Old 02-09-2013, 10:59 PM   #29
Pin Flare
Luna
Pin Flare's Avatar
Drives: 2016 FRS Release Series 2.0
I was not expecting that outcome at all. But the Pin Flare pulled out a win.
Pin Flare is offline   Reply With Quote
Old 02-09-2013, 11:06 PM   #30
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Blah blah.. Lets go to streets of willow and really put them to the test lol
Gixxersixxerman is offline   Reply With Quote
Old 02-09-2013, 11:36 PM   #31
Pin Flare
Luna
Pin Flare's Avatar
well lets do it!
Old 02-10-2013, 12:42 AM   #32
Lonewolf
Lonewolf's Avatar
Drives: Moped
The AT is so much slower because of the double overdrive (5th/6th gears), and some slight tuning differences in the top end. The manual has only one overdrive gear. However, they both have the same 4.10 gears stock.
Once someone comes out with a set of 4.5X gears for the auto and some valvebody/torque converter options...then it should be more even.
Old 02-10-2013, 12:55 AM   #33
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
That all depends on the transmission and driving style. A lot of drag racers prefer an auto Trans because it can shift faster than a human can. A manual is better for smaller motors on tighter courses to keep the rpm high and carry speed
Sent from my SGH-T989 using Tapatalk 2
Old 02-10-2013, 01:02 AM   #34
zoomzoomers
zoomzoomers's Avatar
I wanna see more AT mods!
I love the AT in this car, only other good AT under 30K range that can compete with it is the VW GTI AT (Wish we had a throttle blip when we downshifted). After that, dare i say it can compete with more luxury/sportier automatics at around 50K.
Don't know if you noticed but the AT is our cars rev match on downshifts.
first race.. from about 5mph
second race some where in second gear for both of us
his is stock. mine has a greddy evo3 exhaust, injen intake, and perrin LW pulley. also both fuel tanks were around the same.
Are you in the red car?
Old 02-10-2013, 01:11 AM   #35
ScionFrsFan
I thought the AT and MT were almost the same....its when you drop the clutch in the MT is were you see a 0 to 60 diff.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 02-10-2013, 01:14 AM   #36
ScionFrsFan
Originally Posted by DR 86 View Post
Probably has more to do with running E85. Launching AT? Hold down the brake until just before the emergency assisted braking kicks in (which will limit your revs), rev it up to 5000 rpm, simultaneously release brake and floor the throttle.
I know he's not running e85 yet...bc he has the unichip.
ScionFrsFan
Old 02-10-2013, 01:35 AM   #37
Gixxersixxerman
Pin is in the red car.. That's the manual.. I'm in my asphalt
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
zoomzoomers (02-10-2013)
Old 02-10-2013, 01:41 AM   #38
Dimman
Kuruma Otaku
Dimman's Avatar
The Cusco 4.55 RCE is testing is good for either trans. Diff is the same.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Lonewolf (02-10-2013)
Old 02-10-2013, 01:46 AM   #39
zoomzoomers
This is on a tangent, but have any of you guys noticed that when do a sharp turn or u-turn at very low or slow speeds the diff/LSD makes some noise and feel a bit rough? Or is it just me or my car?
Old 02-10-2013, 01:50 AM   #40
Gixxersixxerman
I'm sure it's just the dif working.. My dads dodge truck with some sort of LSD would have the tires squalling and chirping and then finally start skipping when in a low speed u turn because under power his locked the diff..
I'd assume with ours it's trying to prevent one wheel from "slipping" because one wheel is turning a lot more then the other.. Isn't that how our diffs work.. Lock up or activate when one wheel spins faster then the other
Old 02-10-2013, 01:54 AM   #41
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Great looking cars, guys.
husker741 is offline   Reply With Quote
Old 02-10-2013, 02:00 AM   #42
zoomzoomers
You're correct in how a diff works, but I'm referring to what's called binding. Sorry, I should have clarified.
I've noticed that the diff seems to show signs, via sound and feel, of binding when I'm at low speeds and do a sharp turn or a u-turn.
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
WRB Premium BRZ Auto. Transmission Available! ShoShin BRZ First-Gen (2012+) — General Topics 1 11-16-2012 07:25 PM
Why IS TRD so slow..... SF-FRS Engine, Exhaust, Transmission 10 07-10-2012 03:11 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
