Old 02-13-2013, 01:42 PM   #29
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by bluesubie View Post
A nominate you to do a uoa every 1,000 miles, for a range of different muti-viscosity oils, to see if the viscosity changes. .
-Dennis
I'll leave that to you newby enthusiasts as a learning exercise. I've probably forgotten about more UOA's than most of you will ever see!
smbrm is offline   Reply With Quote
Old 02-13-2013, 01:53 PM   #30
jdmasfcuk
jdmasfcuk's Avatar
Drives: Toyota 86 ZN6
jdmasfcuk is offline   Reply With Quote
The Following User Says Thank You to jdmasfcuk For This Useful Post:
Chad86 (11-08-2015)
Old 03-22-2013, 02:05 PM   #31
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
i run 0W-30
BoostedWrbBrz is offline   Reply With Quote
Old 03-22-2013, 05:00 PM   #32
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by ayau View Post
Someone needs to verify this but...
I believe 0w-20 and 0w-30 will still have different room temperature viscositities. 0w-20 should be thinner at room temperature, therefore, will be "better" for your engine at startup.
Bobistheoilguy.com stresses that no matter what oil you put into your engine, it's still too thick at room temperature.
I think it's safe to assume that Subaru has the most knowledge about their own engine. If they recommend 0w-20, then you should stick to that under normal driving conditions. The only exception would be if your oil temperature runs very hot due to tracking the car (very low population), then you may want to consider 5w-30 to reduce shearing.
correct, ALL oil is too viscous at ambient temperature. 0-20 does have a lower VI than 0-30, but he also stressed that the weight of oil used should be dependent upon pressure and flow and that, essentially, at racing temperatures, all oil has the same viscosity.
if an oil pump only allows 50 psi max and both the 0-20 and 0-30 flow 50 psi at 7000 rpm, the 0-20 should have a higher flow rate and cool more effectively because of the lower viscosity.
his entire education series was really insightful. I would love to be in a position to test flow rates and viscosities for myself.
supramkivtt2jz is offline   Reply With Quote
Old 03-25-2013, 05:38 PM   #33
Big-B
Drives: 2013 Scion FR-S Ultramarine
2013 Toyota Pro / Celebrity Scion FR-S Specifications
ENGINE
Type 4-cylinder, boxer type, 16-valve DOHC with Variable Valve Timing Control
Displacement 2.0L (121.9 Cu. In.)
Power 210 hp @ 7000 rpm
Induction Fuel Injection D-4S (Direct and Port Injection System) TRD Performance Air Intake
Bore X Stroke 86.0 mm X 86.0mm
Compression Ratio 12.5:1
Fuel F&L racing fuel 100 octane unleaded
Exhaust TRD stainless-steel exhaust
Motor Oil Redline 0W20 synthetic
Toyota is using 0W-20 in their track car, I would trust them on this decision.
Big-B is offline   Reply With Quote
Old 03-25-2013, 05:46 PM   #34
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I think it's safe to assume that Subaru has the most knowledge about their own engine. If they recommend 0w-20, then you should stick to that under normal driving conditions. The only exception would be if your oil temperature runs very hot due to tracking the car (very low population), then you may want to consider 0w-30 to reduce shearing.
dude,
youre making too much sense and I could not agree with you more,
fixed the post above, Not sure there is a case for a thicker startup viscosity
thank you btw for your posts, love them all
I run may run a 50/50 mix of 0w20 and 0w30 just to benefit a slightly better HTHS when temps are over 100F ambient
I see no reason to go to a 5W, if a 0w-30 offers similar chemistry
Huehuecoyotl is offline   Reply With Quote
Old 03-25-2013, 06:15 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Huehuecoyotl View Post
dude,
Simple, because 0W-30 isn't offered in your preferred synth oil but 5W-30 is
For a track car I wouldn't touch 0W-20 after the pressure readings I had. Currently using 5W-30. I've been toying with the idea of setting up a pre-oiling system, but I'm lazy so I probably won't.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Chad86 (11-08-2015), tumbla.jr (01-17-2016)
Old 03-25-2013, 06:36 PM   #36
Huehuecoyotl
Thanks, great feedback D-ror
I've been on the factory stuff, and sustina on the 0w20, seems like some of the better 0w20 out there
aside from my preferred German castrol 0w30(I could be wrong but I thought this was a group3/4mixed synth but I could be wrong havent read up on it in a while), what flavor of synth 5w30 are you pouring into yours?
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Chad86 (11-08-2015)
Old 03-25-2013, 06:46 PM   #37
mswhong
Drives: FT86
If you guys are worried about 5w-30 being too viscous at low engine temps.. why not warm your engine up before driving off? I mean, isn't that what most people do on cold days?
mswhong is offline   Reply With Quote
The Following User Says Thank You to mswhong For This Useful Post:
Chad86 (11-08-2015)
Old 03-25-2013, 07:05 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Currently M1/RP, trying to locate a local supply of Motul 300V to test with. I can easily get Amsoil and use to long ago, I want to do some UOAs with a few different oils.. goes back to that lazy thing though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2013, 07:11 PM   #39
reeves
Indeed, Amsoil lists their 0w-30 with a different viscosity then their 0w-20 at 40 degrees Celcius..
At what oil temps is it considered "very hot"? Cruising at ~85mph, I notice my oil temps hovering around 220 degrees Fahrenheit (according to Torque Pro app).. wondering if that's enough to use 0w-30 on those trips.?
Old 03-25-2013, 10:42 PM   #40
Huehuecoyotl
thicker oil wil make you run hotter...
tCsonfrs (01-20-2017)
Old 03-26-2013, 04:07 PM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I personally wouldn't worry about 220 degrees...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
reeves (03-26-2013)
Old 12-08-2016, 02:21 AM   #42
WWFT86
Drives: 2017 BRZ Limited
Check out this link from Subaru Japan's website. Some Google translate may be needed if you don't read Japanese
http://www.subaru.jp/accessory/engine_oil/engine_oil/
and out of all these options it seems this 0W-30 is the bet all-around (e.g. cold weather starts, high temperature engine protection, bumper to bumper stop and go traffic), and lists BRZ specifically listed as a suitable car:
http://www.subaru.jp/accessory/engin...miumoil01.html
WWFT86 is offline   Reply With Quote
Safe to use DOT 5.1? mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-27-2015 04:32 AM
Be Safe! Mr. J BRZ First-Gen (2012+) — General Topics 21 11-21-2012 06:46 PM
Safe at the Dealership? BP1913 BRZ First-Gen (2012+) — General Topics 19 06-18-2012 05:52 PM
Safe to wax new car paint? Nitro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-09-2012 02:08 AM
