Old 02-20-2013, 04:06 PM   #99
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by ICantAffordAnLFA View Post
Half day every Wednesday too
Hahahaha...I'm jealous. I lived and studied in London for a while. I miss my lunchtime pints! Nothing like catching a buzz before going back to a cerebral discussion on "Das Kapital." :happy0180:
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 02-25-2013, 10:42 AM   #100
OrbitalEllipses
Drives: Attitude
*clears throat* DEM BRAKES. I NEED DEM BRAKES.
And also a lunchtime pint. That'd be great.
Old 02-25-2013, 11:24 AM   #101
JRitt
JRitt's Avatar
I just hit AP with another update request. Thanks for your patience!
www.essexparts.com
Old 02-25-2013, 12:25 PM   #102
APS86
Drives: GTS86 Manual
hi Jeff - very interested in a black set o be sent to Australia - do you still have stock?
thanks
Andrew
APS86 is offline   Reply With Quote
Old 02-25-2013, 01:46 PM   #103
OrbitalEllipses
Drives: Attitude
No biggie, you said it'd take a while.
Old 02-26-2013, 02:21 PM   #104
Ro_Ja
Drives: TOYOTA
neeeeeeeeed braaaaaaaaaaakessss
Ro_Ja is offline   Reply With Quote
The Following User Says Thank You to Ro_Ja For This Useful Post:
OrbitalEllipses (02-27-2013)
Old 02-26-2013, 02:27 PM   #105
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Cant wait for our setup to get here!
JDLAutoDesign is offline   Reply With Quote
Old 02-26-2013, 08:31 PM   #106
cslntuee
Drives: Subaru BRZ Limited
Compared with front system, there is only one disc instated of two discs in the rear system.
Any disadvantage for this?
What’s major different between using Front/Rear AP Racing Formula Brake Systems and only
Front AP racing formula brake system + stock rear brake?
Thanks.
ps. Will this BBK more easily squeal or caused the disc deformed (erosion) easier compared to the stock one?
cslntuee is offline   Reply With Quote
Old 02-27-2013, 09:12 AM   #107
cslntuee
I really interested in this stuff.
Is there any possible to have group buy? I just want to save some money and it might also
easy for you to control the quantity of the order.
Thanks.
Old 02-28-2013, 11:06 AM   #108
JRitt
JRitt's Avatar
I have some bad news gents...AP Racing told me we're still 3-4 weeks out on delivery of the first systems. They are a bit overwhelmed with orders these days since race season is now in full swing around the world. They did apologize, and assure us it will be worth the wait. I did let them know that there are existing orders in place, and that our customers are waiting. They said they'd do everything possible to get them to us as quickly as they can. Again, sorry for the delays and inconvenience. I will update as soon as I know more.
thanks
Andrew
You should contact Comp Friction in Australia. They are Australia's designated distributor in Australia, and have the ability to order these parts directly from AP Racing. They will also be holding inventory of our Essex Competition Brake Systems which feature AP Racing components. We're actually shipping some off to them along with our harness bars in the next couple of days. Also, if you buy one of these AP Racing Formula Kits through Comp Friction, I may be able to get one into one of our shipments to them (since it sounds like we ate up all of AP's initial inventory).
Thanks.
cslntuee Compared with front system, there is only one disc instated of two discs in the rear system.
Thanks.
We don't have any plans to do a group buy. The products are available to order at any time, and we occasionally run introductory specials, etc. on some of the parts we carry. In this instance, this is the launch of a completely new product by AP Racing. They are casting a new rear disc, the calipers have some new features, etc. As such, the initial production run is taking a while longer than a regular production run will once the program is up and running and everything is sorted. This is the norm with most manufacturers of just about anything...new products always provide challenges.
We placed an order for a substantial quantity of these kits in both black and red, and after our initial shipment arrives we plan to always have them on the shelf moving forward.:happy0180:
On the rear Formula four piston kit, the disc is a solid one-piece disc. In terms of heat, it's not any issue. The rear on this car should never have any heat-related problems. The downside to a one vs. two-piece rear would be weight. The advantage is that the price is considerably lower for a one-piece vs. two.
In terms of pure performance, a front-only system will give you a greater bang-for-the-buck. It just won't look nearly as good as a front/rear system.
There is no reason to believe these systems will make any more noises than the OEM system if street pads are used. Pad choice, or not having the pads bed-in properly, is the reason for brake squeal 99% of the time.
Disc wear should be lower on an oversized disc with all else held equal. In other words, the large discs in a big brake kit handle heat a lot better, and should last longer when subjected to the same conditions as a stock disc. They'll be a lot less prone to cracking. They will still wear thin over time though. Any time you have metal scraping metal (brake pad on disc), both surfaces will gradually erode. Putting a specific number on that is next to impossible as there are a huge range of variables involved... type of road, track, tires, power, weight, driving style, environment, heat introduced, etc. In other words, if you were going to get 20,000 miles out of your stock brakes, there are no guarantees that you'll get 30,000 miles out of a BBK. The primary benefit of any good big brake kit is a much greater thermal capacity, and they won't fade or give any problems when you wail on them in the canyons or at the track.
www.essexparts.com
The Following User Says Thank You to JRitt For This Useful Post:
schtebie (02-28-2013)
Old 02-28-2013, 11:54 AM   #109
JRitt
JRitt's Avatar
Guys...we just snapped some pics of each of the rear kits FYI.
And here are a couple of pics of the big dog six piston front kit to refresh your memory. The smaller four piston will look very similar...except...well...smaller!
www.essexparts.com
The Following 4 Users Say Thank You to JRitt For This Useful Post:
cslntuee (03-03-2013), cyde01 (02-28-2013), JDLAutoDesign (02-28-2013), Slartibartfast (03-03-2013)
Old 02-28-2013, 11:54 AM   #110
schtebie
Drives: CBS BRZ Limited
Just out of curiosity, how much would replacement front discs run? I think this would be good information for anyone who is considering this setup. :happy0180:
schtebie is offline   Reply With Quote
Old 02-28-2013, 12:44 PM   #111
OrbitalEllipses
Drives: Attitude
Man, I wanted them before the big meet!
Old 02-28-2013, 01:44 PM   #112
Ro_Ja
Drives: TOYOTA
Damn. I was so excited too.
#raceseasonproblems
ap racing, brakes, discs, essex, pads
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Stock wheels, +38 front, +33 rear post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2013 09:38 PM
Introducing: AP Racing Six Piston, 14 inch Formula Road Brake Kit JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 01-23-2013 04:18 PM
