Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 01-19-2013, 12:30 AM   #15
a.beck
Doing it wrong.
a.beck's Avatar
Only marginally on topic: does anyone know a good place in Sydney to get aftermarket speakers (good ones) fitted? Quality work and knowledgeable staff is more important than low prices.
I've used Focal monitors in the studio and love their neutral, balanced sound. No idea if their car audio products have that, but if they do, then a Focal dealer would be ideal.
Cheers,
a.beck is offline   Reply With Quote
Old 01-19-2013, 02:41 AM   #16
st162celica
Drives: 86 GTS Manual - Tornado Grey
http://www.fhrxstudios.com/
st162celica is offline   Reply With Quote
Old 01-19-2013, 02:41 AM   #17
st162celica
Cheers,
The Following User Says Thank You to st162celica For This Useful Post:
a.beck (01-19-2013)
Old 01-19-2013, 04:19 AM   #18
Sparkles
Drives: 86 GTS MT Velocity Orange
Originally Posted by st162celica View Post
Im sure you can fit a 4 inch in there...
I just have the stock speakers connected to my amp and they seem pretty fine to me.
I wouldnt replace the speakers if you are going to run them off the headunit only. If you are going to amp them then go ahead.
100w rms per channel - Prob too much power, but it was an amp I already had.
Has just adding an amp made a noticeable Sound quality difference?
I'm looking to do the same...
Sparkles is offline   Reply With Quote
Old 01-19-2013, 06:15 AM   #19
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Originally Posted by fuddbutter View Post
Cause my 4" will fit in any hole?? :|
Well, i guess it depends on your speaker, as Flat Black said, he had to trim, which he would mean from the plastic in the hole, which wouldn't surprise me.
Some speakers say they are a certain size, but need a bigger cutout.
I have pulled out 10in subs, that seem to float in the cutout, and put other 10in subs that needed me to make the hole bigger.
I guess what i should ask is, what do you plan on putting in there, are you replacing all the speakers? or are you just wanting to add a 4in speaker?
If you are replacing them all, are you putting in a 3 way setup just cause you can?
How much do you want to spend?
Personally, if you haven't had years of experience with 3 way setups, i wouldn't use them, for two reasons.
1: they are very hard to set up correctly
2: price.
the second one ill explain
say you have a budget of $500.
for that you would get some very good two way splits, but you would get some average three way splits all because you are splitting that money over 6 speakers instead of 4.
The cheapest 3 way splits i would buy would be Crescendo's 7B's which RRP at $799 http://www.ozbliss.com/products_cres...s_7B-3Way.html
These actually sound fantastic! but you would want a good quality amp and head unit to get the most of them.
Personally, I will be running a 2 way set up, a set of CDT splits, 6.5in midbass and 1in tweeter.
The tweeter may be replaced with a large format tweeter such as a Vifa ring radiator as i used to use, which is about 4in in diameter..
Anyway, may have gotten a bit carried away there
Hey Fudd, I know you have experience so tell me what you think:
I am running 6" JL Audio component speakers and a Focal amp. It sounds like the "middle" of the sound is missing - vocals are drowned out by instrumentals.
I guess this would make sense since they took the stock midrange out.
I have been recommended a 3" midrange from the Focal K2 range. Do you think this would solve the issue?
yomchi1989 is offline   Reply With Quote
Old 01-19-2013, 07:27 AM   #20
st162celica
Depends on your budget. If I, had the money I would kit the car out.
I spent about $200 on parts/cables and did it myself. Had an amp box and sub already.
It does make a difference, the stock speakers can handle more power and they sound ok for a minor budget.
But if your going in to the trouble of paying someone to amp your stereo then it will be worth getting speaker upgrades.( you do it once and it's done ) Then if you want a sub, then that is something else to consider.
Then insulation/sound deadening. $$$ (my next project )
It's all about your budget and what YOU are going to be happy with.
Old 01-19-2013, 08:00 PM   #21
a.beck
Doing it wrong.
a.beck's Avatar
Awesome, looks like just what I'm after.
Thanks!
Old 01-19-2013, 10:32 PM   #22
st162celica
Thanks!
That guy is awesome. Forgot his name. But He knows his shit. Doesnt muck around and is very honest. He dedication and drive actually encouraged me to do it all myself.
I love his website.
Fuddbutter knows him very well. They used to judge system comps together.
fuddbutter (01-19-2013)
Old 01-19-2013, 10:55 PM   #23
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I am assuming you are running a passive crossover?
and was the JL set originally a 3 way set?
i would try playing with the EQ on the headunit first if it has one, try and bump up the frequency's around 300-800hz
If you are already running JL speakers, i would stick with them rather than going the Focal, http://www.jlaudio.com/c5-400cm-car-...ossovers-99127
The tonality of the Focals may not go well with the JL's,
Also, if the JL set you have is a 2 way system, you may need to get the 3 way passive crossover to drive them.
Unless you are wanting to run a full active 3 way front stage which even i am not game to try haha.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
yomchi1989 (01-20-2013)
Old 01-19-2013, 10:55 PM   #24
RJ_
RJ_'s Avatar
I love his website.
Is it Marty?
RJ_ is offline   Reply With Quote
Old 01-19-2013, 10:56 PM   #25
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Marty is his name
st162celica (01-20-2013)
Old 01-19-2013, 11:49 PM   #26
RJ_
RJ_'s Avatar
+1 for Marty. I had an email conversation with him over a couple of days about options for my BRZ. He was very helpful and good natured. I'd take my car there if it wasn't a 1600km round trip. The web site is also a great resource. If only there was somewhere that good where I live.
The Following User Says Thank You to RJ_ For This Useful Post:
fuddbutter (01-20-2013)
Old 01-20-2013, 12:09 AM   #27
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Where abouts do you live?
Old 01-20-2013, 01:13 AM   #28
yomchi1989
n00b
Hey Fudd,
I have had a mess around with the equalizer... not much luck still sounds rubbish, lol.
The set I have is just a 2 way set.
I have spoken to JL Audio, and they don't have a midrange speaker that they sell seperately that will fit. I would have to replace the whole system which I am not too keen on.
The man at Tonkins has suggested the Focal midrange speaker with a 3 way crossover. Installed it's $850. So it's not cheap... but I don't really have much of an option.
My speaker upgrade so26 Electronics | Audio | NAV | Infotainment 16 03-12-2014 01:16 PM
Speaker upgrades Thongpocket Electronics | Audio | NAV | Infotainment 15 03-01-2013 07:33 PM
speaker replacement pcporo Electronics | Audio | NAV | Infotainment 6 01-23-2013 03:02 AM
Speaker help! KRAZYK Electronics | Audio | NAV | Infotainment 0 08-02-2012 09:54 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
