Old 01-23-2013, 02:13 PM   #1
xwd
Feb Fastrack posted, E85 no longer legal for ST
Well it's not official just yet but as it was recommended to the BOD, just a formality. And of course there is time for the rule to take effect.
http://scca.cdn.racersites.com/prod/...k-feb-solo.pdf
Originally Posted by Fastrack
RECOMMENDED TO THE BOD
#9305 E85 usage proposal
The following updated version of a previously-published rule change proposal is being recommended to the BOD by the SEB:
Replace the last sentence in 3.6.A with the following:
“Fuels comprised of more than 15% Ethanol may only be used when specified by the manufacturer (e.g. in the owner’s manual for Flex-Fuel vehicles).”
Comment: Per the STAC, the use of E85 is becoming more and more widespread within the Street Touring category. In some vehicles it can enable significant power increases, while in others it cannot. Cars have not been classed with this in mind. With inconsistent availability across the nation, it gives significant advantage to those willing to trailer their cars, as opposed to those who choose to daily-drive them. Unlike high octane pump fuels, E85 is relatively easy to police as its use is quite obvious due to smell. Ethanol content in a fuel sample can also be tested easily in the field.
In the Stock category, there is no option to retune a car for the use of E85 so only those designed as Flex-Fuel vehicles can use the fuel anyway. This change will have no effect there.
Old 01-23-2013, 03:31 PM   #2
Mitch
form follows function
Drives: RIP '13 BRZ
I don't understand why they'd even let designated flexfuel vehicles run cornjuice. ST allows tuning, so you're just going to let flexfuel vehicles take advantage of the added octane but not non-FFVs. It should either be all or nothing.
Mitch is offline   Reply With Quote
Old 01-23-2013, 04:04 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
And there it is... ?&%$##@%&*?!
C'mon, there's a certain level of prep for the ST classes & it's consistent with that level of prep, IMO...
GTB/ZR-1 is offline   Reply With Quote
Old 01-23-2013, 04:25 PM   #4
xwd
I think the reason is there are no Flex Fuel vehicles right now which are competitive in any autox class and chances are there won't be.
Old 01-23-2013, 04:38 PM   #5
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
whew... glad I didn't get tuned for corn ... yet.. that kinda sux.. but I understand why they did it..
Bill
Scooby South is offline   Reply With Quote
Old 01-23-2013, 05:29 PM   #6
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
This, and future flex fuel vehicle s which could be competitive will be classed with e85 potential in mind.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 01-23-2013, 05:42 PM   #7
xwd
So the thread title is a little misleading because the rule will likely not go into affect until 2014. So there may be one year to run on E85 is you want...
Old 01-23-2013, 05:51 PM   #8
Scooby South
Conedancer
yeah...thats the big question...When will the BOD implement it??? it could be 2014...or it could be immediate...depending on how they rule..
Bill
Old 01-23-2013, 07:58 PM   #9
-max-
Drives: Firestorm FRS
I like the rule. Of course we only have one e85 station in the state, so i might be biased.
-max- is offline   Reply With Quote
Old 01-23-2013, 08:20 PM   #10
Mitch
Drives: RIP '13 BRZ
You still have the same situation, people being penalized for not running E85 when it was possible. While that pool will be smaller, it will still be the case. The rule could have said "e85 will not qualify as pump gas for competition".
Old 01-23-2013, 09:44 PM   #11
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
It would be cool if it didn't take affect until 2014.
But if the BRZ/FRS dominate STX, and they move it to STR we would then loose the e85 and not be compettitve.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
Scooby South (01-23-2013)
Old 01-23-2013, 11:37 PM   #12
Scooby South
Conedancer
Unless noted otherwise the effective date for all rule, class, and listing change proposals herein is 1/1/2014
Comments regarding items published herein should be directed via the website www.sebscca.com.
I think I found the answer.. its posted right at the top of the Fast Track
Old 01-24-2013, 08:40 AM   #13
apexaddict
"Unless noted otherwise" is the key here, it can be ruled to take effect immediately. I assume that is why it's up for vote this month, so it can possibly go into effect on the March Fastrack when it comes out next month. That will be just before the start of the season.
If it passes and doesn't go into effect until 2014, then I would *highly* recommend the STX people leave their E85 at home this year. As Simmons said above, it would suck bad to risk having the car re-classed when it won't actually be as fast.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
The Following User Says Thank You to apexaddict For This Useful Post:
Scooby South (01-24-2013)
Old 01-24-2013, 09:41 AM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Good.
The less variables the better. Why can't people just drive?
November Fastrack xwd Tracking / Autocross / HPDE / Drifting 2 10-23-2012 06:26 PM
And the Winner is:...........BRZ to STX ..Oct fastrack Scooby South Tracking / Autocross / HPDE / Drifting 79 09-28-2012 03:40 AM
How much longer should I be waiting for... CGY CANADA 38 09-22-2012 05:05 PM
My longer wait... Ryosuke86 Scion FR-S / Toyota 86 GT86 General Forum 3 05-30-2012 09:26 PM
i can't wait any longer 7thgear Scion FR-S / Toyota 86 GT86 General Forum 19 02-16-2012 04:33 PM
