Old 12-20-2012, 11:01 PM   #141
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by AE86guy View Post
18x9.5 +40 F/R. SP spec.
Wow! This is by far the best red 86 i've seen yet! Any scrubbing at the front? And are the rears spaced at all?
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
AE86guy (12-21-2012)
Old 12-21-2012, 12:45 PM   #142
AE86guy
AE86guy's Avatar
Drives: Scion FR-S + Toyota AE86
I have a 5mm spacer in front due to the current tire size. But it still rubs the inner frame and sway bar at full lock. I will be changing tire sizes to remedy this. I also adjusted the camber for fender clearance. No rubbing at all on the un-modified fenders. And that's with 265s.
Nothing done to the rear. I will probably add a 10mm-8mm spacer as soon as I change the tires.
Thanks!
AE86guy is offline   Reply With Quote
Old 12-23-2012, 07:30 AM   #143
AusFt86
Drives: Ft86
Originally Posted by adprokid View Post
1- Wheels and tires weight with not of much power.
2- Less tire choices
3- 19" looks big for this small car
4- Low profile tires means less protection for the wheels and maybe a harsher ride
Agree
AusFt86 is offline   Reply With Quote
Old 12-24-2012, 03:27 AM   #144
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
What are your guys thoughts on extremes 18x8.5 +45 square setup?
Jeffboyarrdee is offline   Reply With Quote
Old 12-24-2012, 06:56 AM   #145
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Your setup is very good but the spoke design will be flat.
18x9.5 +40 will give you an aggressive spoke design.
adprokid is offline   Reply With Quote
Old 12-25-2012, 02:14 PM   #146
Jeffboyarrdee
I agree with the 18x9.5 +40 would give a more aggressive look, but would a square setup with that thickness of wheel and lower offset cause any rubbing? Especially since I'm still on stock suspension.
Old 12-25-2012, 05:56 PM   #147
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Only If you plan to install coilovers I would say 9.5 with 245 35 all around or even 255 if you need extra rubber, but that isn't recommended on stock suspension, the front will stick out and you will be forced to stretch tires to avoid rubbing from inside also.
So 18x8.5 +45 is the right and safe choice in my opinion
Old 01-02-2013, 01:00 PM   #148
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Spotted in another topic...
Originally Posted by funcheung View Post
Picked up my car on July 6, 2012
First thing I always do to all my cars.....paint my calipers with rust proof paint like a true ricer =P
Mod list so far:
- Perrin Lightweight Crank Pulley
- Hawk HP+ Brake pads
- Tein Flex coilovers 7k/7k
- Cusco Tower bar
- Buddyclub racing seats (used, both for $350 ^^)
- Sparco seat rails and sidemounts
- For track: Tenzo R Avid1 (TE37 reps) 17x7.5 +42 (special sale, really cheap)
Needed these to clear BBK
Yokohama Neova AD08 215/45/17
- For Street: Rays Gramlights 57xtreme 18x8.5 +35, 18x9.5 +45 waited 7 months becuz 18" ones had some major delay or something.
Bridgestone Potenza Re760 225/40/18, 255/35/18)
- Stoptech BBK, will put them on after winter.
- Eibach front and rear swaybars (awaiting delivery)
Most recent photo with Gramlights 18x8.5 +33 225/40/18, 18x9.5 +40 255/35/18
The Following User Says Thank You to DarrenDriven For This Useful Post:
Surok (01-02-2013)
Old 01-02-2013, 06:00 PM   #149
Captain Insano
OMG, those are the sex on WRB.
Captain Insano is offline   Reply With Quote
Old 01-02-2013, 06:21 PM   #150
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
That looks incredible.
Surok is offline   Reply With Quote
Old 01-03-2013, 10:21 PM   #151
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Im planning to replace my S7:F Wheel to SP Spec 57 Xtreme staggered. Im currently running squared set up 19" 225/35. whats the best tire size with no rubbing for the 57 Xtreme Gramlights 19 x 8.5 F | 9.5 R. Mine is dropped with eibach pro kit.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-04-2013, 10:58 AM   #152
jadewbj
jadewbj's Avatar
I am on Toyo Extensa HP Tires 225/40 and 255/35. My car is dropped on Tein Flex Coils (not slammed) and have 0 rubbing or clearance issues with the setup.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
86 FRS (01-04-2013)
Old 03-04-2013, 06:03 PM   #153
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
definitely getting these wheel...thx for the pics and info
FullTuneZN6 is offline   Reply With Quote
Old 03-06-2013, 10:14 AM   #154
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Is it just me, or there are absolutely no pictures of these wheels in a square 18x8.5 +33 setup? I can't seem to find any examples. All I see are staggered looks.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
KamalT (12-18-2013)
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
