Old 08-19-2011, 11:35 AM   #57
1660
On the Rise
Drives: Toyota
Originally Posted by Tyandriel View Post
16:1 lean?
Yes. 14.7:1 is ideal at idle for FI. Under load or WOT 12.5 to 12.9 is ideal for FI.
1660 is offline   Reply With Quote
Old 08-21-2011, 05:01 AM   #58
Tyandriel
Drives: Supra MkIII
thanks!
Tyandriel is offline   Reply With Quote
Old 08-21-2011, 11:07 AM   #59
fatoni
Originally Posted by 1660 View Post
If Yamaha takes the ITB approach like the LF-A, there won't be much left on the table. That would be a costly approach for a Scion and would probably gain more than 200 HP. On the other hand, if Yamaha takes the 2ZZ-GE approach, I think the easiest way to get more power is to increase air and fuel, larger TB and re-mapping the AFR. Yamaha will tune the intake and exhaust, so porting and polishing would help.
The crank would be forged and the connecting rods would be high strength steel, so you could probably raise the RPM limiter or fuel cut off.
itrbs probably gain more than 200hp?
Old 08-21-2011, 11:25 AM   #60
1660
On the Rise
Drives: Toyota
Yamaha is capable of getting 133.6 hp from a NA 600 cc motorcycle engine.
Old 08-21-2011, 01:08 PM   #61
Merlin
Drives: 1974 Celica
At the cost of peak power of 14k-15k rpm, with no mid range power...
Merlin is offline   Reply With Quote
Old 08-22-2011, 01:06 AM   #62
1660
On the Rise
Drives: Toyota
You missed the point. Yamaha could easily get more than 200 hp from 2 liters.
Old 08-22-2011, 01:49 AM   #63
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
That is stupid. Strap on a turbo and it's easy to get over 1000hp....
Type[R]+ is offline   Reply With Quote
Old 08-22-2011, 04:47 AM   #64
Levi
Drives: Toyota
But turbo doesn't sound good, has lag and is not responsive. Also, if the FT-86 is light it does not need 400 Nm. Too much "kick-in-the-ass" torque would make the rear wills spin even in third gear and the car will be controlable but unstable when grip is needed.
Levi is offline   Reply With Quote
Old 08-22-2011, 05:45 AM   #65
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Says who? BMW and VAG certainly disagrees with you....
Never heard a T51R supra before? Youtube that for some turbo bliss!
There's a million factors to consider, I don't know where to start!
Although not turbo, drive an Lotus Elise and an Elise supercharged back to back and then tell me which is better. And these cars are way lighter than the FT86 will ever be!
Old 08-22-2011, 09:40 PM   #66
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
I think all we need is a VERY tiny turbo.
That way people that want larger turbo can go bigger easier.
And those that don't want kicking torque will not be mad about it.
What I REALLY would smile about is if it was a twin tiny turbos
CyberFormula is offline   Reply With Quote
Old 08-22-2011, 11:08 PM   #67
fatoni
oh it sounded like you were saying itbs would gain this car 200hp. you dont need itbs for 200hp.
Old 12-25-2012, 03:31 AM   #68
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
Most I've seen run without filter. A friend has a 74 Celica without filter.
Sure they're not Carbs? Or what motor swap? I have a 74 celica too!
ZC6BRZ is offline   Reply With Quote
Old 12-25-2012, 05:12 AM   #69
Calum
That Guy
Drives: 2013 asphalt FRS MT
A thread from 1 year, 4 months and 2 days ago. You get 15 interweb points for knowing how to use the search function... But what the heck were you looking for?
Old 12-25-2012, 12:20 PM   #70
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Umm... maybe ITBs?
The Following User Says Thank You to ZC6BRZ For This Useful Post:
Calum (12-25-2012)
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 06-30-2011 11:58 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 05:49 PM
volkswagen power days monza -- test drive golf gti -- lancie Other Vehicles & General Automotive Discussions 0 06-21-2011 07:06 AM
is your new M3 down on power? NESW20 Other Vehicles & General Automotive Discussions 6 12-27-2009 10:03 AM
