Old 08-09-2011, 10:42 PM   #43
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by 1660 View Post
The technology at low load or RPM concerns emissions. If performance is the concern then AFR and fuel into the cylinder is more important.
If you're upgrading the cam, the last thing you're concerned about is emission.
Low RPM response has a bit to do with how 'active' the intake charge is in the chamber. If the air is slow, there is not very much turbulence and the air and fuel don't mix and burn as well as they should. This affects torque.
So there is a bit of performance potential with low RPM airflow tuning.
@Madfast: Thanks for that post!
Because titanium.
Old 08-10-2011, 02:14 AM   #44
1660
On the Rise
Drives: Toyota
You might want to look at the LFA's engine. It has ITBs with dual stage variable intake. There is a good chance Yamaha will use similar technology.
http://en.wikipedia.org/wiki/Lexus_LFA#Engine
"Air is fed directly from beneath the hood through a visible slit passing into a dual stage variable intake manifold and then into ten individual throttle bodies before finally exiting from a dual stage titanium muffler."
"The engine redlines at 9,000 rpm, but with a fuel cutoff set at 9,500 rpm,[49] and is constructed using forged aluminum pistons, forged titanium connecting rods, and solid titanium valves."
1660 is offline   Reply With Quote
Old 08-10-2011, 03:19 AM   #45
1660
On the Rise
Drives: Toyota
Came across this on ft86club:
http://www.ft86club.com/forums/showthread.php?t=1259
It will give a lot of insight on Yamaha's approach on design.
Old 08-10-2011, 10:04 AM   #46
Dimman
Kuruma Otaku
Dimman's Avatar
Um, that is us...
Because titanium.
Old 08-10-2011, 04:45 PM   #47
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Um, that is us...
yea... we are GOOD
Mr.Jay is offline   Reply With Quote
Old 08-10-2011, 10:05 PM   #48
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Um, that is us...
Originally Posted by Mr.Jay View Post
yea... we are GOOD
ryun84 is offline   Reply With Quote
Old 08-11-2011, 01:13 AM   #49
1660
On the Rise
Drives: Toyota
If Yamaha takes the ITB approach like the LF-A, there won't be much left on the table. That would be a costly approach for a Scion and would probably gain more than 200 HP. On the other hand, if Yamaha takes the 2ZZ-GE approach, I think the easiest way to get more power is to increase air and fuel, larger TB and re-mapping the AFR. Yamaha will tune the intake and exhaust, so porting and polishing would help.
The crank would be forged and the connecting rods would be high strength steel, so you could probably raise the RPM limiter or fuel cut off.
Old 08-16-2011, 10:16 PM   #50
Dimman
Kuruma Otaku
Dimman's Avatar
Interesting find. ITB's for an STI, from Tomei.
http://www.tomei-p.co.jp/_2003web-ca...efr_index.html
Only $5k...
Because titanium.
Old 08-16-2011, 10:23 PM   #51
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
Only $5k...
Haha only 5grand. Good deal.
82mm 4g63 is offline   Reply With Quote
Old 08-16-2011, 10:26 PM   #52
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Only $5k...
Edit: Never mind found out
Old 08-16-2011, 11:50 PM   #53
1660
On the Rise
Drives: Toyota
Only $5k...
I'll say one thing. It does look nice.
Old 08-16-2011, 11:52 PM   #54
Dimman
Kuruma Otaku
Dimman's Avatar
It better do a whole lot more than just look nice for $5k.
Because titanium.
Old 08-17-2011, 01:22 AM   #55
1660
On the Rise
Drives: Toyota
It will. Just pop your hood and everyone will go, "Uuuuhhh, aaaahhh!"
Old 08-19-2011, 10:02 AM   #56
Tyandriel
Drives: Supra MkIII
Originally Posted by madfast View Post
lets hope the ecu can be easily tuned
16:1 lean?
Tyandriel is offline   Reply With Quote
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 06-30-2011 11:58 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 05:49 PM
volkswagen power days monza -- test drive golf gti -- lancie Other Vehicles & General Automotive Discussions 0 06-21-2011 07:06 AM
is your new M3 down on power? NESW20 Other Vehicles & General Automotive Discussions 6 12-27-2009 10:03 AM
