View Poll Results: If I were to repaint/vinyl wrap this car, what color should I go with??
Stay with Lightning Red! 42 45.16%
Silver 0 0%
Gunmetal 26 27.96%
Black 5 5.38%
White 6 6.45%
Other 14 15.05%
Voters: 93. You may not vote on this poll
Old 02-02-2013, 11:45 PM   #1
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
ImperiousRex's Greddy Turbocharged BRZ
Howdy folks! Just thought I'd post up some pics of my BRZ in development. It's a daily driver but I also track the car from time to time as well. If you guys have any suggestions on any parts that would compliment what I'm putting on the car, I'd love to hear it!
Latest Update!
July 24, 2014 - Installed Greddy Circuit Oil Cooler and Koyorad Radiator!
Here's my car at the moment (will update over time):
My current list of mods include:
Wheel/Tire Upgrades:
Street setup:
Gram Light 57Extreme (18x9.5 F/R)
Continental DW Extreme (265/35R18 F/R)
Ferrodo DS2500 Brake Pads (F/R)
Track setup:
Volk TE37SL (17x9 F/R)
Hankook RS3 Ver 2 Tires (245/40R17 F/R)
Wedsport TC105N (17x9 F/R)
Maxxis RC-1 (235/40/17 F/R)
Project Mu 999 Brake Pads (F/R)
ARP Exended Studs
Greddy Gunmetal Short Lugnuts
Engine/Exhaust Upgrades:
Greddy T518Z Turbo Tuner Kit
Greddy FV Blow-Off Valve (with recirculation)
Greddy EVO3 Exhaust
Greddy Neodymium Magnetic Oil Drain Plug
EVS 70mm Front Pipe
Deatschwerks 65C Fuel Pump
Deatschwerks 700cc Fuel Injectors
HKS M-Series Super Fire Racing Sparkplugs
Koyorad Radiator
Spal Medium/Low Profile Electric Cooling Fans
Carolina Dyno Radiator Shroud
Cusco Engine Mounts
Cusco Baffled Oil Catch Can
Perrin Polyurethane Exhaust Hangers
Shorai Lithium Iron Lightweight Battery
Kinetic Custom Machine Battery Bracket
Transmission Upgrades:
Exedy Stage II Cerametallic Clutch Kit
Cusco Type RS Limited Slip Differential
Drive Shaft Shop Carbon Driveshaft
Perrin Transmission Mounts
Suspension Upgrades:
JRZ RS Coilovers - 9k(F) / 11k(R) Hypercoil Springs
SPL Rear Control Arms
Cusco Front Strut Bar with Brake Cylinder Brace
Cusco Rear Strut Bar
Cusco Front Sway Bar (20mm)
Cusco Rear Sway Bar (16mm)
Brake Upgrades:
AP Racing "Sprint" Big Brake Kit (F)
Spiegler Stainless Steel Brake Lines (F/R)
APR Air Ducts
APR Brake Backing Plates
EVS Spec Hose Reducers and 2" Brake Duct Hosing
Aero Upgrades:
APR Front Air Dam
APR Canards
APR Side Rocker Extensions
APR Rear Bumper Skirts
Voltex Type 2 1600mm Wing
Interior/Exterior Cosmetic Upgrades:
FA20Club AC Vent Gauge
TOM's LED Tail Lamps (JDM)
Seibon VS Carbon Fiber Hood
Seibon OEM Carbon Fiber Trunk
Aerocatch Plus Flush Hood Pins
VG Shark Fin Antennae
Consumables Upgrades:
Motul 300V 5w30 Oil
Project Mu G-Four Brake Fluid
Greddy Sport Oil Filter
Planned upgrades in the "near" future:
DriveShaft Shop Rear Axles
Thanks to Evasive Motorsports and CounterSpace Garage for installing everything and putting up with me and my endless questions! >.<
Pics of the parts and my notes on how they feel on the car:
Loving the aesthetics of the 57 Extreme wheels. The weight is similar to the stock wheels and tires. Also at these widths, they do poke outside of the fender a bit. Would definitely recommend getting coilovers w/tophats or some kind of camber kit before upgrading to wheels/tires of this size.
The RPF1 wheels on the other hand are very light and make the car feel so much more responsive and nimble. The R-S3's are also performing admirably at the track so this combination is making me quite happy
With the Greddy T518Z Turbo kit, the car is making more than 50% more power with a decently smooth spool up coming in at about 3.5k RPMs. The BOV is recirculated to keep the set up as efficient as we can. Nearly all the piping has been coated and wrapped and the car has been conservatively tuned for hard track use. With nearly 20k miles and 20+ track days with the turbo, the car is holding up pretty well. Cooling solutions include the Robispec V2 Radiator/Oil Cooler combo as well as upgraded Spal fans with a shroud by @Carolina Dyno.
