Old 12-15-2012, 06:47 AM   #29
OrbitalEllipses
Drives: Attitude
Signal interference? Is that cable shielded stock?
Glad I could help.
Sportsguy83 (12-15-2012)
Old 12-15-2012, 08:44 AM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Glad I could help.
It is shielded. There is a part that when I remove the grommet is exposed, but it's not touching the other cable. I think that cable has to be super sensitive, because I think they are shielded enough for this not to happen. It will be interesting for sure, hopefully I can extra insulate!
Sent from my HTC One XL using Tapatalk 2
Old 12-15-2012, 11:12 AM   #31
Sportsguy83
Drives: Limited BRZ
Ok, i need the electrical experts here. I tried disconnecting the sensor, i isolated the cables from themselves completely, I disconnected the taillight. Every time the same result. If the car is started with the lights on, the car goes on limp mode. If the car is started with the lights off, it starts up normally as it should.
If the lights are on, and the bulb in the fog light kit is removed, the car turns on normal. So, definintely there is something telling the car that bulb is there, and if it is on before starting the car, it goes on limp mode.....
HELP!!
Old 12-15-2012, 12:26 PM   #32
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Try a smaller bulb in the fog light, one which draws less current? Sound like the car might be detecting the added current as if it were a short in the rear lights wire. Exactly where is the power for the fog light coming from?
b.e is offline   Reply With Quote
Old 12-15-2012, 02:39 PM   #33
Sportsguy83
Drives: Limited BRZ
Its coming from the tail lights normal light and brake light connection. I need to find a different bulb that fits so I can try that. I tried the OEM turn signals, but those would not lit up.
Old 12-17-2012, 08:27 AM   #34
Sportsguy83
Drives: Limited BRZ
@johnb831 to keep you on the loop of what's going on, I kept testing to see what specific conditions were the problem and which weren't. I've kept working with Fn'A and they have been extremely helpful and supportive throughout my testing.
I found later on yesterday that if you turn the car on with the brake light active, the car starts fine. This singles out the problem being specifically when the "fog light" is on with the taillights before starting the car, and you start it then the car starts in limp mode.
So now FnA is looking into how to mask the light on startup, probably some type of time delay.
Old 12-17-2012, 12:56 PM   #35
b.e
Swap in LED lights everywhere to save current, maybe? Or unhook the light from the marker lights and use only the brake light?
I like their Kit 3, so I'm rather interested in the solution to your problem.
Old 12-17-2012, 02:14 PM   #36
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Don't jump the gun on swapping in LED's everywhere to save current; We've had multiple frs/brz's working without issues with our kits.
After plenty of talking back and forth, we paid for @Sportsguy83 to ship the kit back where we'll test it and find out what exactly is going wrong with his to make it do that. @b.e We're going to find out whether or not his issue is BRZ Limited related or just a faulty kit, but you will have no problems with your FRS for sure. Our FRS tester hasn't even had a flicker in the last few months!
F n' A Automotive is offline   Reply With Quote
The Following User Says Thank You to F n' A Automotive For This Useful Post:
b.e (12-18-2012)
Old 12-17-2012, 02:18 PM   #37
Sportsguy83
Drives: Limited BRZ
I already have LED's everywhere. I'm very interested in the solution too
The Following User Says Thank You to Sportsguy83 For This Useful Post:
b.e (12-18-2012)
Old 12-17-2012, 09:08 PM   #38
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
thanks for the update. its weird i haven't had anything come up every since the install. it only happened once to me. is it still turning on frequently for you?
johnb831 is offline   Reply With Quote
Old 12-18-2012, 08:27 AM   #39
Sportsguy83
Drives: Limited BRZ
It happens everytime I turn the lights and then start the car. Consistently everytime.
Old 12-18-2012, 09:19 AM   #40
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
I hope you can fix that problem man.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
The Following User Says Thank You to jazztennor For This Useful Post:
Sportsguy83 (12-18-2012)
Old 12-18-2012, 10:25 AM   #41
Sportsguy83
Drives: Limited BRZ
I hope so too. I took the kit out so right now its good to go but I want to make it work.
Old 12-18-2012, 11:20 AM   #42
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
It looks really good with the kit in.
Upgrades
winter mode notFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-02-2013 04:59 AM
My Winter Mode M3MPHIS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 12-25-2012 01:41 AM
My limp speedometer bothers me FastLap Scion FR-S / Toyota 86 GT86 General Forum 29 08-27-2012 03:30 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 04:02 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
