Old 06-17-2012, 03:16 PM   #1
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
Question snow mode = girlfriend mode?
Do we know what Snow mode does exactly?
Does it only eliminate 1st gear from the sequence? Or does it:
--change or increase the TC or VSC or ABS or EBD?
--soften or limit power?
--soften throttle response?
--soften shift speed or directness?
--hasten the onset of upshifts and delay the onset of downshifts?
I've searched and haven't found any definitive explanations. If it did a couple of the above it might serve as a decent "girlfriend mode." I want her to try the car and even drive it sometimes (always with me in the car) but she's a bit apprehensive about the acceleration and power (I'm only slightly apprehensive about her driving since it's a pretty tame car). She saw the new commercial and doesn't feel worthy.
Thoughts?
I s'pose I could just lie and say it does crank up the safety electronics and tone down the power...
Nepenthe is offline   Reply With Quote
Old 06-17-2012, 03:23 PM   #2
kgc
Drives: 2013 Subaru BRZ Limited AT
Thoughts?
I drove an auto BRZ the other day. I'd say you don't need a "girlfriend" mode. The power delivery is very smooth, and the low end doesn't exactly push you back in your seat.
kgc is offline   Reply With Quote
Old 06-17-2012, 03:26 PM   #3
Nepenthe
Yes, I would agree with that for the most part. Still wondering what it does precisely though, and whether it could help assuage her fear.
Old 06-17-2012, 04:30 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
All snow mode does is it starts you on 2nd gear when you are at a complete stop, prevents wheel spin .. and you get a slow start with very low torque.
mashal is offline   Reply With Quote
Old 06-18-2012, 11:53 PM   #5
kgc
Also, you really won't get significant wheel spin even if you floor it with the auto.
Old 06-19-2012, 12:12 AM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
First off their isnt much wheel spin with the manual tranny either unless you have traction off completely and even then its 200hp car , you won't get anything like a pony. With either tranny you would make the tire squeak with the trac 100% switched off , but I would be very careful .. This car handles very different .
Second , the snow mode is only for the Auto.
Old 06-19-2012, 12:19 AM   #7
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
thanks. i havent even tried that snow mode... but they again Im in sunny CA -- i wasnt planning to even try to take it to the snow -- i may get stuck in 2" of fresh powder and totally loose the car if it snows over 12"...
but thanks for that info -- sounds like it should be labeled SLOW NOT snow
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 07-01-2012, 08:06 AM   #8
Nepenthe
Just to follow up (sorry abut the two-week gap!):
http://www.cars.com/scion/fr-s/2013/...s/?revid=58456
"...Snow mode that softens throttle application..."
http://www.autoweek.com/article/2012...iews/120429856
"...automatic is also programmable, with manual and sport modes that increase responsiveness from the powertrain and a snow mode for decreased response..."
http://consumerguideauto.howstuffwor...scion-fr-s.htm
"...automatic transmission also has "sport" and "snow" modes that use different shift-pattern programming..."
For what it's worth, it appears some journalists were of the opinion Snow did more than just lock out 1st gear. I've done some testing with Snow and I believe throttle response, shift speed, and gear selection are all affected. Snow isn't too bad, really. I've used it a few times on my daily commute where the highest posted speed limit is 30 mph.
Old 07-01-2012, 01:05 PM   #9
...For what it's worth, it appears some journalists were of the opinion Snow did more than just lock out 1st gear. I've done some testing with Snow and I believe throttle response, shift speed, and gear selection are all affected. Snow isn't too bad, really. I've used it a few times on my daily commute where the highest posted speed limit is 30 mph.
I've done the same with similar results but honestly wasn't sure if it was a real change in everything from first or whether it was a Hawthorne Effect kind of thing where I was expecting a difference so I found it.
Old 07-01-2012, 03:02 PM   #10
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I thought I was the only one who knew about the Hawthorne effect
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 10:48 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
Snow ZetaVI NY / NJ / CT / PA 3 01-21-2012 06:33 PM
