Old 12-16-2012, 12:40 PM   #29
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Stock with k&n or TRD :p
Are your this is safe for the MAF if we use a oiled filter like the k&n?
And do you know if the TRD is oiled?
Mikepage is offline   Reply With Quote
Old 12-16-2012, 12:42 PM   #30
gmookher
intake: get a TRD or perrin drop in filter if you want stock tune
or get a perrin CAI and stage1 tune as they come available
Old 12-16-2012, 12:43 PM   #31
Mikepage
Mikepage's Avatar
Originally Posted by Darryljr11 View Post
Since people "claim" the injen intake makes your car run lean no matter what but can you actually prove it? Everyone I know in MD with the kit has had no issues whether they have an ecu tune or not. By the way its a short ram intake not a cold air intake but the filter does sit right in front of the snorkel thats supposed to draw in outside air albeit with a opening that allows some air from the engine bay to come in.
If you produce HP with an intake, it will probably lean your engine. More lean = more HP.
Old 12-16-2012, 12:54 PM   #32
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
mine have the GReddy intake. installed without disconnecting the battery. since greddy said its just a bolt on intake. so far so good, no cel or anything. and so much feel the difference from the stock
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 12-16-2012, 12:55 PM   #33
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Since no one wants to post a link to their claims...
http://store.newlevelmotorsports.com/faandmyabafa.html
Darryljr11 is offline   Reply With Quote
Old 12-16-2012, 03:34 PM   #34
FT86Dubai
FT86Dubai's Avatar
Drives: 2013 Toyota 86
Originally Posted by ScionFR-S View Post
im installing the Takeda intake tomorrow and will definitely make sure to keep the battery unplugged the length of the install and i will update everyone accordingly... wish me luck !
I am also in the brainstorming stage o buying an intake and somehow Injen looks like the best one. Your findings would defiantly be interesting to all
2013 Toyota 86 (Sold it and regretting)
FT86Dubai is offline   Reply With Quote
Old 12-16-2012, 03:36 PM   #35
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
I have the AFE and I love it I'm on fa20club stage 2
WiKKiD is offline   Reply With Quote
Old 12-16-2012, 03:45 PM   #36
2forme
Yes, it's been proven... because dynos.
Just because the car doesn't buck or stall, doesn't mean it's running correctly. I'm sorry but running 14:1 above 3500 RPM under heavy load just isn't safe in the long haul.
Old 12-16-2012, 04:14 PM   #37
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
No link to these mystery dynos = no support for your argument
Old 12-16-2012, 04:40 PM   #38
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post:
2forme (12-16-2012)
Old 12-16-2012, 04:47 PM   #39
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
already did and found nothing about the injen intake giving the engine a 14:1 AFR
Old 12-16-2012, 04:49 PM   #40
Sportsguy83
Drives: Limited BRZ
already did and found nothing about the injen intake givin the engine a 14:1 compression ratio
I hope that is a typo. If not, you need to do a bit more research about this subject. 14:1 being talked about is a ratio of of masses in the fuel mixture, that actually means 14 of air to 1 of fuel... The higher number the "leaner" because there is more air per fuel. Running lean leads to detonation and high temperatures among other things.
As for the Dynos, several plots are posted in the site showing the AFR mixture and why it is too lean with virtually all intakes.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
2forme (12-16-2012), Foobar (12-16-2012)
Old 12-16-2012, 05:28 PM   #41
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
You can also run data logs through your OBD2 port to show your AFR continuously. Much of this mysterious info was talked to death months ago which is why we no longer require proof.
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Foobar (12-16-2012)
Old 12-16-2012, 05:44 PM   #42
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
That was a typo meant to say AFR. Correct me if i'm wrong but doesn't the stock engine have an AFR of about 14.9:1 from 1,300 to 3,000 rpm at low-end, 13.1:1 from 3,200 to 6,200 rpm in the midrange and richens up at the top end (12.0:1 and lower) from 6,300 to redline? If these numbers are leaner by 0.5 is that really going to be detrimental to the engine?
Best intake? Maps316 Engine, Exhaust, Transmission 34 05-12-2014 04:15 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
Looking for HKS Intake Spartan65 Engine, Exhaust, Transmission 2 09-12-2012 11:40 PM
