Old 02-08-2013, 01:49 PM   #15
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
[quote=ayau;721205]
Originally Posted by Xdragonxb0i View Post
You should be using thinner oil if your car engine isn't reaching normal operating temperature. As oil heats up, it becomes thinner. When it's cold, it's thicker. This means there won't be enough lubrication for the engine.
Said it before I could. I do lots of short commutes and am glad 0 weight oil is doing its job as soon as possible. Agreed, heavier oil for short commuted is a mistake.
Ocala FR-S is offline   Reply With Quote
Old 02-08-2013, 01:53 PM   #16
ayau
Drives: Some rust bucket
Originally Posted by Tt3Sheppard View Post
0w20 for winter 5w30 for summer
No. Stick with 0w-20 unless you heavily track your car.
Old 02-08-2013, 01:55 PM   #17
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
its almost as if the engineers knew what they were talking about...
driftartist is offline   Reply With Quote
The Following 3 Users Say Thank You to driftartist For This Useful Post:
flippy (02-08-2013), Sportsguy83 (02-10-2013), Tart (08-29-2016)
Old 02-08-2013, 02:22 PM   #18
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
ok. ow-20 is!!
Old 02-08-2013, 02:51 PM   #19
Hanakuso
Could you mix them together? Say 1-5 bottles of 0W20 1-5 bottles of 5W30. So a total of 6 or whatever the recommended amount is.
Hanakuso is offline   Reply With Quote
Old 02-08-2013, 03:40 PM   #20
GNS
Drives: .
Aren't there any 0W-30 synth oils out there? Then you get the 0 weight for cold start ups, and 30 weight at operating temps.
GNS is offline   Reply With Quote
Old 02-08-2013, 05:43 PM   #21
ayau
Not sure what your goal would be to mix the different oils. I believe the owners manual recommends you to use the same oil unless you can't find the same weight oil.
Old 02-08-2013, 05:45 PM   #22
ayau
Someone needs to verify this but...
I believe 0w-20 and 0w-30 will still have different room temperature viscositities. 0w-20 should be thinner at room temperature, therefore, will be "better" for your engine at startup.
Bobistheoilguy.com stresses that no matter what oil you put into your engine, it's still too thick at room temperature.
I think it's safe to assume that Subaru has the most knowledge about their own engine. If they recommend 0w-20, then you should stick to that under normal driving conditions. The only exception would be if your oil temperature runs very hot due to tracking the car (very low population), then you may want to consider 5w-30 to reduce shearing.
The Following User Says Thank You to ayau For This Useful Post:
Huehuecoyotl (03-25-2013)
Old 02-08-2013, 05:47 PM   #23
Hanakuso
Just thought it would be a balance/compromise between the two oil weights.
Old 02-09-2013, 08:09 PM   #24
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Originally Posted by Ryan86 View Post
Toyota South Africa have specified fully synthetic Diesel engine oil, 5w30 for our climate.
Is that in the owners manual? I wonder what is called for in the Arab states?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 02-09-2013, 09:38 PM   #25
Porsche
Drives: 2013 BRZ Ltd. MT
Temperatures are comparable to much of North America, ranging from 70-90 deg F typically during the warmer months of the year.
The difference in oil spec is, I suspect, due to less government interference, and fewer eco-maniacs, and Tree Huggers. This permits the engineers to specify the more suitable oil weight, not needing to live up to any fuel economy constraints. They’re more free to spec the oil that protects the engine BEST.
Porsche is offline   Reply With Quote
Old 02-12-2013, 10:52 AM   #26
bluesubie
Drives: 2004 Subaru Forester 2.5XT
In severe conditions, most 5W-30's (low High Temp High Shear/Resource Conserving) will actually shear more than a 5W-20 because the 5W-30 will have more viscosity modifiers. You can find 5W-30 uoa's where the viscosity has sheared to a lower viscosity than some 5W-20's.
A 5W-20 can also have less evaporation loss than most 5W-30's (measured by NOACK volatility).
-Dennis
bluesubie is offline   Reply With Quote
Old 02-12-2013, 12:00 PM   #27
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
-Dennis
Dennis makes valid points(generally speaking). However you also need to be aware that not all viscosity modifiers have the same shear characteristics. In the arsenal of components formulators do have options regarding the types of viscosity modifiers from which they can potentially select depending on product design performance criteria. However the important part is the overall performance the product delivers not whether component A or B is used.
smbrm is offline   Reply With Quote
Old 02-13-2013, 09:35 AM   #28
bluesubie
Good point about different shear characteristics. There have been a few uoa's in WRX's over the past year where Resource Conserving oil held up fine for 7k+ mile intervals (maybe improvements due to the GF5 spec). Of course, there's also the possibility of thinning down and thickening back up again.
A nominate you to do a uoa every 1,000 miles, for a range of different muti-viscosity oils, to see if the viscosity changes. .
-Dennis
Safe to use DOT 5.1? mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-27-2015 04:32 AM
Be Safe! Mr. J BRZ First-Gen (2012+) — General Topics 21 11-21-2012 06:46 PM
Safe at the Dealership? BP1913 BRZ First-Gen (2012+) — General Topics 19 06-18-2012 05:52 PM
Safe to wax new car paint? Nitro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-09-2012 02:08 AM
