Old 01-17-2013, 03:53 PM   #71
orthojoe
I'm testing out the new ECU protocol AiM has for our cars. Unfortunately, there's no oil temp channel available yet. :-( Any know how it is accessed? I can forward it on to them in the hopes they can implement it.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 01-17-2013, 05:11 PM   #72
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@orthojoe there's a few threads on accessing the info already (see below). It does come to the ODB2 port from the OEM oil temp sensor but is a unique Toyota code. To access the data someone needs to crack the Toyota PID code or pay heaps of money to Toyota to get it.
HKS have done that so their OB-Link works and shows oil temp - must have cost them a heap to get the unique codes from multiple manufacturers. AiM will need the info from Toyota unless someone that had the codes spills the beans!
http://www.ft86club.com/forums/showthread.php?t=23232
http://www.ft86club.com/forums/showthread.php?t=23427
nzer is offline   Reply With Quote
Old 01-17-2013, 05:25 PM   #73
orthojoe
Yup. If someone has the codes, please PM me.
2013 Subaru BRZ
Old 01-18-2013, 04:59 AM   #74
nzer
nzer's Avatar
Originally Posted by MSTiFK8R View Post
@MSTiFK8R I love the look of the single DIN gauges you have with the single DIN stereo.
I see you are running a separate oil temp sensor from the OEM one and looking at the Defi website it seems that this is required. I have the HKS OB-Link that reads it from the OBD2 connector and would love to be able to link that to the Defi gauge.
Is there any way you know of for the Defi gauge to pick up the info coming from the OEM sensor?
Old 01-18-2013, 05:21 AM   #75
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Yes Defi require separate sensor
I cant say for sure, but 99% for you CAN NOT link OEM to Defi
BTW - your ECU needs the oil temp data coming to make some justificatons, so I assume that a proper solution is to just get separate sensor
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
nzer (01-18-2013)
Old 01-18-2013, 08:23 AM   #76
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
This photo above is that dash with red stitch custom? Or did you buy somewhere?
Huehuecoyotl is offline   Reply With Quote
Old 01-18-2013, 01:17 PM   #77
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Got my oil cooler sandwich plate sitting on my desk now Test fit/hose routing will be done sunday, waiting for some straight fittings before I do the final assembly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-18-2013, 01:21 PM   #78
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'll be looking forward to the results!
Old 01-19-2013, 03:31 PM   #79
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Custom made. I hate silver.
Old 01-25-2013, 06:16 AM   #80
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by celica73 View Post
Any installed pictures (under the hood)? Did you have to use the little spacer to make room for the senders, or will they fit in spite of the oil cup?
I did the underhood shots last night for you
the Greddy combo has the spacer, so the fitment is a breeze
Old 01-25-2013, 10:31 AM   #81
celica73
Thanks!
Where did you buy the Greedy stuff?
It would have been so much easier if the drip cup had been pressed onto the block rather than cast as a part of it. I've yet to see a drop of oil spill from the filter when I take it off.
Old 01-25-2013, 10:44 AM   #82
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks!
BTW if you intend to get the Mocal cooler you can use any sandwich plate for the temp/pressure gauges, or should be able to anyways. I haven't test fit my glowshift one yet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-25-2013, 11:25 AM   #83
wootwoot
Drives: FRS
Thanks!
This^ Part numbers etc would be great
Old 01-25-2013, 06:43 PM   #84
Huehuecoyotl
If you we're to mod off the drip cup lip, u can loose the spacer? Six pack an a Dremel tool...it's aluminum right?
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
