Old 12-29-2012, 09:33 PM   #15
RandyP
Drives: Asphalt FRS
Koni's are for sale now. Check your favorite vendor.
RandyP is offline   Reply With Quote
Old 12-29-2012, 09:39 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
For sale yes but not available yet, early march for me to get them.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Calum (12-30-2012)
Old 12-30-2012, 05:39 PM   #17
xwd
Originally Posted by SMOKETREES View Post
Well mine was i think about to break anyways cause when i took off the spring, the valve was spinning like crazy in the shaft when i impacted wrenched it so i think me taking off the spring finished the job with that strut. I dont know how it was already a bad strut when there is only about 8k on the car. I noticed something was wrong after installing cause i heard a thud noise only in the back driver side and i knew right away what is was. Valve either gets stuck within mid stroke or has a leak within it.
You can't spin the shaft in the housing with the stock struts or bad things will happen, so don't use an impact to take off the top nut or re-tighten it.
Old 12-30-2012, 05:48 PM   #18
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Yeah found that out the hard way but luckily I have a couple buddies here who have out coilovers on already and so I purchased one of em for 50$ (SCORE)!!
SMOKETREES is offline   Reply With Quote
Old 12-30-2012, 06:14 PM   #19
Supermassive
Supermassive's Avatar
I'm gonna be splitting my set up for $75 per strut plus shipping...
Supermassive is offline   Reply With Quote
Old 12-30-2012, 06:42 PM   #20
TemeCal
Drives: 86
Where were you a few weeks ago?!?! You're the only one (besides gmookher) that is willing to split them up. I'm glad to see you're willing to do this, and hope it works out for you. Most of us are just needing one strut. I can't imagine someone buying a full set, when there are so many other options out there.
Kudos to you for being willing to split them up!
TemeCal is offline   Reply With Quote
Old 12-30-2012, 06:58 PM   #21
Supermassive
Thanks, i figured that people seem to be having issues with their stock struts so it might be good to just offer them separately.
Old 12-30-2012, 07:09 PM   #22
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by whtchocla7e View Post
Any reason you guys are swapping the stock struts for stock struts already? They break easily or something?
The struts should be covered under the 3/36k warranty. So this puzzles me...
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Calum (12-30-2012)
Old 12-30-2012, 07:13 PM   #23
Red5
Drives: FRS
The stock struts aren't bad, but when you burn the seals out by spinning the shaft while you change springs, they don't last long.
Sent from...somewhere?
Red5 is offline   Reply With Quote
Old 12-30-2012, 07:48 PM   #24
AZP Installs
Gotcha.
Which springs were you putting on? Most lowering springs would kill the OEM Struts anyway.
-Mike Paisan
Old 12-30-2012, 07:54 PM   #25
TemeCal
Drives: 86
-Mike Paisan
Not sure why this is so puzzling to so many people. Struts are leaking AFTER springs are being installed. Either improper installs (spinning the shaft) or struts can't handle the springs. For many of us, it's not worth putting all the OE springs back onto the struts/shocks...hiding the fact that modifications were done to the struts...then hoping Toyota/Subaru will cover it. Much easier to just pay the $75-100.
Old 12-30-2012, 07:58 PM   #26
AZP Installs
Yeah, unless you are doing a very mild drop, no point in re-using the stock struts. Over the years we've found that except for the Eibach Prokit and similar kits you will prematurely wear out your struts anyway by putting lowering springs on. Having installed 1000s of sets of springs over the past 12 years it always amazes us when people do so little research and then wonder why their struts blew out
-Mike Paisan
Old 12-30-2012, 07:58 PM   #27
JoeBoxer
JoeBoxer's Avatar
I don't think any struts have "blown" except for anything but improper install. The stock struts can handle mild lowering springs just fine.
Old 12-30-2012, 08:01 PM   #28
AZP Installs
Yeah? Interesting. I'm not going to get in a pissing match but having installed 1000s of sets and seen the results, the struts can't handle much lowering over the long run. In our experience, most lowering springs will wear out struts in about 30k miles, at least they do on the WRXs and STis and LGTs we've seen.
-Mike Paisan
Cusco Front Strut bar. Hotlava86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 03-29-2015 10:31 PM
FS: Tanabe Strut Tower Bar whataboutbob Brakes, Suspension, Chassis 1 11-20-2012 12:53 PM
KMac Strut Tops 86drift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-03-2012 05:49 AM
Hood strut/prop peenut1086 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-25-2012 11:35 PM
