Drives: acura integra..brother owns FRS
Safe to run 5w-30 oil?
Hey guys about to do an oil change tommarow I'm wondering if there is any reason I can't run 8w-30 instead of the o-20 it calls for thanks let me know
Long Distance Driver
A reason why you cant? Because Thread:
http://www.ft86club.com/forums/showthread.php?t=7443 I HOPE this helps. Good luck.
Drives: 2013 BRZ Ltd. MT
Yes. It’s what I used at my first oil change, and what I’ll likely use for the duration of my ownership. The Subaru Owner’s Manual RECOMMENDS a heavier oil for harder use. “An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.” (Higher in this case means heavier than 0w-20.) The original factory fill is synthetic and Subaru calls for synthetic oils. |
| The Following User Says Thank You to Porsche For This Useful Post: | Chad86 (11-08-2015) |
Drives: Whiteout FR-S
Well I guess the question is answered. All those oil threads discuss different oils but none of them actually have a real answer/confirmed chart of safe to use oil weights
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
ok thanks guys appreciate it
#6 | |
Drives: .
IMO, the 20 weight oils are only there for CAFE requirements, and not necessarily for the protection of your engine. |
Drives: ex500r
[QUOTE=zc06_kisstherain;721183]i am still undecided whether i should use stick with 0w-20 or 5w-30[/Qoute]]
Same here, I think I fall under severe abuse. I take my car on really short trips less then 5 miles. Most of the time the engine isn't even warm when I turn it off |
Drives: Some rust bucket
Stick to the lower viscosity oil (0w-20). Initial startup is what kills the engine because the oil is too thick. This is especially true in the colder states.
I wouldn't switch to 5w-30 unless you track the car heavily. http://www.bobistheoilguy.com/motor-oil-101/ |
| The Following 2 Users Say Thank You to ayau For This Useful Post: | Huehuecoyotl (03-25-2013), SXE10 (03-23-2013) |
#10 |
well probably run 5-30
#11 |
[quote=Xdragonxb0i;721196]You should be using thinner oil if your car engine isn't reaching normal operating temperature. As oil heats up, it becomes thinner. When it's cold, it's thicker. This means there won't be enough lubrication for the engine.
#12 |
Drives: '23 BRZ
If you are in a warm environment and spend time in bumper-to-bumper traffic, or if you track the car, you *might* consider 5W30 synthetic as mitigation against high oil temps. Otherwise, no reason to deviate from factory spec.
#13 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Toyota South Africa have specified fully synthetic Diesel engine oil, 5w30 for our climate.
#14 |
0w20 for winter 5w30 for summer
2013 Ford Focus St
| The Following User Says Thank You to Tt3Sheppard For This Useful Post: | OMEN (03-15-2018) |
| Safe to use DOT 5.1? | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-27-2015 03:32 AM |
| Be Safe! | Mr. J | BRZ First-Gen (2012+) — General Topics | 21 | 11-21-2012 05:46 PM |
| Safe at the Dealership? | BP1913 | BRZ First-Gen (2012+) — General Topics | 19 | 06-18-2012 04:52 PM |
| Safe to wax new car paint? | Nitro | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 06-09-2012 01:08 AM |
