Old 01-07-2013, 03:49 PM   #15
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Cajun, why don't you combine all your one-sentence replies into one?
chenshuo is offline   Reply With Quote
Old 01-07-2013, 05:07 PM   #16
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Is it really that big of a deal?? Geez
Cajun is offline   Reply With Quote
Old 01-08-2013, 10:36 PM   #17
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
It doesn't bother me, but it adds to thread length and will eventually make it hard to sift through information.
Old 01-08-2013, 10:46 PM   #18
mashal
DADA
mashal's Avatar
Drives: 2013
Rule number 1 of any electrical work, always turn off the power .
A bust relay is nothing , I work in aviation and a short or voltage spike can cause alot of damage to some expensive shit! Be careful with your car coz if you fry something big you won't be covered under warranty , they consider it "tampering".
Next time , disconnect the battery and props to you for trying .
mashal is offline   Reply With Quote
Old 01-08-2013, 10:55 PM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@Cajun
I changed my relay without removing battery too (got lucky nothing broke). I can see how you snapped it in half. I had to pull VERY hard in order to take it out.
See attached wiring diagrams.
Go to page 383 and 385. Both of them name the fuse for the turn signals.
Go to your fuse panel (engine bay and inside the cabin) and check those fuses. Change the one blown out (the engine fuse box has spares).
BRZwiringi.pdf
Old 01-09-2013, 12:03 AM   #20
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
is it really necessary to disconnect the battery for replacing the relay? Im kinda planning to do this on weekends.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-09-2013, 12:05 AM   #21
Sportsguy83
Drives: Limited BRZ
I agree with mashal's post above. Better be safe then sorry. Disconnecting the battery takes seconds, why not be safe?
Old 01-09-2013, 12:08 AM   #22
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
true. which part I need to disconnect? + or - or both?
Old 01-09-2013, 12:12 AM   #23
Sportsguy83
Drives: Limited BRZ
the Negative.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
86 FRS (01-09-2013)
Old 01-09-2013, 12:13 AM   #24
mashal
DADA
mashal's Avatar
Drives: 2013
General rule of thumb:
Undo the negative first and connect last, with minor work I usually just disconnect the negative and cover it with towel so it doesn't hit something and spark
The Following 2 Users Say Thank You to mashal For This Useful Post:
86 FRS (01-09-2013), Sportsguy83 (01-09-2013)
Old 01-09-2013, 05:54 AM   #25
Cajun
Cajun's Avatar
I disconnected the negative yesterday to install HIDs. I thought I was gonna have to unscrew something, but you just push in a tab and pull, and you're done.
Old 01-09-2013, 04:43 PM   #26
White64Goat
And the one time you don't disconnect the battery and accidentally short something and deploy all your air bags......you're not gonna be a happy camper......
The Following User Says Thank You to White64Goat For This Useful Post:
Old 01-09-2013, 04:58 PM   #27
Neurytic
Neurytic's Avatar
Drives: 2013 Asphalt FR-S
Should we ask you how you know? :P j/k
Neurytic is offline   Reply With Quote
Old 01-11-2013, 11:02 AM   #28
White64Goat
Never have.....always disconnect battery. I went to an automotive school after high school and one of the guys in my class was wearing a mens heavy link metal bracelet and it contacted the positive terminal of the battery and it was also in contact with the core support and it left a real nasty burn impression all around his wrist in the blink of an eye. Lesson learned for me, and him too. Take your rings off too if you're working around the battery.
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 02:03 AM
