Old 03-16-2013, 03:34 AM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
On the other side of bolt is an indent that shows where the indent is. I faced this backwards facing out so someone doesn't inadvertantly try to use an impact tool and its easy to view the plane of the notch.
Huehuecoyotl is offline   Reply With Quote
Old 03-16-2013, 04:34 AM   #16
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Curious why this rear cam bolt is not more popular for adjusting camber?
OjiGeorge is offline   Reply With Quote
The Following User Says Thank You to OjiGeorge For This Useful Post:
Calum (03-16-2013)
Old 03-16-2013, 06:44 AM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Good question. I can say for myself I want to do more with the rear of the car and made this a moot point. I'm looking to stiffen EVERYTHING up back there, it feels very vague to me. Next I want to keep geometry as close to ideal as possible and I think these will cause more track width change then adjusting from the top. So I'm going with an adjustable bushing in the UCA. You milage may vary.
Old 03-16-2013, 06:55 AM   #18
kanundrum
Drives: 2013 Whiteout FR-S
Nicee
Old 03-16-2013, 09:06 AM   #19
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
As Andrew (@apexaddict) and Sam (@samstrano) figured out, if you have uneven camber side to side in the rear (sounds to be fairly common from the factory), the rear subframe is out of alignment, the subframe attachments are slotted so it can be adjusted from there. You still wont be able to dial in an exact number, but atleast you can correct it if you aren't getting equal amounts per side.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-16-2013, 04:31 PM   #20
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
@digital_assassin well done! i was under the thought that this is the same essential rear suspension set up as the GR sti and i know no one uses such bolts there so the only choices were LCA's or white line bushings...
good to know! how much more camber can you get out of it +/-1?
Jive Turkey is offline   Reply With Quote
Old 03-16-2013, 05:06 PM   #21
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Not sure how much range it truly has. It says +/- 3* but that's unlikely. On my car it took out a full degree so it's at least good for +/- 1*
digital_assassin is offline   Reply With Quote
Old 03-16-2013, 06:00 PM   #22
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
I used a set cusco rear lower control arms. worked perfectly
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
fenixv8 is offline   Reply With Quote
Old 03-16-2013, 06:06 PM   #23
ayau
Drives: Some rust bucket
Adjusting the ride height of the rear will also change camber. The lower you are, the more camber you can get.
Old 03-16-2013, 07:23 PM   #24
VoiD
Drives: 13 WRB BRZ
So TC112 is what i need? I just put on kw v3s and i can see i have too much camber on the back for street use
I read in another thread that TC112s need to be modified to fit. Sent Chris@Perrin a msg
VoiD is offline   Reply With Quote
Old 04-03-2013, 12:09 AM   #25
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
This...?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-03-2013, 12:29 AM   #26
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
why would rear camber be different with just a strut change? what does the rear strut have to do with the camber?
Surok is offline   Reply With Quote
Old 04-03-2013, 09:17 AM   #27
eckoflyte
Drives: Toyota 86 GTS
On compression your wheel travels on an arc gaining more dynamic camber as that corner goes lower, for eg your rear left wheel through a right turn. Lowering the car has a similar effect giving you more static camber.
eckoflyte is offline   Reply With Quote
Old 04-03-2013, 07:29 PM   #28
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by deedzman View Post
i thought there is no stock camber adjustment upfront unless you have camber plate mounts? or am I just stupid lol
OP has KW coilovers, which have slots in the struts, giving some ability to adjust camber. No need for crash bolts or camber plates unless you want more than what you get with the KW struts. It seems like between 2-2.5 is easily attainable with the strut slots alone.
It is the rear that does not have any camber adjustment, without buying some parts, even with the KW coilovers.
neurokinetik is offline   Reply With Quote
Coil springs on OEM shocks Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 01-04-2013 07:22 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 08:27 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 10:07 PM
