Old 03-12-2013, 02:48 AM   #85
Sco2355
Originally Posted by PatGT86 View Post
so, I'm awaiting delivery of my FR-S, browsing DIY planning my future mods...
I have some basic working knowledge of automotive wiring and such, just trying to get this mod figured out in my head.
when I do the fog light mod, I'm going to order up the tundra/corolla stalk, which has been described as a straight swap for the existing stalk.
now, what I need help understanding is: is there a relay/place for a relay hiding somewhere in the engine compartment that I can hook the lamp harness up to when the stalk is installed -or- do I have to pass wires in through the firewall and somehow connect the switch wires from the lamp/relay harness up to the stalk? If it's the second scenario, which/where are the wires that you need to splice into? On an OEM harness near the steering column?
Any clarification (or pics!) will help...
Thanks,
Patrick
Read the first post... I have pictures and even tell you which wire to tap into.
Sco2355 is offline   Reply With Quote
Old 03-12-2013, 02:50 AM   #86
Sco2355
Originally Posted by zoomzoomers View Post
Don't know if this has been aswered already, but here goes.
On US cars you cannot turn on the fogs without the driving lights being on. So no, the fogs do not work independently of the driving lights. I wish they did though.
The way I have mine hooked up I can turn the fogs on independently of the running lights/head lights. The fog light indicator in the dash does not come on unless your headlights are on though.
Old 03-12-2013, 04:17 AM   #87
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
Does the fog light for the brz fit on the bezel of the frs? Iono if its too small to fit on the bezel or not. Just quick question. Sorry
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 03-12-2013, 04:20 AM   #88
Sco2355
Honestly I'm not 100% sure but I believe the OEM BRZ/FRS fogs are the same. So it should fit if they are.
Old 03-12-2013, 05:15 AM   #89
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I wouldn't run it independently like that since you run the risk of discharging your battery if you forget to turn them off, and without any warning chime it's only a matter of time when that happens. Plus you really should be using a relay instead of running it off the stalk
HRTROB is offline   Reply With Quote
Old 03-12-2013, 05:33 AM   #90
Sco2355
I understand what you're saying and I've thought about it. Honestly I'm not concerned with forgetting it. I'm really OCD so I check even when I don't touch the lights at all. And in case it does happen I carry and jump box.
Old 03-12-2013, 10:19 AM   #91
PatGT86
Drives: 2013 Raven Scion FR-S
I don't think the US FR-S comes prewired for fogs - you'll have to wire it in the engine compartment. You only have to pass one wire through the firewall if you're using the stalk, tap it to the white wire (pin 4 if I remember correctly) on the stalk connector. Take note that this is a negative trigger wire
Thanks!
With this info, some learning of how a negative trigger circuit works and the pics from Sco2355's original post, I think I've got it figured out...
I'll try to draw up a diagram and post it for review -- if it's correct, it could help others out too...
PatGT86 is offline   Reply With Quote
Old 03-12-2013, 11:09 AM   #92
PatGT86
how does this look?
Let me know if I need to make any corrections...
Also, assuming we're hooking up a pair of 55w halogen lamps, what relay & fuse amperage should we be using? I can add that info to the diagram if it makes sense to
Old 03-12-2013, 11:18 AM   #93
Sco2355
I am using a 20 amp fuse.
Old 03-12-2013, 08:27 PM   #94
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Thanks PatGT86 ..... I was about to do a diagram. I hope someone adds some input soon.
Willsonk is offline   Reply With Quote
Old 03-12-2013, 10:12 PM   #95
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The diagram PatGT86 posted is the right way to do it
Old 03-12-2013, 11:04 PM   #96
PatGT86
Thanks!
some minor updates:
Old 03-13-2013, 05:11 AM   #97
zooki
Drives: waiting on a 2021...
Just to let you know, wiring it up this way will only let the foglights come on with the low beams. They will NOT come on with the running lights, and they will turn off when you switch to high beams. Just an FYI.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-13-2013, 07:57 AM   #98
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yes I am aware of that. But that is the only way to go for you US guys if you want the fog light indicator in the cluster to light up. Or you can do it the way the OP did it, run it independently in which case you risk forgetting to turn them off.
Fortunately for me, I have a JDM/ECE spec car so fogs come on with running lights and stay on with high beams
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
