   Reply With Quote
Old 03-27-2013, 10:56 AM   #10
truenosan
truenosan's Avatar
Drives: 13 Firestorm FRS
I stuck mine on the inner side of the fender. Just partially drop the fender liner, and feed the ballast through.
Super clean install.
truenosan is offline   Reply With Quote
Old 03-27-2013, 11:04 AM   #11
marky
marky's Avatar
Thanks.. Do what I did improvise get 2 zip ties connect them together then bend one side like a "U" shape or hook and just loop it under the frame.. The driver side is a bit tricky to get due to the windshield washer container on the bottom.. Just pop out the tube funnel first and the harnesses wire next to it.. Other side is easy
Old 03-27-2013, 01:46 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The heavy duty 3m is what holds on a lot of lip spoilers, so I don't think heat is an issue. Also you really need to clean where you applying it with rubbing alcohol before setting it.
Old 03-27-2013, 01:54 PM   #13
marky
marky's Avatar
Yup clean with alcohol.. The stock double tape came with my ballast are cheap and didn't want to drive/buy aka lazy so I just secured it for sure Lol.. Yeah your right they use heavy duty tape on spoilers .. Looking to get the TRD spoiler and that uses 3M tape..
Will alcohol hurt the clear coat ? Not sure if I will use alcohol when I mount my TRD wing..might use drinking water to clean it..
The Following User Says Thank You to marky For This Useful Post:
finch1750 (03-27-2013)
Old 03-27-2013, 02:07 PM   #14
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
I've used rubbing alcohol when plasti dipping emblems and I apply it, rub it with water, then dry. Didn't do any damage.
husker741 is offline   Reply With Quote
Mounting a Fire Extinguisher Xauterus AUSTRALIA 37 05-21-2017 06:15 PM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 01:39 PM
Radiator Mounting and Cap SupremeGunman Engine, Exhaust, Transmission 7 04-30-2012 06:16 PM
where are you mounting your plates??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 28 01-31-2012 05:41 AM
