Old 03-22-2013, 11:31 AM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
vortech supercharger & clutch & cooling?
alright so i'm hearing that you need to worry about coolant temps, oil temps, and need a 6 puck clutch to have the vortech because the stock will run out in a month. true? input on all of this please.
ft86me is offline   Reply With Quote
Old 03-22-2013, 11:34 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Who is saying that/ where are you hearing that?
Old 03-22-2013, 11:37 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
someone that happens to know someone..apparently he says he needs a 6 puck clutch because it burnt through oe in a month and he needed to upgrade water cooling and needed an oil cooler annnnnd even said its not good for daily driving.
Old 03-22-2013, 11:38 AM   #4
Sportsguy83
Drives: Limited BRZ
The only thing I can say is a 6 puck is overkill, there are daily driver friendly alternatives that are way better than a 6 puck clutch.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 11:40 AM   #5
dabocx
dabocx's Avatar
Drives: Scion FRS
This is going to depend alot on how you drive the car, there a quite a few people on here with the vortech kit some with higher psi versions without any of these problems.
If your going to do heavy/hard track work you might need a oil cooler or at least get one to be safe.
Clutch is going to depend on how you drive it, the vortech kits dont have alot of torque so you should not have any problems for a long time. You could get one at the same time as a lightweight flywheel to be safe, though there are alot of diff types and some might be more friendly for DD
dabocx is offline   Reply With Quote
The Following User Says Thank You to dabocx For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 11:44 AM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
my thoughts exactly. i didn't think this is a true statement because why would vortech even release something like that and not mention it. i haven't heard of such thing so far either. visconti didn't mention such a thing either and he is really on top of his shit.
the clutch deal i can understand about the driving deal. i don't drive like a bat out of hell but do give it some love at times but that's just a simple pull from a rolling in like third.
i'm not going to be tracking the car btw. just daily with some spirited driving when i feel like opening it up some.
what do you guys think?
Old 03-22-2013, 11:49 AM   #7
Sportsguy83
Drives: Limited BRZ
I'd say eventually you will need a clutch, but it will definitely not be right away, and most definitely it will never be a 6 puck.
Old 03-22-2013, 12:11 PM   #8
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I love 6 pluck's makes traffic easier!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
Sportsguy83 (03-22-2013)
Old 03-22-2013, 02:02 PM   #9
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I'd recommend an oil cooler, but for sure it will run fine on the stock coolant system and clutch.
If the clutch dies, replace it with a stage 1 or stage 2 clutch and you'll be fine!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 02:18 PM   #10
ft86me
ft86me's Avatar
Drives: 2013 FRS
oil cooling for even basic daily driving? i wont be tracking this car.maybe some pulls or couple corners but nothing crazy
Old 03-22-2013, 02:27 PM   #11
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Agree 100%
I'm not in a hurry to replace mine, and it drives fine 90% but when I am pushing it past 9/10, you do smell a lil clutch if I am not gentle on the shifts, but I'm modded. Burn a clutch in a month? really?
Just a lil smell. No, not the end of the day, but I dont know that its a pre-requisite, nor is an oil cooler, but nice to have if you plan to run it hard and want to enjoy lower oil temps. I will keep you all posted on my clutch.
I have no need to replace my radiator, you can bolt the SC on stock and go, no ill happens.
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 02:31 PM   #12
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Yes, with the S/C a lot more stress is put on the engine with a lot more load.
PERRIN_Mladen is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 02:34 PM   #13
2forme
Originally Posted by PERRIN_Mladen View Post
Yes, with the S/C a lot more stress is put on the engine with a lot more load. The kit also uses a thin oil which is another contributing factor that brings up oil temperatures.
What does the oil of the kit have to do with the oil in the motor?
Old 03-22-2013, 02:34 PM   #14
ft_sjo
Drives: GT86
6 puck disc is fine with the RIGHT COVER. E.g. not one that comes in a kit. Try the OEM cover.
Vortech Supercharger or AVO Turbo HillCountryGuru Forced Induction 48 04-11-2014 09:19 PM
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
Vortech supercharger skatery1989 Forced Induction 293 04-19-2013 04:58 PM
Vortech supercharger. skatery1989 Engine, Exhaust, Bolt-Ons 2 02-23-2013 07:19 AM
Vortech Supercharger FRS/BRZ vividracing Forced Induction 5 01-29-2013 07:03 PM
