Old 09-11-2012, 12:42 AM   #71
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by sparks View Post
Not sure, Mr. SVXdc has been quite for the last few days, probably work related. All you'll need is the two pin to RCA kit and your choice of camera kit. Again, something without guide lines, or can be disabled.
I can confirm SVXdc has been off the radar
I'm not in a huge rush but if anyone knows where one can get another "wiring kit" I'd really appreciate it!
RYU is offline   Reply With Quote
Old 09-11-2012, 09:35 AM   #72
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by xcelir8brz View Post
I decided to swap out the switch that I had installed to see if that solved my problem. I cut the old switch out, and wired in a new one. Tomorrow morning on my way to work I'll try this out to see if it solved my problem. Looking at the pictures earlier in the post I did in fact use the ping/green wire and cut and tapped it appropriately. If this switch doesn't work, I'll have to remove the deck, check my soldered connections and reassemble. And if that doesn't work, maybe because I am 6AT instead of manual? Or Radio Version? I'll report back tomorrow my status.
Thanks!
So I tested this out this morning. The switch now works. However, the end result is not good. As soon as I flipped the switch (a multiple of times), my GPS got out of whack - until I literally shut everything down, was stationary, switch (on) and then all was good. Furthermore, I don't see anything undim in either navigation, phone, video. I have proven that this is controlled by the GPS in my case and not the VSS. In further diagnostic functions of the radio, the SPD sensor somehow is tied to my GPS rather the VSS wire as I was receiving SPD increases with switch off.
I have a 6AT Limited, and am not happy about this.
I truly think it might have to do with the RADIO Firmware version.
This is what I got under the 'Unit Version Information' screen:
Manufacturer Name:
Fujitsu TEN
Version:
44.103 12/04/1
CD DSP Version:
1.04
Can you guys check with yours and see if there is a comparison?
THANK YOU!
xcelir8brz is offline   Reply With Quote
Old 09-11-2012, 10:03 AM   #73
Foobar
SLO NO MO
Foobar's Avatar
Manufacturer Name:
Fujitsu TEN
Version:
44.103 12/04/1
CD DSP Version:
1.04
THANK YOU!
Weird - mine definitely doesn't care about GPS to determine motion and my toggle switch doesn't affect GPS at all - map/navigation continue to work fine without the signal. I'm sure it'll be lost if I go underground in a tunnel without the speed sensor on though, but that's to be expected.
I'll check the head unit version info tonight after work and let you know.
Old 09-11-2012, 10:07 AM   #74
Foobar
SLO NO MO
Foobar's Avatar
Oh and just to rule it out - you definitely have the e-brake line grounded on the 16-pin right? Doubt that's causing your problem, but that's one other thing that I did on mine.
Old 09-11-2012, 08:56 PM   #75
xcelir8brz
E-Break is good. The Info screen proved that when I did this mod when I installed my Amp/Sub.
Thanks!
Old 09-11-2012, 09:33 PM   #76
Foobar
SLO NO MO
Foobar's Avatar
This is from my software version screen:
Navigation: 16:24/17.04 9.2.2.230646
Audio: 04,17,2012 Ver.44.1003
Old 10-24-2012, 02:36 AM   #77
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
so is this the only sure way to bypass the lockout? ground the e-brake wire, and then put a switch to this gps signal or w/e it is wire? i'm tired of waiting to stop to put anything into the nav.
Jive Turkey is offline   Reply With Quote
Old 10-24-2012, 09:12 PM   #78
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
Can someone verify this works? I had my car on a Ferry this weekend, parked of course, and the Nav locked me out because the Ferry was moving.
I'm assuming the GPS notices the car is moving and locks the user out, even when the car is not running.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 10-24-2012, 09:44 PM   #79
Foobar
SLO NO MO
Foobar's Avatar
Switch on the vehicle speed sensor line works for me.
Sent from my Galaxy Nexus using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
TSY (10-25-2012)
Old 10-27-2012, 09:11 PM   #80
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
That definitely means your HU was using GPS to detect motion. The VSS will not have been pulsing since your wheels were not spinning. So cutting the VSS wire would not have made a difference. The only solution would be to block GPS reception (try a metal plate over your instrument cluster).
What is the model number printed on the front of your factory HU?
Same question -- what is the model number printed on the front of your factory HU?
I'm wondering if later models switched to using GPS.
ADDED: You both should also look up the firmware version on the diagnostics screen. EDIT: Not diagnostics screen. See my next post.
SVXdc is offline   Reply With Quote
Old 10-27-2012, 09:24 PM   #81
Foobar
SLO NO MO
Foobar's Avatar
FA601US
Let me know which screen you want me to get (let me know the button sequence to get to it as well to make sure I'm looking at exactly the right info).
Old 10-28-2012, 03:10 AM   #82
TSY
TSY's Avatar
My GPS was updated by the dealership with the latest firmware a month ago because I was having issues with satellite reception.
I'll check the version tomorrow.
Old 10-28-2012, 11:23 AM   #83
xcelir8brz
Thanks for the update!
Old 10-28-2012, 02:33 PM   #84
TSY
TSY's Avatar
I checked my HU today.
Model: FA601US
Nav: 15:50/30.07 9.2.2.250040
Audio: 08,07,2012 Ver.44.1004
So it does appear I have a more updated version of the HU's firmware.
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
