Old 01-31-2013, 03:05 AM   #1
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Darton Sleeves for FA20
They look the goods:
https://www.facebook.com/photo.php?f...type=1&theater
JP is offline   Reply With Quote
Old 01-31-2013, 03:19 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Call me stupid but what are those sleeves for?
Extending the chambers/oil flow/oil lubrication/etc.?
Old 01-31-2013, 03:22 AM   #3
JP
Backyard Fabricator
allows you to run bigger pistons/more boost etc and they also have a "closed deck" skirt at the top now to help prevent bore-shift.
Mainly for the really serious engine builds.
Old 01-31-2013, 04:07 AM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Correct me if im wrong but our engines are unsleeved, so we would just need to bore and install these sleeves for stock pistons to fit?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 01-31-2013, 04:14 AM   #5
ft_sjo
Drives: GT86
Why would you go to all that trouble just to re-fit the OEM pistons?
Old 01-31-2013, 04:15 AM   #6
JP
Backyard Fabricator
stock bores have a metal matrix liner cast into them. Bore that out, press these in, deck the sleeves to match the block, bore and finish the sleeves to fit for your choice of pistons.
From the "FA20 Engine Mechanical - Engine Unit - Details (2013 FR-S)" doc from toyota:
(4) A compact block has been achieved by producing the thin cast-iron liners and cylinder block
sub-assembly as a unit. It is not possible to rebore a block which uses this type of liner.
(5) The liners are a undercut-type, which have been manufactured so that their casting exterior
forms a large irregular surface in order to enhance the adhesion between the liners and the
aluminum cylinder block sub-assembly. The enhanced adhesion helps improve heat dissipation,
resulting in a lower overall temperature and reduced heat deformation of the cylinder bores.
Old 01-31-2013, 04:16 AM   #7
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Mmmmm so it slides Into the combustion chamber?
bigger pistons ... ? How so, the diameter is set constant only xy horizontal expansion is possible so it lengthens the chamber with this mod to the block .. does this really work? hahaha
Old 01-31-2013, 04:20 AM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
well i mean same size as stock.
Old 01-31-2013, 12:35 PM   #9
s2kdrew
Drives: 2013 hot lava FRS
this is mainly for people who are rebuilding the engine, with all high performance internal parts. stroker kits is what these sleeve for, since original block wont have enough strength once you increase the engine displacement. and could handle high boost power too.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 01-31-2013, 12:49 PM   #10
turbo_jimbo
Drives: 01 MR-s, 78 280z, 13 FR-s
That didnt take long.
turbo_jimbo is offline   Reply With Quote
Old 01-31-2013, 12:56 PM   #11
Fnbeast86
Drives: Firestorm red fr-s
Really?
Fnbeast86 is offline   Reply With Quote
Old 01-31-2013, 12:58 PM   #12
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
It addresses the issues of having an open deck block, not ideal for boost and big power.
Tansey86 is offline   Reply With Quote
Old 01-31-2013, 01:00 PM   #13
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Thank you, this was what I needed to wrap my head around these sleeves hahaha
So they slip into the cooling part of the block to add rigidity and keep its form under high rpm/pressures
Old 01-31-2013, 01:04 PM   #14
Tansey86
Tansey86's Avatar
Exactly.
STAGE 3 FA20 cf6mech Engine, Exhaust, Transmission 44 08-09-2013 01:55 PM
FA20 Dimensions Matador Engine, Exhaust, Transmission 9 07-31-2013 12:45 AM
FA20 Shortblock Ishii Motors Engine, Exhaust, Transmission 16 08-04-2012 09:28 AM
question about cylinder walls(sleeves) carbonBLUE Engine, Exhaust, Transmission 12 04-13-2012 06:21 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
