Drives: 2012 BRZ Premium WRB 6MT
New Products: Front/Rear AP Racing Formula Brake Systems- fit stock wheels!
Essex led the way in FT86 brake system development with our Competition Sprint and Endurance Systems, which feature AP Racing components. We then added a massive six piston road car setup to the mix. Now we're adding a four piston front and four piston rear setup to the lineup. The best part is, they will fit stock FT86 wheels without a spacer! The rear system will work with both the front six piston or front four piston system.
You can see all of the options here. These are all on the shelf and ready to ship today! Front Red Six piston 350mm disc Front Black Six piston 350mm disc Front Red Four piston 343mm disc Front Black Four piston 343mm disc Rear Black Four piston 335mm disc Rear Red Four pison 335mm disc These systems are completely designed, manufactured, and assembled by AP Racing in England, and we (Essex) will be importing them to North America. Please visit our blog for details. I'll post more info as I have it. We are now accepting orders. Front six piston: ![]() ![]() ![]() ![]() Front four piston: ![]() ![]() ![]() ![]() Rear four piston: ![]() ![]() ![]() ![]()
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 06-20-2013 at 10:18 AM. Reason: Added links and pics |
Drives: Attitude
So these are streetable with piston dust boots, etc.?
Drives: '13 BRZ in WRB--let's mod!!!
Whoa... Nice...
Weight specs yet? |
Yes sir.
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
Not yet...but I will post as soon as I have the data.
Drives: Attitude
Ermergerd. Saving monies now.
I had you and Ro_Ja in mind when I posted this. You guys wore me down...good work.
Drives: Attitude
<3
EDIT: This is one of those times I don't NEED it, but I WANT it. Let me know if you're going to run a special on the first few sets and I'll drop the coin then and there. |
Oh dear... Do want.
#10 |
Drives: 2013 FR-S Ultramarine
Stainless or aluminum pistons?
And ditto on the weight specs. ![]() I'm curious how this compares to the Stillen kit. I'd buy it over them just because it's Essex but I know Stillen makes good stuff in general. |
#11 |
Is there a ball park price? It's funny I was just talking to my friend about getting new brakes!
#12 |
Awk. Never mind. I didn't see the link***^^^
#13 |
Drives: Flat grey Toyota 86
This is great. Count me in if we loss some weight.
#14 | |
Thanks guys. I should have weights and pics next week.
The main difference is that the four piston caliper in Stillen's kit is the only component in their kit made by AP Racing. Their kit uses a 330x28mm disc (either slotted or drilled)...I'm not sure what brand the disc is, or where it is made. Stillen manufactures the other parts in their system or sources them elsewhere. I don't know if their system comes with pads or fluid. The kit in this thread is the offcial AP Racing Formula Kit, fully designed and built in England, and imported to the USA by Essex. It features all AP Racing components...four piston calipers, two-piece discs with patented J Hook slot pattern, hats, brackets, fluid, and pads. The only exception is the brake lines, which are made by Goodridge. The front kit we are selling features an ever so slightly larger diameter disc vs. Stillen kit (332mm vs. 330mm), but the one in our kit is narrower (26mm vs. 28mm), which should give slightly better wheel fitment (I have not yet verified that though). We are only offering the J hook option on discs, not drilled. Our kit is available in silver, and theirs is not. Our kit comes with AP street pads and AP fluid...not sure if theirs does or not. Price between the two front systems is roughly identical. The rear systems are the same situation...Stillen uses AP Racing calipers and parts from other sources. Our kit is 100% AP Racing components. Ours uses a 1-piece J Hook disc, while theirs is a two-piece setup. Our rear kit is about $500 less expensive.
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 01-21-2013 at 09:15 AM. Reason: corrected disc size info |
| Tags |
| ap racing, brakes, discs, essex, pads |
| AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 07:43 PM |
| Stock wheels, +38 front, +33 rear | post_break | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 03-11-2013 09:38 PM |
| Introducing: AP Racing Six Piston, 14 inch Formula Road Brake Kit | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 01-23-2013 04:18 PM |
