#29 |
Drives: Attitude
Signal interference? Is that cable shielded stock?
Glad I could help. |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Sportsguy83 (12-15-2012) |
#30 | |
I Love custom Turbo kits
Drives: Limited BRZ
Sent from my HTC One XL using Tapatalk 2
#31 |
Drives: Limited BRZ
Ok, i need the electrical experts here. I tried disconnecting the sensor, i isolated the cables from themselves completely, I disconnected the taillight. Every time the same result. If the car is started with the lights on, the car goes on limp mode. If the car is started with the lights off, it starts up normally as it should.
If the lights are on, and the bulb in the fog light kit is removed, the car turns on normal. So, definintely there is something telling the car that bulb is there, and if it is on before starting the car, it goes on limp mode..... HELP!!
#32 |
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Try a smaller bulb in the fog light, one which draws less current? Sound like the car might be detecting the added current as if it were a short in the rear lights wire. Exactly where is the power for the fog light coming from?
#33 |
Drives: Limited BRZ
Its coming from the tail lights normal light and brake light connection. I need to find a different bulb that fits so I can try that. I tried the OEM turn signals, but those would not lit up.
#34 |
Drives: Limited BRZ
@johnb831 to keep you on the loop of what's going on, I kept testing to see what specific conditions were the problem and which weren't. I've kept working with Fn'A and they have been extremely helpful and supportive throughout my testing.
I found later on yesterday that if you turn the car on with the brake light active, the car starts fine. This singles out the problem being specifically when the "fog light" is on with the taillights before starting the car, and you start it then the car starts in limp mode. So now FnA is looking into how to mask the light on startup, probably some type of time delay.
#35 |
Swap in LED lights everywhere to save current, maybe? Or unhook the light from the marker lights and use only the brake light?
I like their Kit 3, so I'm rather interested in the solution to your problem. |
#36 | |
Drives: 11 STi Sedan
After plenty of talking back and forth, we paid for @Sportsguy83 to ship the kit back where we'll test it and find out what exactly is going wrong with his to make it do that. @b.e We're going to find out whether or not his issue is BRZ Limited related or just a faulty kit, but you will have no problems with your FRS for sure. Our FRS tester hasn't even had a flicker in the last few months! |
| The Following User Says Thank You to F n' A Automotive For This Useful Post: | b.e (12-18-2012) |
#37 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | b.e (12-18-2012) |
#38 | |
Drives: SWP 2013 Subaru BRZ Limited
#39 |
Drives: Limited BRZ
It happens everytime I turn the lights and then start the car. Consistently everytime.
#40 |
Drives: Scion FR-s
I hope you can fix that problem man.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake |
| The Following User Says Thank You to jazztennor For This Useful Post: | Sportsguy83 (12-18-2012) |
#41 |
Drives: Limited BRZ
I hope so too. I took the kit out so right now its good to go but I want to make it work.
#42 |
Drives: Scion FR-s
It looks really good with the kit in.
Upgrades
| winter mode | notFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 01-02-2013 03:59 AM |
| My Winter Mode | M3MPHIS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 12-25-2012 12:41 AM |
| My limp speedometer bothers me | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 08-27-2012 02:30 PM |
| snow mode = girlfriend mode? | Nepenthe | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 07-01-2012 03:02 PM |
| sport mode... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-01-2012 11:50 AM |
