Old 03-19-2013, 10:49 AM   #197
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by mact View Post
I doubt the plastic intake manifold is going to explode, crack, or leak.
Me neither, its holding up quite well.
FullBlown is offline   Reply With Quote
Old 03-19-2013, 01:03 PM   #198
juanmedina
Drives: WRX
I'd be more interested in wear and tear than a blown engine, that seems like more useful data.
lol components should be tested to ultimate failure first then to wear/fatigue etc
juanmedina is offline   Reply With Quote
Old 03-19-2013, 01:21 PM   #199
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
That doesn't make sense. Blowing the engine before seeing what fatigues first isn't the best option since one part can fail causing larger issues, which makes it easy to overlook the first part that truly caused the failure and blame a different part that was only damaged due to the first failure.
I'm still trying to wake up, I really hope that made sense. But basically, colateral damage isn't fun to sift through to figure out the ultimate cause of the damage.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-19-2013, 01:44 PM   #200
juanmedina
Drives: WRX
How are you going to see what fatigue if is not broken? FPM are not noobs to this they should be able to figure out what happen, by looking at the bearings, rods, pistons and crank. They will actually have to test many engines not just one since no two engines are the same, the same goes for other conditions and many other factors.
The Following User Says Thank You to juanmedina For This Useful Post:
_hollywood (03-21-2013)
Old 03-19-2013, 01:46 PM   #201
OrbitalEllipses
Drives: Attitude
How are you going to see what fatigue if is not broken? FPM are not noobs to this they should be able to firure out what happen, by looking at the bearings, rods, pistons and crank.
THE juanmedina? Go back to PPP :-P
Wear won't be seen when the engine blows...only engine components destroying everywhere else will be seen. It would be impossible to ascertain what wear was occurring where and whether it was before or after catastrophic failure. One could only provide a "best" guess; whereas cracking the block before hand could show you all that other wear you're talking about. Loose chunks of liner, piston, bearing, and valves doesn't really help me ascertain anything.
civicdrivr (03-19-2013)
Old 03-19-2013, 01:46 PM   #202
swift996
swift996's Avatar
I'm interested to see how the piston rings, rods, and other components hold up. Along with the head gaskets and valve trains. It's a little more of a pain upgrading those in a boxer layout versus an inline. I'm bullish that the component quality is high enough to handle boost over time but will be watching. I'm between the FMB Stage 1 premium and the Innovate kit. I need DD reliability but more power is a must!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-19-2013, 01:48 PM   #203
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Thank you, that's what I was trying to say in my own special not-so-eloquent way
Parting out HERE
Old 03-19-2013, 01:48 PM   #204
juanmedina
Drives: WRX
What kind of wear you thing you are going to see? bearing wear? piston ring wear? you don't have to take the engine apart to figure that one out. It shouldn't be catastrophic either
Old 03-19-2013, 01:51 PM   #205
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm beginning to think you don't understand the difference between fatigue vs failure.
Parting out HERE
Old 03-19-2013, 01:52 PM   #206
OrbitalEllipses
Drives: Attitude
That's not a wouldn't. Go look at a non-boosted engine failure we recently had on the forums; hole in the piston, valve contact, etc.. No one knows, especially not you, what kind of failure will occur when it does finally occur. Maybe it'll just spin a bearing, maybe it'll spit a piston out of the block. We can take this elsewhere Juan; this is FBM's thread.
Old 03-19-2013, 01:54 PM   #207
juanmedina
Drives: WRX
LOL I do FEA work all day long. Good luck catching that fatigued rod before it breaks....
Old 03-19-2013, 02:34 PM   #208
boead
boead's Avatar
look Max; its got a blower!!
boead is offline   Reply With Quote
Old 03-19-2013, 02:36 PM   #209
sw20kosh
Drives: 2013 Black FR-S
^ Innovate should have used that blower...
Old 03-19-2013, 03:59 PM   #210
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by ft_sjo View Post
You do realise that air flows inside the manifold and not around the outside, right?
you do realize you can scan the inside of a manifold right?
3D printing isn't as primitive as before, you can actually print metal models of your scans now-a-days.... jeeze...
[ame="https://www.youtube.com/watch?v=snOErpOP5Xk"]3D Printer - High Resolution - Homemade - DIY - YouTube[/ame]
simple science really...
Fingers crossed for the manifold! Ive heard plastic manifolds blowing at 25+ psi on most other cars.... who knows though, our intake manifolds are pretty thick and have plenty of regitity
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 05:45 PM
AVO Turbo Kit Stage 2 - work in progress AVOturboworld Forced Induction 202 06-18-2013 01:35 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