Currently running an Exedy Stage II Cerametallic clutch kit with lightened flywheel. So far the clutch has been pretty solid for daily driving as well as hard track use (but occasionally has issues when getting into gear from a full stop). The Cusco Type RS Limited Slip Differential has also been installed and is one of my favorite upgrades. Makes the car much easier to push hard through corners even with sport traction control on. And lastly a little weight savings in the form of a DriveShaft Shop carbon fiber driveshaft.
The JRZ RS coilovers have provided amazing damping on fairly stiff springs (Hypercoil 9k F/11k R). Every click makes a noticeable difference! The Robispec front control arms added sharper and more direct steering feel and the anti-dive characteristics make the car feel much more stable under braking, acceleration and shifting. The SPL rear control arms have been solid with easier camber adjustment as well as decent access to the compression adjustment knobs on the JRZs. Strut and sway bars have stiffened up the car all around and the car in general is set up for neutral to mild oversteer.
Brake Upgrades:
Having used (and loved) the AP Racing J-Hook Rotors for my GT-R, I was already leaning towards the AP Racing "Sprint" Big Brake Kit but after an excellent sales pitch by CSG Mike, I was sold. Not only do I get to reunite with those rotors for the BRZ, I found out the brake pads for these calipers are so much thicker than the stock pads, which should lead to far fewer pad changes on top of the additional ventilation from the rotors. Any additional stopping power is just icing on the cake. Also with the new brake kit, I've also committed to separate track and street sets of brake pads and added some Stoptech slotted rotors for the rear for a little more ventilation as well.
Interior:
Installed the FA20Club AC Vent Multi-gauge. Plugs straight into the ODBII port and with it, I'm now able to keep track of Oil/Coolant temps, AFR, Boost, etc.
Exterior/Aero:
The TOM's LED Tail Lamps [JDM] and VG Sharkfin Antennae are the only purely cosmetic mods that I've added to the car but I've been quite happy with both. The tail lamps required some re-wiring to work with the USDM harness but Evasive handled it like the pros that they are! Also running full APR aero as well as a Voltex 1600mm wing for extra downforce. The Seibon VS Carbon Fiber hood was added for extra ventilation (despite being slightly heavier than stock >.<)!
Latest Dyno:
Mustang Dyno:
Dynojet Dyno (with Heat Soak comparison):
Dynapak Dyno:
Thanks for taking a look and again if you guys have any feedback, I'd love to hear it!
Last edited by ImperiousRex; 03-12-2015 at 05:51 PM. Reason: Sharing fun with rotors!
ImperiousRex is offline   Reply With Quote
Old 02-03-2013, 12:27 AM   #2
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Looking good man! Love the wheels and those are some beefy rear tires haha!
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 02-03-2013, 06:26 PM   #3
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
9/10 would bang
Surok is offline   Reply With Quote
Old 02-03-2013, 06:30 PM   #4
ImperiousRex
Track Junkie
lol thanks guys
Old 02-05-2013, 03:41 PM   #5
TWMPerformance
Drives: Manual Transmission, All the Way!
Nice parts! Build looks sweet so far
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 02-07-2013, 02:47 PM   #6
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Really nice car Ted!
Evasive Motorsports is offline   Reply With Quote
Old 02-07-2013, 02:50 PM   #7
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Definitely reccommend installing the Rear Fog Light/ Brake Light. I love mine!
L3P47 is offline   Reply With Quote
Old 02-07-2013, 03:40 PM   #8
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
Great wheel/tire choice but as you stated the car is dying for a proper coilover setup.
Orthow is offline   Reply With Quote
Old 02-07-2013, 04:04 PM   #9
ImperiousRex
Track Junkie
Haha thanks! You guys are doing a great job of working on it! ^_^
Yeah >.< I've ordered a set of JRZ RS Coilovers but they ran into a small issue of the coilovers making contact with the lower suspension parts in some settings or something like that so they're looking into it before they ship it out. Hopefully soon though!
Old 02-07-2013, 04:36 PM   #10
mackeye
mackeye's Avatar
Drives: BRZ Pearl White Satin
Nice car, well done !
mackeye is offline   Reply With Quote
Old 02-07-2013, 08:03 PM   #11
Evasive Motorsports
When the JR-Z come in the car will feel a lot better on the track.
-Randy
Old 02-19-2013, 02:13 AM   #12
BOYCE
BOYCE's Avatar
It was nice meeting you too! Here's a pic of your ride that my wife took right after your track run. I'm also looking forward to your JRZs. They should be really nice!
BOYCE is offline   Reply With Quote
Old 02-19-2013, 03:18 PM   #13
Turbowned
Turbowned's Avatar
Nice car, nice mod list! I can't wait to see it when the suspension is in!
Old 02-19-2013, 09:54 PM   #14
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
what tire setup and size do you have on your stock wheels?
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 12:28 PM
StockySnail's Lightning Red 6MT BRZ Limited Build Thread stockysnail Member's Car Journals 206 09-23-2024 12:40 PM
The lightning lap Gixxersixxerman FR-S / BRZ vs.... 35 09-17-2014 02:15 PM
Lightning Red Ft 86 Acid18 Member's Car Journals 6 12-28-2012 03:27 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 01:56 PM
