Old 03-21-2013, 10:59 AM   #155
bpracer
Drives: Asphalt FR-S
Originally Posted by Chillz View Post
Have you confirmed that the BRZ premium stalk doesn't have the "auto" switch?
I'm going by what somebody else posted. If true great, if not, well, it should still work. I'll know next week.
Product Name: BRZ WIPER STALK FOR PREMIUM MODEL - WITH FOG LIGHT
SWITCH
Item#: 83115FJ070
Unit Price: $60.00
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 03-21-2013, 11:02 AM   #156
Sco2355
Originally Posted by HRTROB View Post
If you do find it, kindly post the part number here thanks!
No doubt, will do!
Sco2355 is offline   Reply With Quote
Old 03-21-2013, 11:42 AM   #157
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
I'll just leave this here.
Originally Posted by nigel-jdmparts View Post
No, you cannot have auto headlights work. Because you don't have the sensor on the FRS.
pascalbrax is offline   Reply With Quote
Old 03-21-2013, 11:50 AM   #158
Sco2355
While true, it can still be done. The FRS does not have the parts, but I do have the part numbers for all the parts needed. After doing this fog install what I decided to do was purchase the correct wiring harness and slowly buy the pieces needed to make it all happen. This way it's PnP.
Old 03-21-2013, 12:34 PM   #159
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Is there a part number for a O.E.M foglight harness?
iketiak is offline   Reply With Quote
Old 03-21-2013, 12:52 PM   #160
Sco2355
No there isn't a separate harness. It's made into the main harness.
Old 03-21-2013, 01:02 PM   #161
iketiak
iketiak's Avatar
I would be very interested in finding out the P/N for the euro stalk as well. will you be doing a revised DIY guide once you get all parts?
Old 03-21-2013, 01:28 PM   #162
Sco2355
Yep.
Old 03-21-2013, 05:01 PM   #163
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Is anyone using the Nigel JDM wiring harness and the BRZ stalk yet??? What's your results??
Willsonk is offline   Reply With Quote
Old 03-21-2013, 05:16 PM   #164
Sco2355
Why would you buy the harness and the stalk?
The Following User Says Thank You to Sco2355 For This Useful Post:
civicdrivr (03-21-2013)
Old 03-21-2013, 05:20 PM   #165
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm not a wiring wizard, but I believe this is exactly what has been discussed in this thread over the past few days. Nigel's harness is a positive trigger setup, the stalk is a negative trigger setup. Its a waste of money to buy Nigel's harness if you plan on running the stalk since you can build your own harness for a fraction of the cost.
The diagrams have been posted over the past few pages, just get the supplies and run some wires.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-22-2013, 03:09 AM   #166
Willsonk
Sco2355 ....... All the items were ordered before diagrams and all the added info.
Old 03-22-2013, 03:35 AM   #167
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
No problem! Let us know how how your install goes!
So with curiosity i decided to take the button apart so i could see the circuit board. It seems that from looking at it, ground is separate from the other 3 so wouldn't tapping into the white work? Here is a pic of it and a diagram showing where the wires connect for better understanding.
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-22-2013, 04:49 AM   #168
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Nope. As I said earlier, that ground is NOT A SWITCHED GROUND. It's for grounding the light inside the switch.
HRTROB is offline   Reply With Quote
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
