Old 03-04-2013, 06:12 PM   #911
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by DeepDish View Post
How i can get 5x120 bolt pattern wheels onto an frs/brz which have 5x100 pattern. if anyone has ever done it or know how it can be done, please let me know thanks in advance
you'd have to do a hub conversion. or run spacers that have a different bolt pattern. i'm not sure that anyone makes those for 5x120 though could be wrong.
FreshFRS is offline   Reply With Quote
Old 03-05-2013, 04:17 PM   #912
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
i want to get 18s as wide as possible on stock suspension with a meaty tire 18x9s a viable route for a square setup?? want to have a concave look
eddieEndo is offline   Reply With Quote
Old 03-06-2013, 08:27 AM   #913
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Originally Posted by whitefrs View Post
Yes
I take it you have this fitted on your car or someones you know?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 03-06-2013, 09:48 PM   #914
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Same here. Looking at an 18x9 +35 with a 245/35R18 should fit okay on stock suspension? Not sure I could fit a 255 in there without a drop and decent camber.
Slick is offline   Reply With Quote
Old 03-07-2013, 02:21 AM   #915
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
I think I have finally decided on a wheel/tire setup.
18x8 +35 RPF1 I really want to stay away from messing up my speedo so a 245/35/18 tire would keep my speedo in spec. Would this set up rub at all? I tried searching but only found people running 225/40/18 and 245/45/18
Tires will be Hankook V12's most likely. Thanks so much in advance!
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 03-07-2013, 03:11 AM   #916
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I run 18x8.75 +35 with 245/35/18, no problems at all, so you will be fine
Killerbee is offline   Reply With Quote
Old 03-07-2013, 03:15 AM   #917
WillBRZ
WillBRZ's Avatar
awesome! glad to hear that! are you on xxr's?
Old 03-07-2013, 03:23 AM   #918
Killerbee
Killerbee's Avatar
Yes, xxr 527. There are some pictures in my car journal, however car is still on stock suspension. I will change this over the weekend and there will be more and better pictures of it when thats finished :-)
Old 03-07-2013, 04:01 AM   #919
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
18x10 +38 front and rear 245/40s.... Lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-07-2013, 11:10 PM   #920
Slick
Slick's Avatar
Thoughts?
I see that 17x9 +35 with a 245 tire is a preferred setup for 17's, so it should work equally well on 18's? (I.e. 18x9 +35 with a 245/35R18)
Old 03-08-2013, 07:46 PM   #921
Bingbong
Bingbong's Avatar
Drives: Crv,Legacy-ultramarine frs
guys thanks in advance.my eyes burned to keep searching reading what set up of wheels/tires and springs do I need to my car ultramarine that don't need camber or anythings to buy coz I dont have much budget to my car for now only wheels/tires and springs..thanks to all threads and members.
Bingbong is offline   Reply With Quote
Old 03-08-2013, 08:08 PM   #922
Dipstik-sportech
Dipstik-sportech's Avatar
Rota grid 17x9 +35 front and rear with a 245/40-17 square setup
Old 03-08-2013, 08:13 PM   #923
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Is this a good setup
17x9 et 35
225/45/17 front Hankook rs3
245/40/17 rear Hankook rs3
Car will be turbo
Old 03-09-2013, 07:06 PM   #924
-DK-
Drives: FRS (Ultramarine MT)
Hey all,
I'm planning to get gram light rays 57Extreme.
Front: 18x8.5 +30
Rear: 18x9.5 +40
What size tires would make an optimal fit? I'm thinking of getting Dunlop DZ101 with sizes 225/45/18 front and 245/40/18 rear. Would this make a good fit and no impact to speedo/handling?
If I were to drop it by 1", would there by anything I need to change?
Thanks for the help.
-DK- is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
