Old 12-19-2012, 01:04 PM   #1
hypermax
hypermax's Avatar
Drives: BRZ Limited
0 offset Works XD9 (allmost)
Guys I have a set of Works XD9, they were previously for my 350z so the offset is really crazy on the BRZ, Front is 18x9 +22mm, Rear is 18x10 +18, what I have to do is get the 15mm lug conversion spacer from Project Kics and install them to all four corners, The original offset of the wheels will become near 0, FML.
Spacers will arrive tomorrow, I will see how bad this 0 offset is. The thing is I don't want to give up the wheels they are really nice.
when it is done, the car will look like an UFO, which it is pretty much against the will of the car, he was meant for handling.
Or I have to get get the wide body kit to fit the wheels
hypermax is offline   Reply With Quote
Old 12-19-2012, 01:18 PM   #2
ill roller
Drives: BRZ/E30/IS300/LS400
Give up now... With camber you could make it work if you didn't need the adapters, but that extra 15mm is going to take it too far.
RISKY DEVIL // ILL PHOTOGRAHY
ill roller is offline   Reply With Quote
Old 12-19-2012, 01:29 PM   #3
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
Don't do it!
dorifuto is offline   Reply With Quote
Old 12-19-2012, 03:44 PM   #4
hypermax
hypermax's Avatar
Drives: BRZ Limited
Originally Posted by dorifuto View Post
Don't do it!
LMAO, this is what i have in mind with the spacers, Front will fit good, but the rear will sticks out so hard
Old 12-19-2012, 03:48 PM   #5
jserman
Drives: 97 DB8
I would like to see a test fit with them just to see how much they stick out...
jserman is offline   Reply With Quote
Old 12-19-2012, 03:52 PM   #6
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
had 0 offset rims on my supra a while ago... liked it a lot, but don't think it will fit on the twins.
Walla Walla is offline   Reply With Quote
Old 12-19-2012, 04:02 PM   #7
hypermax
hypermax's Avatar
Drives: BRZ Limited
Yeah, I will do test fit for sure, I don't to give up now jet. I have to see this UFO in person to give the project.
Old 12-19-2012, 05:31 PM   #8
larryw
larryw's Avatar
Drives: -
Front might work with a butt load of camber. And I mean A LOT. About 6 degrees give or take. Rear isn't going to work. Sorry buddy. For reference, the car below has a 18x10 +12 set up in front, 18x10.5 +17 w/ in the rear, with TONS of camber. He also says he has a lot of clearance issues. I don't know if it would be worth putting the rims on.
larryw is offline   Reply With Quote
Old 12-19-2012, 05:46 PM   #9
hypermax
hypermax's Avatar
Drives: BRZ Limited
Very nice info to know, it is very helpful, and it does hurt my feeling.
Old 12-19-2012, 07:50 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Rocketbunny?
Old 12-19-2012, 07:59 PM   #11
dorifuto
dorifuto's Avatar
Drives: 2013 brz
I have a set of factory r33 gtr rims I wanna run. With a conversion spacer it would be 17x9+15. Does anybody have pics of this fitment on a brz/frs?
Old 12-19-2012, 08:14 PM   #12
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
If it wasnt dropped to the floor I think this would look pretty good. I think that he should go ahead with it, and see how it works out. The pics above are pretty flush or barely poking a bit, and I bet the clearance issues are more from the drop than the rims themselves.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 12-19-2012, 08:38 PM   #13
jserman
Drives: 97 DB8
Larryw that frs is pimp
Old 12-20-2012, 01:43 PM   #14
jumbaco
jumbaco's Avatar
Drives: FD
how did you come up with the zero offset?
Front is 18x9 +22mm, Rear is 18x10 +18, with 15mm spacer, you will now have 18x9+7, 18x10 +3
jumbaco is offline   Reply With Quote
So, what's the stock offset? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 12-17-2018 10:47 PM
offset is everything notFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 04-11-2017 02:52 PM
37 vs 45 offset - Advan RS Symbiont Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-28-2014 12:12 PM
Offset for GT vs. GTS giraffee AUSTRALIA 3 07-20-2012 12:30 AM
deep offset jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-28-2012 10:12 PM
