Old 10-03-2012, 05:49 AM   #1
86drift
86drift's Avatar
Drives: Toyota 86 GT
KMac Strut Tops
I've been working with KMac to develop camber and caster adjustable front strut tops.
We started out with 02-07 WRX tops as the bolt PCD was the same. However they'll raise the ride height about 20mm.
So, to reduce this difference we moved the bearing up in the plate and the middle plate is now steel (rather than alloy) and 6mm rather than 10mm. With the standard struts there's still a ride height increase of about 10mm. So, these are really only suitable for coilovers or with lowered springs. In the end it's just under 1kg and slightly lighter than the standard top. Here are pictures of the finished top.
If you're interested in purchasing a pair please refer to the classified section or PM me.
86drift is offline   Reply With Quote
Cusco Front Strut bar. Hotlava86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 03-29-2015 10:31 PM
SRT Strut Tower Triangulation Bar Swift Racing Technologies Brakes, Suspension, Chassis 34 10-24-2012 05:15 AM
Hood strut/prop peenut1086 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-25-2012 11:35 PM
Scion tops Consumer Reports 2011 reliability ratings Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 23 11-02-2011 08:52 PM
