Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-29-2012, 05:00 AM   #1
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
OBDII Connector
Any of you in Oz or NZ got an iPhone, android or PC hooked up to and working with the OBDII connector? Yes I have tried and have found some discussion in USA forum but nothing on the Australasian forum so not sure if our connectors are "live".
If you have got it working can you get real time oil temp?
And, what connector/transmitter are you using, what reader (iPhone, android, laptop) and what app or software.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
lazyluka (11-29-2012)
Old 11-29-2012, 03:35 PM   #2
Chojin9
Drives: Inop
Some talk of it here,
http://www.ft86club.com/forums/showthread.php?t=16640
Chojin9 is offline   Reply With Quote
Old 11-29-2012, 04:37 PM   #3
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
bluetooth OBD + Android phone + torque app.
fin.
RAN94A is offline   Reply With Quote
Old 11-29-2012, 04:50 PM   #4
nzer
nzer's Avatar
fin.
Which bluetooth OBD sender do you use?
Old 11-29-2012, 05:04 PM   #5
Yruyur
Yruyur's Avatar
No real time oil temp. Link to the one I use in my Sig.
Sent from my flux capacitor using Taptalk
The Following User Says Thank You to Yruyur For This Useful Post:
nzer (11-29-2012)
Old 11-29-2012, 05:39 PM   #6
nzer
nzer's Avatar
Code 01 5C 1 on this wikipedia list (assuming correct) seems to indicate it is the oil temp code. Can we not get real time data as there's no actual oil temp sensor on the car or some other reason?
http://en.wikipedia.org/wiki/OBD-II_PIDs
Old 11-29-2012, 05:44 PM   #7
lazyluka
Drives: GT86
I have the same one at home as Yruyur.
Just need a car
Looking at Torque, it should be possible as you can add custom PID's. Just added mine. I just don't know if our vehicles output Oil Temp.
Perhaps someone can try?
Torque Settings -> Manage available OBD2 PIDs
Add Custom PID
OBD2 PID:
015C (may need a space between 01 and 5C)
Long Name:
Engine Oil Temp (Change this to your liking)
Short Name:
Oil (Change this to your liking)
Min Value:
-40
Max Value:
210
Scale Factor:
x1
Unit Type:
°C
Equation:
A-40
If I understand correctly, if you want Fahrenheit replace A-40 in the equation above with: 9/5*(A-8)
lazyluka is offline   Reply With Quote
Old 11-29-2012, 05:51 PM   #8
Yruyur
Yruyur's Avatar
I was looking for that PID I will try using it. I was told there is a sensor and the Toyota software can read it but not confirmed.
Old 11-29-2012, 06:13 PM   #9
nzer
nzer's Avatar
Be very interested to hear if that PID works if you can test pretty please!
Old 11-29-2012, 06:25 PM   #10
Yruyur
Yruyur's Avatar
Testing now...we when my car gets done being washed.
Old 11-29-2012, 06:27 PM   #11
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
I use the ELM 127 obd2 bluetooth adapter (amazon for 10$)
and torque app for galaxy nexus/asus tablet from google play (5$)
Works great, and the addon's for torque to get video overlay of your inputs for logging is free and pretty sweet
JesseE is offline   Reply With Quote
Old 11-29-2012, 06:28 PM   #12
Yruyur
Yruyur's Avatar
You mean the oil temp works?
Old 11-29-2012, 06:30 PM   #13
Yruyur
Yruyur's Avatar
Not working.
Old 11-29-2012, 06:31 PM   #14
keen as
keen as's Avatar
Drives: 86 GT MT
Just need a car
Add Custom PID
OBD2 PID:
Long Name:
Short Name:
Min Value:
-40
Max Value:
210
Scale Factor:
x1
Unit Type:
°C
Equation:
A-40
Just tested it
NOT work for oil temp
Anything else I can try?
keen as is offline   Reply With Quote
BT OBDII/Android/Torque Confirmed working Dadhawk Engine, Exhaust, Transmission 54 12-06-2012 12:57 AM
brake light connector kask2_6.0 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-28-2012 05:18 PM
iPhone 5 new connector & BeSpoke?!?!? Davyator Electronics | Audio | NAV | Infotainment 14 09-18-2012 11:39 PM
Subaru iPod Connector Cable? Kimsey47 Audio/Visual, Electronics, Infotainment, NAV 25 07-05-2012 02:49 PM
