go_a_way1
Old 01-01-2013, 08:50 PM   #771
Sparda29
Dunlop specs 7.5-9.0" wheels, so in theory the OEM wheels are too narrow.
A better question for the OP is why go wider for winter tires? You want narrower, not wider. 235s on a 7" wheel will be very hard to mount (tire guy may refuse) and will ballon like a mofo.
Didn't think about the whole going wider for the winter. Just don't wanna have to buy a new set of tires.
Sparda29 is offline   Reply With Quote
Old 01-01-2013, 09:10 PM   #772
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ahh so you already have those winter tires? Try to get them mounted, some tire shops may refuse or charge extra if they realize it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-01-2013, 09:43 PM   #773
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
It'll work just fine, a shop might complain, but you should take on the responsibility of doing so. If it was my own car, they would be mounted though.
FT-86 SpeedFactory is offline   Reply With Quote
Old 01-01-2013, 09:53 PM   #774
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I don't think they will be that hard to mount or anything, i know of trucks with 7" wheels with 265 tires stock, i know it's a different type tire but i'm sure they would rather mount a 235 on a 7 than stretch it on a 9.5.
Old 01-01-2013, 10:19 PM   #775
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Balloon is an understatement!!! LOL.... might not even get them to seat. And if for some miraculous reason you did, you'd have NO SIDE WALL.
*used to be an installer at PEP BOYS*
ravenblackfrs is offline   Reply With Quote
Old 01-01-2013, 10:26 PM   #776
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
aspect ratio. A 235/40 has a small sidewall, it's a lot easier to mount a 265/75 on a 7" wheel.
In fact Dunlop says a 265/75 trunk tire fits on a 7" wheel in the specs as an suggested rim size.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-01-2013, 10:29 PM   #777
gmookher
truck tires have alot more sidewall so you get more fudge factor
not so with a sports car... stretched tires dont handle the same..nor does a pinched tire.
Old 01-01-2013, 10:30 PM   #778
JoeBoxer
JoeBoxer's Avatar
They will work fine for winter tires, not trying to start an argument here but as said by FT86SpeedFactory and others there shouldn't be a problem.
Old 01-01-2013, 10:32 PM   #779
JoeBoxer
JoeBoxer's Avatar
It's a winter tire so i'm sure handling is not going to be a hugh priority. I didn't say it was ideal but if he wants to run them since he already owns them i don't see a problem.
Old 01-01-2013, 10:39 PM   #780
ravenblackfrs
I just read it as he was trying to put a tire too small to seat the bead. LOL. I've seen people try to do that believe it or not.
Old 01-04-2013, 04:44 PM   #781
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
currently have a squared set up 19 x 8.5 225/35. switching to staggered set up. its going to be my 1st staggered setup. 19 x 8.5 F i'll be running 225/35, 19 x 9.5 R whats the ideal tire size for the rear? with no rubbing and of course kinda scared to scratch the wheels on the rear going on curb.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-04-2013, 05:04 PM   #782
MenoSkyz
MenoSkyz's Avatar
Drives: Car
SLightly Stretched Tires on 18x8.5 & 18x9?
Hello each and every one of you. I have a couple of questions about stretching tires on 18x8.5/9 rims.
1. What would be a great tire size to slightly stretch on those rim sizes?
2. Will it cut handling performance?
3. Will it cut treadlife on the tire? Uneven wear?
I will not track my car and will be a daily driver, but still would like to take my car on windy roads such as Calaveras Boulevard in Milpitas. Please help me learn any knowledge that you may have since I am still very very very new to any concepts of tuning/modding/etc.
Much Love & Appreciation
MenoSkyz is offline   Reply With Quote
Old 01-04-2013, 05:13 PM   #783
JoeBoxer
JoeBoxer's Avatar
I've run 235/40 on 8.5 and 8.75" and they aren't really stretched at all but are about perfect. A lot of guys run 225/40 or 245/35 as well but i like the 235/40 for filling out the fenderwells especially if you don't plan on lowering.
Old 01-04-2013, 06:58 PM   #784
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
255/30 my first choice
265/30 alternate
ill86 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
