go_a_way1
Old 01-28-2013, 04:40 PM   #855
olorin
olorin's Avatar
Drives: GBS Premium
I am looking at purchasing 17x8 and I can either get 36mm or 49mm, which would be a better choice on a brz lowered 1"? I would like all wheels to be the same for simplicity.
Thanks
olorin is offline   Reply With Quote
Old 01-28-2013, 06:00 PM   #856
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thanks
+36mm
Old 01-28-2013, 06:01 PM   #857
JoeBoxer
JoeBoxer's Avatar
Originally Posted by stancypants View Post
so thinking of 18x9.5 +25 or +20 all the way around with a 225/35 better ?
225/35 is too short for this car, 225/40 would work but 245/35 would be better.
Old 01-29-2013, 12:50 PM   #858
Verysafety
That was not Verysafety.
Verysafety's Avatar
Drives: S Chassis
Nice thread. A lot of the same questions are asked over and over in this thread. Find some offset calculators online if you need help. That's all it really takes. There are some minor things to take into consideration when lowering your vehicle with wheels like suspension clearance (which bolt-on spacers help remedy)
IMO: Anything smaller than a 9 width wheel should be considered unethical.
Verysafety is offline   Reply With Quote
Old 01-31-2013, 11:17 AM   #859
mtsound
Stock suspension
16x8 +25 offset square set up running 225/50 rs3
How aggressive would this be?
I'm looking for a track wheel and I like the enkei compe
Any other options in 16x8 35-40 offset?
mtsound is offline   Reply With Quote
Old 01-31-2013, 12:43 PM   #860
Verysafety
Verysafety's Avatar
Drives: S Chassis
It's an 8 width wheel and it's 16 inches, it will not be aggressive at all.. and you're running a wide tire so there's absolutely not going to be stretch with a 50 sidewall. It'll look like balloons.
Old 01-31-2013, 11:38 PM   #861
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
my wheels are 18X8.5 et35 (17.5lbs) / 18X9.5 et42 (18.25lbs) i was planning on getting Front 225/40/18 - Rear 255/35/18 tires. Is there any other tire combos I can get on this wheel specs?(if tire brand I'm getting does not have the want specs)
tintumz22 is offline   Reply With Quote
Old 02-02-2013, 02:33 PM   #862
DC-FRS
18x8.75 all the way around, in 225/40/18. Lowered on Eibach Pro Kit ( about .5"-1.0")
DC-FRS is offline   Reply With Quote
Old 02-02-2013, 07:26 PM   #863
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
I don't know if I agree with unethical. It is in most cases unnecessary weight unless mounting a 265 width tire or wider.
However I do agree with people doing what they want with their own car.
I have a lot of 5x100 8" wheels. So if I buy another set it would be 8.5" - 9" square or 8.5"/9.5" staggered.
7" or 8" would work for most users. 215-255mm max is quite a bit of tire.
ill86 is offline   Reply With Quote
Old 02-03-2013, 11:36 AM   #864
Verysafety
Verysafety's Avatar
Drives: S Chassis
True, but really cannot bring myself to own a skinny pair of wheels other than stock wheels..
Old 02-03-2013, 11:49 AM   #865
mangostick
Drives: whiteout FRS
I've been using and recommending this tire size calculator for years. Have a look, might help with some fitment and clearance questions. Esp if you have factory wheels/tires on your car, you can plug your new sizes in and get the differences then go out to the car and actually see where the new combo would likely end up.
http://www.rimsntires.com/specs.jsp
mangostick is offline   Reply With Quote
The Following User Says Thank You to mangostick For This Useful Post:
tintumz22 (02-03-2013)
Old 02-03-2013, 12:59 PM   #866
mangostick
I'd say better than 95% (statistic I just made up but seems legit) of car owners that want to change wheels have NO concept of geometry, scrub radius or how any of it affects handling.
What works best is usually not what every likes to look at. But hey, I agree its a free country. let em do what they want. :happy0180:
The Following 2 Users Say Thank You to mangostick For This Useful Post:
coyote (02-14-2013), ill86 (02-05-2013)
Old 02-06-2013, 02:16 PM   #867
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by RazBRZ View Post
Has anyone asked about gravel rally rims?
Will these fit? or any 15"?
http://passwordjdm.com/Enkei-RCG4-Wheels-C2150.aspx
I too am curious about this.
The Following User Says Thank You to BigFatFlip For This Useful Post:
RazBRZ (02-06-2013)
Old 02-12-2013, 07:18 PM   #868
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Hey guys
I'm looking to get CCW but looking for semi aggressive
Planing on doing
18x9.5 3inch lip Front
18x10. 3inch lip rear
Questions!!!
What offset should I go with in the front and rear?
What size tire should I go with (don't wanna rub)?
Btw I'm lowered on BC coils
Thanks
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
