Old 10-28-2012, 03:54 PM   #85
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by TSY View Post
I checked my HU today.
Model: FA601US
Nav: 15:50/30.07 9.2.2.250040
Audio: 08,07,2012 Ver.44.1004
So it does appear I have a more updated version of the HU's firmware.
So now we just need someone to customize the firmware so that speed sensing isn't getting input from the GPS. Anyone know if there is any work in this area going on?
Old 10-28-2012, 05:25 PM   #86
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Originally Posted by Foobar View Post
Let me know which screen you want me to get (let me know the button sequence to get to it as well to make sure I'm looking at exactly the right info).
Sorry, you can see the version info from regular operating mode (it's not on the diagnostics screen). For anyone else who needs to check:
1. Press "Audio"
2. Touch "Info"
3. Touch "Software version"
That screen will show both the audio and navigation software versions.
To access diagnostics mode:
1. Turn off audio by pressing the PWR/VOL button/knob.
2. Press and hold all 3 buttons below the volume knob for 3 seconds.
To exit, press and hold the AUDIO button for more than 3 seconds, or turn key from ACC OFF to ON.
There doesn't appear to be any version information shown in diagnostics mode.
SVXdc is offline   Reply With Quote
Old 11-19-2012, 08:38 PM   #87
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
has anyone figured out a way to get those lines off the screen when installing a back up camera?
Jive Turkey is offline   Reply With Quote
Old 03-03-2013, 12:05 PM   #88
bulldog11267mad
bulldog11267mad's Avatar
Drives: 2013 BRZ Limited manual
i did the nav hack on my dmg brz and it worked great. then did it on my fathers sti and my cousins sti worked great everytime. my brz got totaled now i have a new wrb brz and did the nav hack on it. the same way i did on all the others grounded the grey wire on the 16 pin plug and cut the 17th pin pink/green on the 28 pin plug. this time nothing changed as soon as i start to move it kills those functions. i even unplugged the entiree 28 pin plug and still does the same thing. the model number of the head unit is the same as well. anybody have any ideas as why it would work on some but not others?
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
bulldog11267mad is offline   Reply With Quote
Old 03-03-2013, 06:47 PM   #89
Jive Turkey
the tuna, no crust.
i really need to do this. foobar, you have any issues yet? what exactly did you do.
Old 03-03-2013, 07:10 PM   #90
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I believe it has to do with the TSB update for the GPS signal issues. They reprogram the nav and I think they change it to sensing if the car is moving by GPS signal. If you want to confirm this you can unplug your gps antennae and see if the BT functions return.
Flat Black VW is offline   Reply With Quote
Old 03-04-2013, 06:31 AM   #91
Foobar
SLO NO MO
Foobar's Avatar
Are you referring to the VSS bypass? I think I have an older version of the navigation firmware which ignores GPS detection and relies solely on VSS input to determine if the nanny should kick in.
Sent from my Nexus 4 using Tapatalk 2
Old 03-04-2013, 03:15 PM   #92
Jive Turkey
the tuna, no crust.
yupp, i want to input things while i drive.
Old 03-04-2013, 04:12 PM   #93
Foobar
SLO NO MO
Foobar's Avatar
Yeah, I'm avoiding the Navi firmware upgrade until someone figures out how to make VSS/GPS Bypass work.
Old 03-04-2013, 04:15 PM   #94
Jive Turkey
the tuna, no crust.
looks like i'm going digging around this weekend, mind posting a picture of your switch? where you mounted it?
p.s. install you overpipe/frontpipe already
Old 03-04-2013, 05:37 PM   #95
Foobar
SLO NO MO
Foobar's Avatar
I believe I have a post here somewhere with a pic of it. I'm on my phone so I can't look now but I'll try and find it later.
FP/OP - still waiting on Perrin to ship it. FT86speedfactory is following up with them on status since it was confirmed in stock last week when I ordered it.
As soon as I get it, it'll be installed by the following weekend. Weather permitting.
EDIT:
Here it is: http://www.ft86club.com/forums/showt...388#post615388
The switch is inline on pin 17 of the 20-pin head unit harness. Pink/Green marking on the wire. Single-Pole/Single-Throw switch spliced right in between, and now I can use my head unit while moving. My understanding is that some other folks with different Navi firmwares have tried this mod, but the GPS signal is still preventing them from bypassing the VSS.
Old 03-13-2013, 05:43 PM   #96
reeves
I'm so glad I haven't gotten anything "fixed/updated" on my car from the dealership yet.. My NAV finds satellite signal pretty good, ~90% of the time, so it wasn't too annoying.
I'm gonna finally try this bypass and see if it works.
The Following User Says Thank You to reeves For This Useful Post:
runny_yolk (03-30-2013)
Old 05-07-2013, 01:16 PM   #97
kuhlka
Drives: 2013 BRZ Limited AT
I'm wondering if there is a better fix for the VSS signal without having to cut and wire in a switch. I'd like to use a voltmeter on that pink/green wire and the ground while the car is moving to see if the voltage changes or if it's a simple on/off. If so, we may be able to just use a simple splice and hook that wire onto something else so it tells the HU that the car is in perpetual motion. If I can get this figured out, I'll post up a YouTube tutorial from start to finish.
kuhlka is offline   Reply With Quote
Old 05-07-2013, 05:39 PM   #98
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
You're missing the point. The speed signal helps with GPS accuracy / driving through tunnels etc.. Just cut it if you're not bothered about accuracy.
86•BRZ is offline   Reply With Quote
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
