Old 08-24-2012, 06:51 PM   #1
so26
Drives: Raven FR-S 6MT
My speaker upgrade
I just wanted to share with you guys the speaker upgrade I did on my FR-S. I (like many of you) didn't like sound of the stock stereo system in the FR-S; the highs sounded too harsh and the lower did not sound clean. It was so bad that I didn't enjoy listen to music on my +1hr commute to work; so I decided to change out the stock speakers.
I went with 6.5" Polk DB651s units in the doors and used Phenryiv1's spacers to mount them. I did not want to cut any of the original wiring so I used Metra 72-8104 speaker wiring plugs to connect them to the factory female plugs.
I used Frost King vinyl foam weatherseal tape from Lowes to form the gaskets between the spacer and the door and the speaker and the panel; and all the screws are stainless-steel.
I replaced the front speakers with 3.5" Infinity Reference X REF-3002cfx units.
As you can see spacing between the mounting holes on the new speakers was to short so I cheated and used oversized washers to hold the speakers down. I know I know some of you just cringed and I would have liked to have done it differently but it works for now and they are secure. 4" units might fit better in the space.
If you didn't like that then you are probably not going to like the jumper wires I used in the tweeter plugs to bypass them. Again, I did not want to cut the original wiring however I did desolder the male plugs from the factory 3.5" speakers and reattached them the new speakers because I couldn't find anything like Metra adapters for the front speakers.
In the end the upgrade cost me $170 in total and the system does sounds better now. Not as good as the Bose system I had in my Mazda3 but to get to that level would have cost $$$ and I was working on a tight budget.
so26 is offline   Reply With Quote
The Following 6 Users Say Thank You to so26 For This Useful Post:
chanomatik (01-09-2013), civicdrivr (09-01-2012), cmss2000 (08-30-2012), TemeCal (09-01-2012), whataboutbob (08-24-2012), XanRules (03-12-2014)
Old 08-31-2012, 11:47 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
How do you like the spacers?
Im thinking of buying
mashal is offline   Reply With Quote
Old 09-01-2012, 11:10 AM   #3
Blake
Drives: Ravin Scion FR-S
Do the doors rattle when their is bass with these new speakers? Mine currently do and I can't stand it!
Blake is offline   Reply With Quote
Old 09-01-2012, 01:36 PM   #4
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
The doors on these rattle bad, all the wires and cables that don't have enough foam on them. Get some sound deadening mat and line both inside and out on the door panel, and also put a bit on the inside of the door card itself, you don't need to do the entire panel, just behind the speaker and anywhere that sounds..uh..dingy when you tap it. I did it all just for extra quite. Made a night and day difference.
michaelahess is offline   Reply With Quote
Old 09-01-2012, 04:52 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Did you do anything for the rear speakers?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-01-2012, 11:16 PM   #6
so26
They worked perfectly ...btw make sure to use #12x1.5" screws with them.
Old 09-01-2012, 11:19 PM   #7
so26
Yes somewhat but I don't play my music very load so it's not much of an issue for me however michaelahess made some good suggestions for improving the situation.
Old 09-01-2012, 11:22 PM   #8
so26
Not yet but I'd like to put the 4" version of the infinity speakers in the rear.
Old 09-03-2012, 02:55 PM   #9
mashal
DADA
mashal's Avatar
Drives: 2013
Why did you go coaxial? Just curious I have personally never used them , I'll all about the components.
Old 10-08-2012, 01:11 PM   #10
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Why did u replace the stock tweeters that were on the dash. i am not good with speakers, but my question is can u install a coaxial 4 inch speaker on the dash without removing the stock tweeter. Would that affect anything, i am assuming it would sound better now that u have 4 tweeters in total.
vignesh is offline   Reply With Quote
Old 10-08-2012, 01:35 PM   #11
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
More tweeters isn't better, if he had the factory tweeters running he would have 6 in the front stage that's way too much.
JoeBoxer is offline   Reply With Quote
Old 10-15-2012, 07:18 PM   #12
so26
Yup and I found the stock tweeters too harsh.
Old 02-16-2014, 02:00 PM   #13
Whos2sayJay
Nurses Do it Better
Whos2sayJay's Avatar
Drives: 2013 Subaru BRZ LM AT
Can you explain how you did this? I want to do the same thing, but I'm not sure I understand the concept. I know the 3.5 inch speaker won't receive a signal if the stock tweeter harness is not connected, how do you bypass that?
Whos2sayJay is offline   Reply With Quote
Old 02-16-2014, 03:12 PM   #14
onefitz
Drives: 13 GBS BRZ
Found a lot of that rattling is actually coming from the window/door lock control boxes. A little sound deadening stuck to them to keep it from rattling made a world of difference.
onefitz is offline   Reply With Quote
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 07:18 PM
Speaker issues. Hotlava86 Issues | Warranty | Recalls / TSB 19 10-18-2012 04:06 PM
FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S phenryiv1 Audio/Visual, Electronics, Infotainment, NAV 1 08-22-2012 06:03 PM
Speaker help! KRAZYK Electronics | Audio | NAV | Infotainment 0 08-02-2012 09:54 AM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 05:43 AM
