Drives: 2013 FRS
vortech supercharger & clutch & cooling?
alright so i'm hearing that you need to worry about coolant temps, oil temps, and need a 6 puck clutch to have the vortech because the stock will run out in a month. true? input on all of this please.
#2 |
I Love custom Turbo kits
Drives: Limited BRZ
Who is saying that/ where are you hearing that?
#3 |
Drives: 2013 FRS
someone that happens to know someone..apparently he says he needs a 6 puck clutch because it burnt through oe in a month and he needed to upgrade water cooling and needed an oil cooler annnnnd even said its not good for daily driving. Last edited by ft86me; 03-23-2013 at 07:49 PM. |
#4 |
Drives: Limited BRZ
The only thing I can say is a 6 puck is overkill, there are daily driver friendly alternatives that are way better than a 6 puck clutch.
#5 |
Drives: Scion FRS
This is going to depend alot on how you drive the car, there a quite a few people on here with the vortech kit some with higher psi versions without any of these problems.
If your going to do heavy/hard track work you might need a oil cooler or at least get one to be safe. Clutch is going to depend on how you drive it, the vortech kits dont have alot of torque so you should not have any problems for a long time. You could get one at the same time as a lightweight flywheel to be safe, though there are alot of diff types and some might be more friendly for DD |
#6 | ||
Drives: 2013 FRS
the clutch deal i can understand about the driving deal. i don't drive like a bat out of hell but do give it some love at times but that's just a simple pull from a rolling in like third. i'm not going to be tracking the car btw. just daily with some spirited driving when i feel like opening it up some. what do you guys think? |
#7 | |
Drives: Limited BRZ
#8 |
Reverse Burnouts
Drives: 2013 Argento FRS
I love 6 pluck's makes traffic easier!
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#9 |
I'd recommend an oil cooler, but for sure it will run fine on the stock coolant system and clutch.
If the clutch dies, replace it with a stage 1 or stage 2 clutch and you'll be fine! |
#10 | |
Drives: 2013 FRS
oil cooling for even basic daily driving? i wont be tracking this car.maybe some pulls or couple corners but nothing crazy |
#11 | |
Drives: Perrin/VORTECH Supercharger TestBRZ
I'm not in a hurry to replace mine, and it drives fine 90% but when I am pushing it past 9/10, you do smell a lil clutch if I am not gentle on the shifts, but I'm modded. Burn a clutch in a month? really? Just a lil smell. No, not the end of the day, but I dont know that its a pre-requisite, nor is an oil cooler, but nice to have if you plan to run it hard and want to enjoy lower oil temps. I will keep you all posted on my clutch. I have no need to replace my radiator, you can bolt the SC on stock and go, no ill happens. |
#12 |
Drives: '11 535i
Yes, with the S/C a lot more stress is put on the engine with a lot more load.
#13 |
#14 |
Drives: GT86
6 puck disc is fine with the RIGHT COVER. E.g. not one that comes in a kit. Try the OEM cover.
| Vortech Supercharger or AVO Turbo | HillCountryGuru | Forced Induction | 48 | 04-11-2014 09:19 PM |
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 06:48 PM |
| Vortech supercharger | skatery1989 | Forced Induction | 293 | 04-19-2013 04:58 PM |
| Vortech supercharger. | skatery1989 | Engine, Exhaust, Bolt-Ons | 2 | 02-23-2013 07:19 AM |
| Vortech Supercharger FRS/BRZ | vividracing | Forced Induction | 5 | 01-29-2013 07:03 PM |
