| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#141 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Changed my oil at 10065 and sent it in for testing. No idea where that titanium is from.
#143 | |
Drives: 2004 Subaru Forester 2.5XT
Although it's a different lab, this VOA also shows titanium at 2 ppm's. Titanium is used as an anti-wear additive. PU VOA -Dennis Last edited by bluesubie; 03-11-2013 at 05:52 PM. |
| The Following User Says Thank You to bluesubie For This Useful Post: | Mikem53 (04-26-2013) |
#144 |
Drives: LR BRZ Ltd, 06 STi
Thanks for posting up, I updated the first post with your link. The titanium was probably in your oil which I can't say for sure because nobody has run pennzoil on this thread yet. Maybe one of the other guys will know for sure.
#145 | ||
Cone basher
This oil change had 4 different autocross events two of which had co drivers, and 2 - 100+ mile hill country drives through some fun roads running at pretty high rpms. |
#146 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Throwing this in there for science. My 3rd oil change, 2nd gearbox fluid change.
Oil went from Stock -> Amsoil -> Amsoil -> Amsoil Gearbox went from Stock -> Motul Gear 300 -> Amsoil Quote:
#147 |
Drives: Frs
Any thoughts on the gearbox change interval?
I'm at 15.5k and have been waiting for free time to change my diff and gearbox fluid since 7k ... |
#148 | |
I presume that you listed your total oil capacity instead of actually listing how much oil you had to add during the interval. How much did you add? -Dennis |
#149 | |
I'd say change both now, I used Amsoil for tranny and diff though they're different specs for each. |
#150 | |
Photo Specialist
![]() The BRZed shop manual says to add 5.7 US qts to the engine when replacing the oil and filter. It seems like an amazing amount
#151 | ||
Did you have to add any between changes? -Dennis |
#152 | |
Drives: Altezza RS200-Z 6MT
Those of us who replace the factory fill with something better like Redline MT-90, Motul 300 gear etc etc should be able to extend that easily. Diff oil is every 30K. There's nothing stopping you dropping it early & replacing with something from Redline, Amsoil or Motul. |
#153 | |
Photo Specialist
Good news then. I didn't add any oil between the oil change interval.
#154 |
Drives: Ion Redline
edit: I got most of the info I was looking for.
What I'm still trying to figure out, is if a failsafe way to determine the difference (from the bottle itself) between the Scooby SM and SN formulations was ever discovered?
"Bullshit, asshole! No one likes the tuna here!"
![]() Last edited by KSC; 03-13-2013 at 01:19 PM. |
| DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
| First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
| When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
| Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 76 | 04-15-2012 04:44 AM |
