Old 03-03-2013, 10:10 PM   #15
Burrcold
Drives: Subaru BRZ Limited
Mine doesn't do that. Make sure you keep auto off, then manually turn off the a/c and adjust the temp and air direction with the knobs. Once you have it set, turn the car off and back on again. The a/c should not come on and your previous settings should still be there.
Old 03-03-2013, 11:42 PM   #16
Turbowned
Turbowned's Avatar
I could be wrong, but that's how auto climate control was explained to me when I was trained on it for Audi cars. I would assume it's similar for this system.
Old 03-04-2013, 12:13 AM   #17
jmaryt
Drives: 2012 honda civic ex
Originally Posted by Huehuecoyotl View Post
it dehumidifies using the compressor, so ac is on
+1
jmaryt is offline   Reply With Quote
Old 03-04-2013, 08:49 AM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Push the Auto button, then push the A/C button. Done.
Old 03-04-2013, 08:58 AM   #19
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
is it bad when the AC turns on and you turn it off right away?
chenshuo is offline   Reply With Quote
Old 03-04-2013, 09:01 AM   #20
sierra
Drives: Skoda Yeti DSG diesel 4x4
No. It works by turning on and off all the time.
sierra is offline   Reply With Quote
Old 03-04-2013, 09:03 AM   #21
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
ok that what i'm gonna do then. whenever that AC turns on i'm gonna shut it off right away, as quick as a ninja. although some of you don't have the AC on automatically for every setting, then i guess i'm probably doing something wrong. i'll play around with it more. thanks guys
Old 03-04-2013, 09:45 AM   #22
Turbowned
Turbowned's Avatar
If all else fails, RTFM! lol
Oh, except you already did. Dammit.
Old 03-04-2013, 11:48 AM   #23
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
What thing i always thought about and maybe it happens to you guys too not just the BRZ, BUT how come when all a/c climate control etc is all turned off -> no air, while driving depending on how fast you go hot air still goes through?
Marcoscrdo is offline   Reply With Quote
Old 03-04-2013, 12:17 PM   #24
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
that's normal. it happens with any car. if you dont want the hot air coming into the car, press the "Recirculate" button. it'll turn off all the vents in the car and you won't get any air coming in.
The Following User Says Thank You to chenshuo For This Useful Post:
Spaceywilly (03-04-2013)
Old 03-04-2013, 01:16 PM   #25
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
The A/C thing really bothers me as well. Especially given that it is currently winter time. I would greatly prefer if the car was smarter about the AC operation, like if it took the outside air temperature into consideration when operating.
I don't care if my interior temp is set to 65. If its 25 degrees outside the AC shouldn't turn on!!!
Old 03-04-2013, 01:27 PM   #26
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
My AC comes on every time also. Drives me crazy, though maybe I was doing something wrong, but now I feel better about it.
Dorb is offline   Reply With Quote
Old 03-04-2013, 05:31 PM   #27
Marcoscrdo
Marcoscrdo's Avatar
Yeah ive been trying to sometimes put a/c on and its still hot air. Its just not as hot as with the a/c button off.
Old 03-04-2013, 08:15 PM   #28
Brzetto
Drives: 4 wheels
Subaru should have the ability to customize set the air system so the AC doesn't come on unless the button is pushed. A true automatic system should work both ways, fully manual or auto.
Brzetto is offline   Reply With Quote
climate control swap possibility Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 143 03-14-2019 11:46 PM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 08:38 AM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
